Old 11-05-2012, 11:49 AM   #3
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
There is another thread on here from yesterday with another person having the same thing happen. You can actually make your own tool with a piece of steel and two grade 8 bolts that will fit into the holes. Just take a piece of flat steel and drill two holes, spaced for two opposite holes in the pulley, and stick the bolts through (either tap the holes for the bolts or put nuts on the back side).
That's a good idea, Scott. I suppose there'd have to be a center nut to attach a wrench to to turn it.
Do you know the torque specs on that pulley nut cover thing I posted above?
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 10:43 PM
Custom front end spdas Cosmetic Modifications (Exterior/Interior) 18 03-09-2011 06:56 PM
End of a decade? yaris-me Off-topic / Other Cars / Everything else Discussions 4 12-31-2009 12:12 PM
aftermarket front sway bar end links? jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-08-2009 11:26 PM
Review: Adjustable Sway Bar End Links m911gt Performance Modifications 9 04-29-2009 09:25 AM
