Old 11-21-2012, 05:13 AM   #145
TrYaris
TrYaris's Avatar
Drives: Racin' yaris :D
Hey guys, What is the difference between 4-2-1 and 4-1, in performance I mean
TrYaris is offline   Reply With Quote
Old 11-21-2012, 11:23 AM   #146
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Depends on how they are designed, but if both are designed correctly there should be almost no difference.
Old 11-21-2012, 11:46 AM   #147
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
The 1NZ FE engine's firing order is 1-3-4-2.
A 4-2-1 tri Y header pairs up sequentially firing cylinders 2-1 and 3-4 so that the exhaust pulse from one helps to draw exhaust from the other.
Then the combined 2-1 and 3-4 pairs join to help scavange each other...
Practically speaking, the headers are too short to make a lot of difference.
But that's where namer comes in...
Old 11-21-2012, 01:08 PM   #148
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
The 4-1 is supposed to delay the power increase until higher in the powerband. The 4-2-1 is supposed to give a midrange bump. On our tiny cars you probably would never notice a difference. I love my DC header. Anytime I'm above 4k I'm just roaring and pulling hard for a yaris lol.
Old 11-21-2012, 01:20 PM   #149
tooter
play every day
tooter's Avatar
I actually did notice a difference...
...as I climb a steep 1/4 mile hill in 2nd gear to get to my house. It's always the same hill, so that's constant. And driving up it everyday I have a good feeling for the resistance. The header definitely helped the engine make it up the hill easier. If you start climbing under 2,000 rpm, the engine labors sluggishly. But anything over 2,000 and it gains rpms much easier and climbs more easily than the stock header which feels like it's holding back at the same rpms.
Old 11-21-2012, 01:36 PM   #150
^ An aftermarket header will certainly make a difference over stock, but I doubt you can feel any difference BETWEEN aftermarket headers. You just can't feel 1-2 horsepower, in my opinion.
Old 11-21-2012, 01:36 PM   #151
TRYaris is that your car in your avatar?
Old 11-21-2012, 02:32 PM   #152
xnamerxx
0-60 in slow
xnamerxx's Avatar
Basically what Cali said.
There is a maximum of about 12" to work with and an ideal length of about 35" so most of the ots headers compensate by increasing the volume of tube which in essence give some of the same effect as increasing length but reduces scavenging at lower rpms. Now this motor is relatively small displacement with a good torque management system going to a larger diameter tube won't hurt you as bad as it would on a larger engine.
So not wanting to give up anywhere in the powerband while still gaining some up top is the reason I decided to design and build my own header.
As far as header type is concerned both a 4-2-1 and a 4-1 will accomplish the same goal but each design has its own advantages but both of them can produce near the same power and torque so there isn't a real advantage to choosing either one aside from packaging constraints, and a 4-1 is simply easier to package with the effecting lengths required.
Old 11-21-2012, 03:05 PM   #153
TrYaris
TrYaris's Avatar
No it's not :P would be nice but I don't have that much money !
Old 11-21-2012, 04:01 PM   #154
1.5
Form>Function
1.5's Avatar
This
Tr that pic I think is sporting a MI Hood visor.
Old 12-01-2012, 10:20 PM   #155
TOLMACH
Drives: soarer
This is what I received yesterday
http://photo.qip.ru/users/tolmach/96608749/129617602/
Same part number but Dc logo seems to be on the fourth tube as compared to this one (stole this pic from someone here) - here logo is on the third tube
http://photo.qip.ru/users/tolmach/96608749/129617601/
have not tried installing it yet, but there seems to be enough space between the hole for the O2 sensor and top bracket
Overall build quality of mine is not very impressive (kinda very average) as compared to the WR one
Old 12-01-2012, 10:33 PM   #156
tooter
play every day
tooter's Avatar
That's one thing I really like about the Weapon R. It's precise. You could cut your finger on that sharp knife edge where the two main tubes are joined...
But as far as performance, it doesn't matter.
Old 12-01-2012, 11:20 PM   #157
xnamerxx
0-60 in slow
xnamerxx's Avatar
That's not a good thing, air doesn't like sharp edges.
Old 12-01-2012, 11:56 PM   #158
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I don't think it would make that much of a difference in our case either way.
Any aftermarket header should prove to be at least slightly better than stock, right?
Old 12-02-2012, 12:07 AM   #159
xnamerxx
0-60 in slow
xnamerxx's Avatar
the slight knock it causes in flow won't make much of a difference.
Old 12-02-2012, 01:49 AM   #160
tooter
play every day
tooter's Avatar
... especially when its just a trailing edge with alternating pulses coming through each runner.
Old 12-02-2012, 02:41 PM   #161
TOLMACH
Drives: soarer
Mine looks nothing like this inside (build quality wise) ((
Hopefully, will still do its job
Old 12-02-2012, 02:55 PM   #162
xnamerxx
0-60 in slow
xnamerxx's Avatar
I wouldn't worry, all of the aftermarket headers lack a ventur,i so the collector looking bad wol make almost no difference.
