Old 09-11-2010, 06:11 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by johnny_vitz View Post
Do you know if the 5 speed trans from an xb will bolt into an echo? And if so, I could use the 8 bolt LSD in it?
yes, the xa/xb/echo share transmission mounts. the echo trans is a bit longer, so a swap from an xB to echo would yield slightly more room on the end. the xB comes with an 8 bolt differential, so i'm not sure why you'd be concerned with using an 8 bolt lsd in your 8 bolt transaxle ?
TRD final drive hare Performance Modifications 10 01-15-2010 12:19 PM
Final Drive t0m4s Performance Modifications 17 04-11-2009 03:16 PM
Final Drive t0m4s Central and South America 0 04-07-2009 06:06 PM
final drive rx100 Performance Modifications 2 08-21-2007 01:26 AM
