Old 11-11-2012, 09:32 PM   #1
burned
Drives: 1nzfe
1NZ-FE All Motor Build
As per request, I'm starting a thread on the N/A build were working on. I'll show you what were using and where we are on it.
We can discuss any and all things related. Input is welcome and so is your creativity. There are going to be unknowns but that is part of this build.
One thing that I'm not to interested in, is doing a bunch of stock comparison to all the mods with all this excess testing. What I will do is ensure all the parts are made to proper spec and that they all work together.
Remember I really don't build for the average bolt on guy. I like to build the best possible built combinatin of parts possible for the platform.
We go for broke or we don't go at all. Like I say, "Live to be Legendary"
So with no further to do. well start with the block.
Standard 1NZ-FE block. Complete internal polish (not sure why, Dustin wanted it that way) perhaps better oil flow? Not something I would of done but hey its his motor. Also sleeved by Golden Eagle.
78mm bore so now were at a 1.6L
compression will be 14:1
burned is offline   Reply With Quote
Old 11-11-2012, 09:51 PM   #2
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
shiny, not real sure why he would want it all polished on the inside perhaps with it having a smooth surface it ill be least likely for any oil to stay in the engine during oil changes.
Are you changing the stroke any?
Any idea what diameter header he will be using?
I am assuming with that much compression ratio that stronger head studs will be used and the pretty ITB you guys offer will utilized.
Old 11-11-2012, 09:59 PM   #3
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I've never seen any engine with the internals polished even motors designed for only racing. Smooth surfaces usually aren't conducive to flow of fluids and can cause puddling and beading. A easy example is to look at the bottom of a boat, they are generally coated with a semi rough material to help reduce friction. You want a semi rough surface its good for flow and fluid movement.
Old 11-11-2012, 10:05 PM   #4
burned
Drives: 1nzfe
We're doing two strokes. Currently we have a finished billet knife edged super light standard crank and are waiting on the 3mm stroked version.
Yes we will be doing our ITB set-up for sure.
As far as header, we are using my good friend John at LHT to do our long tube header for this motor. I'm not sure of the Dia. yet but John is a guru with that stuff. I'll find out what he has in mind and get with you on that. He's the same guy that did up my wrap around turbo manifold.
10mm ARP head studs and main bolts will be used.
below is a pic of the crank we have on hand. it's the stock diameter. Still waiting on the stroked one.
Old 11-11-2012, 10:07 PM   #5
burned
Drives: 1nzfe
At Xnamerxx, I agree.
But hey it's Dustins build and he's got the money to spend so well see what it does.
Old 11-11-2012, 10:27 PM   #6
burned
Drives: 1nzfe
We ended up with rods from Molar (oliver) and Arias pistons of course.
Old 11-11-2012, 10:36 PM   #7
xnamerxx
0-60 in slow
xnamerxx's Avatar
I doubt polishing the internals will make and difference to oil return, just giving an explanation about why polishing is normally bad. The only thought I had when I saw that was ,"you're going to put oil in there?".
Well I'm going to put my guess at 145~hp from the data I've seen of these engines, and a guesstimate from the big JUN cams.
Keep us posted.
Old 11-11-2012, 10:42 PM   #8
burned
Drives: 1nzfe
will do bro. I'm as curious as you. I know Dutin is hoping for 200-225.
ECU will be standalone, Fuel Tech 400 (FT400)
he wants to run nitro-methane for fuel but I'm not sure on that either.
I'll continue to post up as things progress or as things change.
Old 11-12-2012, 01:14 AM   #9
ljming99
Drives: Yaris '06
Simple ...2 words -
GOLF BALLS
ARE NOT SMOOTH
ljming99 is offline   Reply With Quote
Old 11-12-2012, 01:41 AM   #10
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I always enjoy your many thoroughly entertaining visits here, Aras.
And have noticed a recurring pattern...
There are always lots of photos of really finely made extremely high quality parts... but there is no evidence of those parts actually installed in a complete running engine. Seems like there is always the announcement of something coming just around the bend... but it never actually arrives. This makes for great showmanship, but after a while I've noticed that while there is lots of sizzle, there's no steak.
Now I'm certainly a total rank amateur at marketing, but even I have a clear video of my manifold in actual use in a running engine. I'd be embarrassed to post a blurry nonrecognizeable skip framed pixellated low resolution video because it makes such a poor first impression. I eagerly wanted to see your excellent work, and was disappointed at the poor quality of presentation. There was no way to tell what was going on or even to identify what engine was running. Why not simply wait until you can make a decent video which is of the same high quality as your work? Just a suggestion.
Greg
Old 11-12-2012, 03:26 AM   #11
burned
Drives: 1nzfe
Well Tooter, I think the blurry Mobile up-loads of the turbo motor are quite visible to that of which iv'e shown plenty of.
It was quick and on the fly. Which is why it is what it is. You can choose to believe or not to believe. But to say you cant see the motor in the car running, well; I don't think the mobile upload is that blurry.
Plenty of sizzle and lots of steak. Also atl least the parts I make are not retro fitted junk-yard designs with flange changes.
My turbo motor= proven and runs;while the mobile uploads are blurry it's quite obvious it works.
Old 11-12-2012, 11:02 AM   #12
tooter
play every day
tooter's Avatar
There is a difference. My business is doing something else, and I'm just playing around with junkyard parts as a hobby, while I'm assuming that you are doing what you do as a business.
Business is an artform.
It's a blank canvas on which each businessman paints a portrait that expresses the moral values by which they live.
Old 11-12-2012, 12:11 PM   #13
Tooter did a cool thing with that, even though it didn't make power. And he participates in this community, consistently.
Old 11-12-2012, 01:41 PM   #14
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Old 11-12-2012, 02:46 PM   #15
Golddeenoh
Golddeenoh's Avatar
easy man, tooter just wants a prettier video that truly shows how awesome 653ish hp is in an xB. no need to start dissing or anything. we all just want to see good quality videos to go with the information. and not evey one has a basically limit less budget so getting tooter's intake for a turbo build is a cheaper alternative even if it doesn't increase power it should last beyond the boots capabilities of the plastic stock intake.
Old 10-22-2014, 12:03 PM   #16
Gabwone
Drives: Echo RS 2004
what is your engine management ??
Gabwone is offline   Reply With Quote
Old 10-22-2014, 01:57 PM   #17
TommyYaris
Drives: 2009 Yaris
Gabwone, OP has been banned.
TommyYaris is offline   Reply With Quote
Old 10-23-2014, 06:05 AM   #18
IllusionX
Drives: 07 Yaris Sedan Aero
For the sake of it. Why was he banned? lol
2 sets 1nz fuel injectors for sale fnkngrv Items for Sale by private party 2 06-05-2012 05:35 PM
online car show for the 1NZ cars! cali yaris General Yaris / Vitz Discussion 8 08-03-2010 07:36 PM
manifold 1zz to 1NZ? Nets Performance Modifications 3 05-09-2010 12:22 PM
1NZ port & polish ChinoCharles Performance Modifications 75 06-01-2009 06:39 PM
Look at this 1nz Thej3sta2 Performance Modifications 33 03-19-2009 04:15 PM
