Old 08-24-2010, 04:33 PM   #19
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
It's bad enough that Yaris has a "4 1/2" gear with a marginal drop from 4th to 5th, the last thing I need is to be pulling even more RPM's at 75 MPH...
...no thanks.
Midnight Drifter is offline   Reply With Quote
Old 08-24-2010, 06:36 PM   #20
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
...no thanks.
I hear you, I'd be tempted to go the other way, or even find a 6 speed box that could help turn the revs down.
But then again, I am not going to race it.
Colin Chapman disciple
Old 08-24-2010, 07:17 PM   #21
That's the first thing I need.
Old 08-25-2010, 10:36 AM   #22
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
With the 6 speed in my car I turn 2950 RPM (aprox 350 more than the 5 speed) @ 100km/h (62mph) and I'm getting better fuel economy than with my 5 speed.
I average 700+km on 40-42L of fuel. With the 5 speed I'd average 650-680km on the same fuel.
Old 08-25-2010, 02:16 PM   #23
Jason@SportsCar
A 6spd would actually do the opposite. A 6spd is essentially a close-ratio gear box, and 6th gear is only fractionally taller than 5th in a 5spd. And in nearly every case Toyota has outfitted the 6spd with a shorter final drive, which actually means you are spinning the engine more with the 6spd.
If you want to drop your revs put on some taller tires, or drive slower.
Old 08-25-2010, 08:56 PM   #24
Morgan
Morgan's Avatar
Drives: 07 MM LB
Good luck...
Old 09-09-2010, 01:08 AM   #25
johnny_vitz
Drives: 2005 Toyota Echo
Originally Posted by Jason@SportsCar View Post
If anyone is interested, we have done the xB final drive (4.312) swap in our Yaris, fits and works perfectly.
Parts needed from Toyota/Scion:
33321-52110, output shaft
41221-52270, ring gear
90105-11040, ring gear bolts (8)
Depending on mileage you may also want to replace bearings and seals, but you don't need to source those from Toyota.
Do you know if the 5 speed trans from an xb will bolt into an echo? And if so, I could use the 8 bolt LSD in it?
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 09-11-2010, 07:11 PM   #26
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
yes, the xa/xb/echo share transmission mounts. the echo trans is a bit longer, so a swap from an xB to echo would yield slightly more room on the end. the xB comes with an 8 bolt differential, so i'm not sure why you'd be concerned with using an 8 bolt lsd in your 8 bolt transaxle ?
Originally Posted by xnamerxx
you nailed it sir.
Old 09-12-2010, 07:32 PM   #27
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
For anyone racing their car up and down hills and around corners, the final drive change is the best value for money performance increase I reckon you can do (short of forced induction, if allowed).
The difference for drivers of Echo's is phenomenal. I have a TRD 4.7:1 final drive in my car and there is a steep hill near me that I used to only be able to do about 60kph up it. Basically as soon as I changed into 2nd the gear, the engine didn't have enough power to accelerate and my speed would drop. With the new final drive, I am still slowly accelerating at 80 kph by the time I reach the top of the hill.
rob323 is offline   Reply With Quote
Old 09-12-2010, 07:36 PM   #28
Bluevitz-rs
Rob, you need a 1.5 in that thing
Old 09-12-2010, 08:32 PM   #29
rob323
Yes, that's all fine but it throws me up into the 1401-1600cc class where there is no way I can compete against mivec mirages and Vtec civics.
Old 09-12-2010, 08:42 PM   #30
Bluevitz-rs
^ Oh, gotcha
Old 09-12-2010, 08:55 PM   #31
why?
why?'s Avatar
Drives: Yaris LB
Well I knew a 6 speed would be closer ratio, but I hate the 4th to 5th gear change in the yaris, it is almost worthless. If the 6 speeds do have a shorter final drive, you would be right, and the last thing the yaris needs is to be revving even higher at normal highway speeds.
So if I ever have enough money or time I'd need to look outside of Toyota, and that would mean crazy money. Oh well.
Old 09-12-2010, 10:12 PM   #32
Bluevitz-rs
Just change out the fifth gear for the .725 in the C60/C160
Old 09-12-2010, 11:38 PM   #33
johnny_vitz
The 8 bolt is just a lot more common and easier to find (than the echo's 6 bolt). I just wanted to make sure the xb trans would fit in so I could just have the xb trans with an LSD ready for spring to go in... With a new clutch and flywheel. Thanks for the info!
Old 09-13-2010, 11:37 AM   #34
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
My biggest complaint about my Yaris gearing (automatic) is the 3rd gear. Mine accelerates fine in 1st and 2nd, then when 3rd comes along it's such a long gear that acceleration drops rapidly and people often start passing me. Also, it's annoying that sometimes the car will shift into 3rd when going uphill and then I'll actually start going slower until it figures out that it should have stayed in 2nd. I find myself manually shifting the gears when going uphill because of this. If I could have bought a manual to begin with I would have, but I could only find 1 manual sedan in the whole southeast (within my dealer's trading range) and it was as base model as you can get :(
Old 09-13-2010, 06:40 PM   #35
Tamago
Tamago's Avatar
Drives: ZZW30
that sounds like an engine problem to me ;) time for more power!
you nailed it sir.
Old 10-22-2010, 09:09 PM   #36
Niner
Drives: Silver 07 Yaris Sedan
If anyone's interested, I've got a Scion xA and want to do the reverse swap - put a Yaris final drive in it. I'm more interested in gas than speed. Used to have a Yaris but lost it in a garage fire (and just discovered I still have a login here).
Not sure how we'd work out the swap (I have a truck, but driving that for very long defeats the purpose of saving fuel). Any takers in Michigan near Lansing or Detroit would be a much better option, or anyone that has the engine out already and don't need the shaft back immediately (with escrow cash or whatever needed so I don't sit on my butt too long.)
Henry
Niner is offline   Reply With Quote
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 03:58 PM
TRD final drive hare Performance Modifications 10 01-15-2010 01:19 PM
Final Drive t0m4s Performance Modifications 17 04-11-2009 04:16 PM
Final Drive t0m4s Central and South America 0 04-07-2009 07:06 PM
final drive rx100 Performance Modifications 2 08-21-2007 02:26 AM
