My Face Is Ridiculous
Drives: 2010 Toyota Yaris 3dr LB Join Date: Dec 2011
Belt noise after MI pulley?
I've got some belt noise after doing the MI pulley. Not squeal, just an audible (windows down sitting in car) sound of the belt spinning around. Is this just a quality of the lighter pulley or should I have my belt checked again? I've never done a lightweight crank pulley before and wanted to make sure this wasn't normal before I started poking around.
I would check your belt tension but it shouldn't make more audible noise.
play every day
![]() ![]() ![]() Drives: 2012 Grey Toyota Yaris SE Join Date: Dec 2011
Can u record the video? Maybe Garm can confirm if its normal or not
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
Audible just means that it can be heard by human ears, so yes there are inaudible noises, and dogs can hear sounds we can not.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
^ My wife arguing with me, for example.
play every day
![]() My wife says I have selective hearing. Last edited by tooter; 11-20-2012 at 10:10 PM. |
apparently i have a some hearing difficult in my right ear, typically that is the side were my wife tends to be when she is asking me something and i get to look over at her while she gives me the stare of death while i have not the slightest clue as to what she said.
i will record some audio of it later. it's definitely audible though.
Form>Function
Are there any cracks in the belt? Time to replace?
This thread went from drive belt noise to ignoring complaining women lol |
play every day
My thought is that it could possibly be the anodized surface on which the belt runs which is relatively slippery compared to a raw aluminium surface. If it was me, I'd remove it, mask it off with some tape and beadblast just the belt grooves alone, although lately my solution to everything has been to blast it.
It's all speculation until an actual audio is made available. I don't believe captain is experiencing any noises associated with slippage, as those are very easily identifiable. Also, belt age should not be an issue since the car is only a 2010.
My thoughts, again speculation, is harmonic. The sound resonating from the MI pulley differs from OEM due to its aluminum vs cast construction. He is probably hearing a different 'whirring' sound.
Yeah, it's not slippage for sure. Just a different (but noticeably louder) sound at idle. I've got a Zoom H2 and will record and post it up later today.
I've attached the wav file inside of a zip file.
It's just a high-pitched sound as the belt revolves, kinda annoying. |
Hope Garm can help you with your problem captain! I want to install this pulley too :)
That really sounds like a loose belt to me.
How many ft lbs is it supposed to be?
| pulling the AC belt pulley on front of compressor | yaris9876 | DIY / Maintenance / Service | 6 | 07-19-2012 11:12 PM |
| Squeaky belt after pulley install? | Black_griffin6 | DIY / Maintenance / Service | 12 | 07-01-2012 11:17 AM |
| Belt noise? | Cutie Pie #2 | DIY / Maintenance / Service | 20 | 05-22-2009 02:51 PM |
| Water pump belt and pulley - replaced at 36,000mi | cleong | DIY / Maintenance / Service | 3 | 03-06-2009 01:12 AM |
| Underdrive Pulley Belt | ruimond | Performance Modifications | 11 | 02-14-2009 10:05 AM |
