Old 08-25-2011, 12:24 PM   #1
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Is there a DIY for replacing an alternator?
I have a 2007 LB (as seen in my signature) and this morning I woke up to a battery that would not crank the engine. I knew it was coming but I was fooling myself into thinking it was going to "just get better". The last couple days I have been noticing a little less enthusiasm in my starter cranking over the engine. This morning it turned the engine a little and then a bunch of hurried clicks. I'm going to swing the batter by an autozone to test, but if its not the battery then I guess its the alternator. and was wondering if there was a DIY. I did a search and nothing came up, but I did find the service manual for it.
Old 08-25-2011, 01:12 PM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
If your battery is more than three years old, replace at the first signs of failure.
Old 08-25-2011, 01:14 PM   #3
Shinare
Shinare's Avatar
oh ok, I'll try that first.
Old 08-25-2011, 03:02 PM   #4
bronsin
bronsin's Avatar
Geez TEST the battery!
The one in my ECHO lasted 9 YEARS!
Old 08-29-2011, 06:52 PM   #5
Shinare
Shinare's Avatar
Just as an update, I brought the battery to Autozone, they tested and it failed. I purchased a "Duralast Gold" battery for $107 after being reassured that it would fit. It didn't fit in the bracket without prying down on the bracket on the battery itself but eventually it closed enough to allow me to tighten the nut enough to stay on. I hope it lasts. I could tell immediately with the first crank the difference in batteries, the other battery always sounded a little sluggish cranking the engine, now it sounds like the starter itself could propel me down the road at 30MPH. Zero hesitation.
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 01:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 02:25 PM
07 yaris bad alternator Yaris_guy DIY / Maintenance / Service 24 06-29-2011 12:47 PM
FS: 2009 Alternator & Overdrive Alt. Pulley MGargano Items for Sale by private party 9 10-28-2010 08:42 AM
