Old 05-26-2015, 05:12 PM   #1
MedMantle
MedMantle's Avatar
Drives: Yaris '05 1.3 Hatch "R.I.P."
Unhappy OEM Electric Window install problem
Hey guys, I have managed to completely install all 4 OEM electric windows but my car didn't have the connectors in front. So I made my own harness to connect my driver doors wiring to the passengers door wiring.
I'm left with one problem though.. I can open and close all my windows from my Drivers switch panel but none of the passenger switches do anything? I tested them and they definitely aren't faulty.
The only wire I am suspecting of being wrong is the blue wire in the middle of the window switch connectors.. When I was working it out I was pretty sure that it was supposed to go to Ground(-)...
Please save my day
MedMantle is offline   Reply With Quote
Old 05-26-2015, 07:19 PM   #2
What year was your Yaris built?
Old 05-27-2015, 02:15 AM   #3
MedMantle
MedMantle's Avatar
It was built in Dec 2005, so probably 2006 **
Old 05-27-2015, 05:10 AM   #4
OK. The connector wiring doesn't match any USDM or European market Yaris wiring diagrams that I have. What is the actual model number for the car?
Old 05-27-2015, 11:29 AM   #5
MedMantle
MedMantle's Avatar
Hey, I just remembered! The wiring came from a newer Yaris than mine, I think 2007, but that shouldn't be a problem?
Model No: NCP90R-AHMRKQ-92R
VIN (just in case) : JTDKW923X05000819
Thanks for checking it out :D
Old 06-03-2015, 12:43 PM   #6
MedMantle
MedMantle's Avatar
Okay, so after fiddling a bit with a tester I discovered that the common "blue" wire which is in the middle of all the passenger door switches must go to the permanent 12v terminal in the fuse box. That is where my driver side switch also gets its power from after being activated by a relay. Quick and simple fix.
I thought the driver side switch sends 12v to the passenger switches, that's why when I had the "blue" wire left which I was unsure of I presumed it was for "grounding".
Stoked to have my OEM Electric window motors, door panels and switches all wired up and 100% working. All for $250 if I thumb-suck the currency conversion! :P
I'm glad I saw your picture showing where the Permanent 12v supply is in the Fuse Box CTScott. Made life that much easier :D
DIY: Colibri Power Window Install Taiyaki DIY / Maintenance / Service 15 04-28-2016 09:03 PM
Help: Rear Door Small Window Install nick.dollimount DIY / Maintenance / Service 7 09-22-2010 02:22 PM
Driver Window Weatherstrip problem? michaelhay General Yaris / Vitz Discussion 8 04-26-2010 08:14 PM
[REQUEST] Removing Front Bumper + Faulty Electric Window '04 Yaris lufcfan DIY / Maintenance / Service 0 03-03-2010 06:29 PM
Help: Rear Door Small Window Install nick.dollimount DIY / Maintenance / Service 0 07-31-2009 08:40 AM
