#289 |
![]() ![]() ![]() ![]() Drives: 2011 Toyota Yaris Join Date: Feb 2013
I believe they are 6k in the front and 3k in the rear. Much too soft in my opinion. I will be ordering short/stiffer springs for the rear soon. The fronts can go pretty low on the Megan coils, but I'm only on the springs in the rear, took off the locks/perches already. Still not as low as I want to go though. If I were to do everything over again, I would have been a little more patient, saved another $150 or so and bought BC extreme low coilovers. You should get coils though, sedans look dope slammed.
#290 | |
I already have on lotek springs on it and it's about a 1.9 drop I love the back of my car, the front... not so much |
#291 |
Still not low enough for my though haha
#292 | |
![]() ![]() ![]() Drives: 2011 Yaris RS 5 door 5 spd Join Date: Aug 2012
![]() TRD sway bar, h&r coilovers, tanabe strut tower bar, konig feather, bfg sport comp 2, MI intake manifold, aem cai, dc header, trd catback, MI crank pulley, trd short shift kit, phillips hid kit, morimoto led fogs, parrot navi indash, alpine 6.5 speakers, alpine amp, alpine reverse camera, led interior lights, thule roof racks, netz badges... |
#293 |
Oh sorry the way I typed it made it seem like I only got the front coilovers haha. I have the full coil overs, front and rear. But, the rear coils didn't go as low as I'd like to. As I'm sure you know the rear spring is independent from the shock. That's why I said I'm only on the springs in the rear cause I took off the locks/perches that came with the coils to get the maximum drop. I want to get shorter/stiffer springs though so I can put the locks and perches back on to be able to adjust my height as I please again. Plus, it looks like you have bigger rims so that should fill the gap nicely if you feel like the Megans don't have a low enough drop for you.
#294 |
@aspro - Thanks a lot man!
#295 | |
![]() ![]() Drives: CS1 Join Date: Mar 2013
#296 | |
#297 |
Got the crew banner on! #Sus_Spec Okay, no more new posts from me until I get my wheels mounted ;)
20140919_185035 by TerenceJCruz92, on Flickr
#298 |
Does anyone know the diameter of the rear springs on Megan Racing coilovers? I found some shorter, stiffer springs for my rear, just want to make sure it'll fit. I know our springs are independent from the shocks, but still lol
#299 |
65mm inner diameter should be the standard. I have 6in 8k springs all around.
#300 |
Hey guys, it's been a while since I've updated this. Just doing more research and saving money before I do any more mods. These are a couple of items I am looking for in order to finally put my wheels on:
1) -3 OR -5 camber shims from RealCamber. I don't know which yet, if -3 is enough to fit some 16x8.5 +25 offset wheels wrapped in 195/45s I would rather stick with that so I don't burn through tires as fast. 2) 6" 10k springs for the front, and 5" 8k springs for the rear for my Megan Racing coilovers. Want to add stiffer and shorter springs so I can go lower and get tighter fitment. I am paypal ready, please comment below if you have any of these items! Thank you very much. Also, just wondering, do any of you guys know which lug nuts I'd need to buy to work with some BBS RS reps? Preferably with a lock. (I know they're reps, but I still don't want to worry about them getting stolen. Haha) Thanks everyone! - Terence Last edited by TerenceCruz; 11-26-2014 at 04:14 AM. |
#301 |
just get some gorilla lock nuts. either ones with 1 lock nut, or all 4 lock nuts, or just basic type where a socket adapter is needed to remove.
As for springs, there is a diminishing return on getting stiffer springs as it relates to ride height. Did you already calculate the drop with those spring specs?
#302 | |
#303 |
cool sounds like you did your math. I just mean that the stiffer you go obviously the less compression you get given a fixed amount of weight (3 passengers in the rear). But the difference between say 9k and 12k is smaller than 6k and 9k. etc etc, you wont see much of a compression difference but your butt will sure feel it. 8k all around feels jolting in SF streets, and i run full soft on the shocks/struts.
At the extreme end of the spectrum of spring rate, a solid unmoveable spring = cinder block as your spring, you wouldnt get any compression, and your car will bounce everywhere. Try and find a spring height that will accomadate your drop, vs using spring rate. Of course making sure short springs will work with your shocks / struts to make sure they dont bottom out.
#304 | |
#305 |
![]() ![]() ![]() ![]() Drives: 08 BB LB Join Date: Dec 2008
http://www.racingsprings.com/2.5-ID-Coil-Over/Store/15
All the springs I'm running on my Megans i got from ^^this^^ site. I've got 6" 9k in front and 4" 7k in the rear no issues with fitment, and my ride quality isn't that bad.
Too much of car culture is people taking things too seriously and not enjoying it for what it is. |
#306 | |
| 2010 Vitz RS Modellista Completed Car | Vitz Rs Modellista | Photo-Video-Media Gallery | 38 | 11-18-2014 01:25 PM |
| 2012 Vitz from the 2011 Tokyo Auto Salon | CTScott | Third Gen Yaris General Discussion | 14 | 02-10-2011 09:06 AM |
| Is UA-NCP13 1.5L Manual Trans a Vitz RS? | WesSunday | General Yaris / Vitz Discussion | 1 | 11-28-2010 11:47 AM |
| Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 01:57 PM |
| A German Yaris/Vitz/Echo ;) | we-to-11 | Photo-Video-Media Gallery | 5 | 06-27-2007 09:26 PM |
