Old 07-08-2012, 07:57 PM   #1999
sqcomp
Roadrunner Jr.
sqcomp's Avatar
That proposed hole is VERY close to the glass...that's the challenge. Know that the hole is only the size of a tweeter. Can a right angle adaptor give enough torque to drive a hole saw?
The dremel idea may be the best at the moment.
:) whadyamean you can't angle a sawzall in there?!? :)
― Thomas Paine
Old 07-08-2012, 09:19 PM   #2000
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
well aslong as there is no glass directly behind you're proposed hole, drill a centered pilot hole, and the hole saw will stay perfectly on line.. Ive seen one drift when dont that way..
But i get the hesitation.. I guess the dremel probably is the way you would wanna go..
And if you do try the sawzall, please get it on video!!!! haha
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 07-09-2012, 12:11 AM   #2001
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Some thing like a hole saw mentioned above is what I had in mind, Yes a dremel may be the power tool, now because of the angle of the a-pillar the dremel will not be exactly perpendicular to the cut, I hope that would not be an issue.
I'll stop by tomorrow at the local store and see if I can find a hole saw that fits the size of the hole that I need.
Thanks
D.
CLA 250, 4MATIC
Old 07-09-2012, 03:45 AM   #2002
sqcomp
Roadrunner Jr.
sqcomp's Avatar
It's not the bit I'm concerned with in using a hole saw that close to the glass...
If you think a dremel is too big, a drill body is massive...one needs to get the hole saw bit straight on just like the dremel. Can you squeeze yourself into a good place on that dash to hit the pillar straight on with either option?
― Thomas Paine
Old 07-09-2012, 12:20 PM   #2003
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I hate drilling into metal...
― Thomas Paine
Old 07-09-2012, 11:23 PM   #2004
derickveliz2
Me too! I'm going to confirm that in a few minutes!
D.
CLA 250, 4MATIC
Old 07-10-2012, 02:06 AM   #2005
derickveliz2
I did it! I did it!
Video1:*It was so easy that I took my phone for a video!
Video 2: Without holding my cell phone for video I could probably have done it in less than half of the time..
D.
CLA 250, 4MATIC
Old 07-10-2012, 02:23 AM   #2006
derickveliz2
OK, this was so EASY, just like a hot knife on butter! best $15 bucks spent.
Now I have left tweeter as far forward and far to the left I possible can! I gain 5 inches and that's a lot! the distance from my left ear to tweeter now is 48" it used to be 43".
Stage is wider and deeper already!
Probably 5 inches sound meaningless, but you should hear the difference that it makes.
Picture 1: the a-pillar after cutting the metal
Picture 2: Tweeter in place! NICE! I'm happy.
D.
CLA 250, 4MATIC
Old 07-10-2012, 07:41 AM   #2007
sickpuppy1
Drives: 2010 Yaris Sedan
What about the aiming? Looks like its down at the dash....
Old 07-10-2012, 10:49 AM   #2008
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The aiming axis at that point will only have a minor effect. The gain Derick has from physical location is going to override the angle for the most part. What I'm going to be interested to see is how the mounting is integrated with the a pillar.
I see that mount is deep...really deep in there. What say you Derick? This may be a good experiment for horn loading...
― Thomas Paine
Old 07-10-2012, 10:52 AM   #2009
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Sand down those edges on that metal, run that wire...are you going to surround the mounting hole with some deadening to reduce resonances? How's the tweeter going to be mounted?
― Thomas Paine
Old 07-11-2012, 03:05 PM   #2010
derickveliz2
Yeah me too! I'm thinking about cutting a big section (hole) in the lower part of the a-pillar and build up a big open horn shape from the tweeter's base to the opening of the a-pillar, I'm not sure how to accomplish that, but I'll dig into it.
D.
Yes will deaden the area, I will use a thin sheet of wood/balsa wood or even MLV as baffle into the metal.
D.
CLA 250, 4MATIC
Old 07-11-2012, 09:48 PM   #2011
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Baffling into the metal...I wish I could be out there with you to help. I think between the two of us we could make this happen REALLY quickly.
*sigh*
Using some substrate you can drill into using the L1v2's mounting holes. I'm thinking even a 1/4" pan head would be fine and not kick too far into the metal depending on the thickness of the substrate.
I'd say make a couple rings out of balsa that are juuuuusssst slightly larger than the outer diameter of the tweeter and then reverse the technique we've used to make the original pillars. Build in instead of out.
Thoughts?
― Thomas Paine
Old 07-11-2012, 11:38 PM   #2012
derickveliz2
........and then reverse the technique we've used to make the original pillars. Build in instead of out.
Thoughts?
You read my mind!
D.
CLA 250, 4MATIC
Old 07-12-2012, 12:24 AM   #2013
sickpuppy1
Kind of a speaker mounted in a funnel. Interesting.....Hey, what about using a funnel! lol
Old 07-12-2012, 12:26 AM   #2014
sickpuppy1
By angleing the cut on the material you could still aim it a bit if needed. If nothing else it would be a cheap way to experiment.
Old 07-12-2012, 12:27 AM   #2015
sickpuppy1
Would it have a megaphone effect though if not treated or coated....
Old 07-12-2012, 12:32 AM   #2016
derickveliz2
Hilser Funnel in process... kind of!
pictures of the cut out section soon...
Hilser Funnel
D.
CLA 250, 4MATIC
