Old 11-04-2012, 11:51 PM   #1
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Compressor pulley end fell off!
While changing the oil on the Yaris today, I noticed something in the splash guard under the radiator: It was this above.
I figured out it was the end of the compressor pulley on the air conditioner. I read somewhere on here that there is no nut to hold it on. Rather, it just threads on and there is a special tool that you need to tighten it down. This tool fits into the holes on the wheel, then you torque it down.
Is this correct? Will any mechanic have this, or is it a Toyota-specific tool? I'd rather not bring it in if I don't have to, but I also need it fixed. I assume I shouldn't drive it without this piece on ....
Thoughts?
Old 11-05-2012, 06:49 AM   #2
There is another thread on here from yesterday with another person having the same thing happen. You can actually make your own tool with a piece of steel and two grade 8 bolts that will fit into the holes. Just take a piece of flat steel and drill two holes, spaced for two opposite holes in the pulley, and stick the bolts through (either tap the holes for the bolts or put nuts on the back side).
Old 11-05-2012, 11:49 AM   #3
Thirty-Nine
That's a good idea, Scott. I suppose there'd have to be a center nut to attach a wrench to to turn it.
Do you know the torque specs on that pulley nut cover thing I posted above?
Old 11-05-2012, 01:20 PM   #4
The service manual considers the compressor to be a one piece part, so there are no specs for the pulley.
Old 11-05-2012, 02:00 PM   #5
Thirty-Nine
Ah. Well I guess "tight enough" will have to do. Now I'll just have to make that tool.
Out of curiosity, the part that came off is designed to come off to replace the belt, correct? If so, does Toyota offer a proprietary tool for this piece?
Old 11-05-2012, 02:56 PM   #6
No. The belt can be replaced without removing the pulley. I am not sure if there is a SST, since Toyota just replaces the entire compressor.
Old 11-05-2012, 05:49 PM   #7
Thirty-Nine
Hmm ... I wonder if I could just put a nut on there instead of this plate? Is the plate a balancer of some sort?
Thoughts?
Old 11-05-2012, 08:48 PM   #8
Thoughts?
I really don't know. It might act as a bit of a flywheel for the compressor.
Old 11-14-2012, 10:52 AM   #9
Thirty-Nine
Well, I made a tool to put it back on. I basically made my own adjustable spanner wrench using two bolts that could be moved to fit into the holes. I then put a large bolt through the center of the metal bar and fastened it with a nut so I could turn it with a wrench. I used a bit of thread lock on it, and tightened it as best I could. I haven't tried it yet, but hopefully it'll hold.
Old 03-30-2023, 11:49 PM   #10
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Any updates? did the fix work? I have a similar situation myself.
Thanks!
jack black is offline   Reply With Quote
Old 11-19-2025, 10:51 AM   #11
09GLH
Drives: 2009 Yaris 5 door
Just replaced the headlights, and looked down and saw the same thing. No clue how long it's been down there, gotta be years. Time to build a tool like others mentioned. 294k on mine.
09GLH is offline   Reply With Quote
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 10:43 PM
Custom front end spdas Cosmetic Modifications (Exterior/Interior) 18 03-09-2011 06:56 PM
End of a decade? yaris-me Off-topic / Other Cars / Everything else Discussions 4 12-31-2009 12:12 PM
aftermarket front sway bar end links? jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-08-2009 11:26 PM
Review: Adjustable Sway Bar End Links m911gt Performance Modifications 9 04-29-2009 09:25 AM
