Old 01-21-2014, 04:24 PM   #1
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
Cool Belly Pan / Under Carriage Cover anyone ?
Having worked on many models, and of course the changing times, you see differences. Like the Prius and it's mileage gains (as well as other models and makes).
-You see the feather light rims.
-You see the headlamp (where it meets bumper) is tucked under the bumper at the front
You see underpinnings/belly pan/undercarriage covers, especially on the Prius and Fusions, as well as others. (my 10 has small beginnings of what the Prius has)
Of course the aero body isn't the only thing saving fuel, it's the other tech stuff too like direct injection with no fuel return in a sealed environment, tighter and more gears, and so on.
----Has anyone found belly pans on the newer Yarii ?
----Has anyone made one up or used one from another vehicle that would fit from the Yota family ?
Just curious, but I think that would help squeak some more miles per gallon out on the highway.
Body gap trim would be another idea, but I would think a belly pan that is usable, and wouldn't over heat the engine or trans would be a good thing for mileage.
Thoughts ?
Old 01-21-2014, 04:57 PM   #2
Thoughts ?
Micro Image used to sell one that went from the bumper to the subframe (almost identical to the one made by C One, but easier to take on and off). Below is a link to the thread on it. There is also a thread on the Micro Image forum on a rear one that someone fabricated (and added a rear diffuser to).
Sitting under mine while they are on the lift I strongly believe that the Yaris would benefit from as much underpanel as one could possibly add.
http://www.yarisworld.com/forums/sho...ght=underpanel
Old 01-21-2014, 05:06 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I have the MI one and it's great. It keeps the engine bay cleaner for longer. I also got it because I wanted to prevent the car from wobbling so much on the highway. I'd like to think that it worked, but I can't say for sure since I added a rear sway bar at the same time.
Old 01-21-2014, 06:12 PM   #4
RJay
Drives: 2002 Toyota Yaris T-sport
That MI one looks very, very interesting. I'm going to keep that idea in mind if you please.
198X BMW E30 modified race car
1975 Ibanez "Les Paul custom"
RJay is offline   Reply With Quote
Old 01-21-2014, 10:12 PM   #5
dragoonmc
Drives: 07 hatchback
Micro Image no longer sells theirs.
dragoonmc is offline   Reply With Quote
Old 01-22-2014, 07:56 AM   #6
JimKellyfan
The alum. looks nice. I wonder on the weight it adds, as well as does the engine optimum temp change and the fan runs more or no ?
Old 01-22-2014, 12:30 PM   #7
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Not heavy at all. Engine temps are fine since there's still enough air flowing through.
It's one of those mods that complement the car really well.
Old 01-22-2014, 12:37 PM   #8
I really should have bought a couple while Micro Image was selling them. I am in the process now of fabricating one myself for one of my cars which is missing the OEM plastic pieces. If it comes out good, then I will make two more for my other two streetable Yaris.
Old 01-22-2014, 12:45 PM   #9
We are talking to the fabricator about making more sets of these. Stay tuned. There's a thread on our forums about it.
Old 01-22-2014, 01:14 PM   #10
RJay
I want it for my BMW :) With a splitter up front. So I'd have to design it myself anyway.
@ M-I / Cali Yaris: Do you ship them to Europe as well for a p1?
Old 01-22-2014, 01:20 PM   #11
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
^This. Do want.
Old 01-22-2014, 07:49 PM   #12
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
I was thinking of making one that extended to the bottom edge of the bumper to protect it from driveway scrapes. I can care less about my stock bumper now, but when I ever do get a JDM one imported.
Check out my Build thread:
Old 01-23-2014, 03:18 PM   #13
Yaristeve
Drives: 3-door hatch
Those MI panels look really nice. But, would it be possible to modify it by installing little access doors (for oil filter and drain) instead of having to remove it completely (even though removal of the panel is made easier with the Dzus fasteners)?
Old 01-24-2014, 04:54 PM   #14
Astroman
Modded Moderator
Astroman's Avatar
I looked and couldn't find the thread. I am interested in one as my plastic one is gone and I hated it anyway.
Old 01-24-2014, 07:50 PM   #15
CrankyOldMan
It's been dormant since mid-December. I added a post the other day. http://microimageonline.com/forums/s...TB-Under-panel
Old 01-26-2014, 11:48 AM   #16
If you had one, you're welcome to cut a door and add hinges and a latch. From my side, that added to much cost to the part.
Old 01-26-2014, 02:04 PM   #17
tk-421
tk-421's Avatar
Drives: 5D-07-LB
... not to mention, more moving parts = bigger possibility for failure. It might be a better idea to simply cut the hole and skip on the latch/hinges.
Old 01-28-2014, 12:41 PM   #18
Yaristeve
OIC. More a cost issue (nothing wrong with that) than a structural issue. Thanks.
FS Palmdale,CA: Floor mats, windshield washer, hubcaps, vvti cover, hatch container AGlobalThreat Items for Sale by private party 15 08-19-2013 01:34 PM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 04:30 PM
DIY Tow-Hook Cover Plate Mod Yarisduder DIY / Maintenance / Service 4 05-30-2010 12:51 AM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 06:55 PM
