Old 11-04-2010, 08:16 AM   #469
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
145hp
I guess most of the power is locked up in the head
Old 11-04-2010, 09:10 AM   #470
henry33
Drives: yaris1.33
not bad result for the atmospheric engine ;)
henry33 is offline   Reply With Quote
Old 11-04-2010, 12:08 PM   #471
^ balanced and blueprinted also, not all in the head work. An inspiring result for an N/A build on that motor.
Old 11-04-2010, 12:46 PM   #472
Bluevitz-rs
and I'm sure if they weren't restricted to certain stock parts it would be even higher. TB, intake manifold... ect.
Old 11-04-2010, 01:38 PM   #473
Jason@SportsCar
Don't believe most of the info you are reading out there... Tons of people just take the Toyota press release and try to sexy it up - even the Toyota release has a typo, we did not start with a 5-door. The engine is not balanced and blueprinted, 100% OE Toyota bottom end, never touched.
Also keep in mind, as I said when I posted the old dyno sheet, this is from a Dynapak, these are not at the wheels numbers. While I think we made great power for our first crack at this engine, it is not a 145hp at the wheels monster. In reality it should be down a hp or two from that, since we had to pull what was left of the aluminum pulleys off.
Old 11-04-2010, 01:51 PM   #474
hmm, Ok I sit corrected.
isn't the old dyno before cams and management change, though?
Old 11-04-2010, 01:57 PM   #475
145hp@7252rpm
moar redline?
Old 11-04-2010, 02:00 PM   #476
Originally Posted by Jason@SportsCar View Post
Here is the dyno graph before the AEM EMS 2.
oh, i see....peak power rpm fudged by toyota?
Old 11-04-2010, 02:26 PM   #477
Jason@SportsCar
Yes it was. I think the head and cams yielded a very small return.
Bolt-ons and the Camcon will get you 90% of what we made. For the rest you need to get past the rev limiter, the AEM got us that, and better control of VVT-i, this is where the next chunk of power came from.
With our Level 2 prep limits only allowing us max .390 cam lift, and port matching 1" in, we did not make a lot of power on the head. There is still a lot left in there, but as long was we race the car in H Prod we can't go further into the head.
Old 11-04-2010, 02:28 PM   #478
Jason@SportsCar
No, that was our old dyno sheet. Before the AEM, cams and port work. That was bolt-ons and the Camcon.
Old 11-05-2010, 12:06 AM   #479
i wouldnt mind seeing the newer dyno sheet if you have access to it...
Old 11-05-2010, 09:41 AM   #480
33OH
Drives: '08 Yaris
What all bolt-ons did you have on? Is there list somewhere?
Old 11-05-2010, 10:05 AM   #481
hatchbackkid82
Drives: .
+1
Old 11-05-2010, 01:14 PM   #482
Jason@SportsCar
All of the parts are listed in the story in SportsCar, there is a link to download a PDF of it in this thread.
In a nutshell - the power stuff:
AEM EMS series 2 - you need the ability to control the VVT-i/fuel/ign to make all the other parts work to full potential. Without a tune you will get minimal gains from the rest. This car was originally tuned for economy and reliability, there is a lot of power that can be unlocked with a proper tune.
Okada coils
K&N intake
DC header/Coast Fab muffler/no cat
SPEC aluminum flywheel
NST pulleys - these were on when we did the dyno runs, and for most of the season. Once we started running 7300+rpm on the track the crank pulley failed, so we went back to stock.
Old 11-05-2010, 02:28 PM   #483
33OH
Drives: '08 Yaris
Awesome, thanks Jason. Your car rocks. Finally some motivation to try and pull some N/A power from a 1NZFE.
Old 11-05-2010, 05:40 PM   #484
Astroman
Modded Moderator
Astroman's Avatar
I love this thread.
Old 11-06-2010, 10:55 AM   #485
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
am i reading this right? you had the NST pulleys installed, then when u tweeked the engine and started running higher revs the NST crank shaft pulley broke? how bad was the damage?
also, im assuming that the NST pulleys are a bad idea for running past the stock rev limiter then?
this worries me cuz i just installed these guys and i autocross. sometimes on a quick straight i will stay in second and let the rev limiter bounce if there is a quick turn not to far but would be losing time if i go to third.
Old 11-06-2010, 12:54 PM   #486
If you're on your rev limiter, you are at around 6250. You can't run past the stock rev limiter.
Jason's pulley broke in two, completely destroyed. Pretty sure a pic got posted.
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 08:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 11:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 06:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 01:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 11:51 AM
