![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
Squeak sound Where to Lube Anyone !!
Hi
https://sendvid.com/sk4sl0fg Please see video above can anyone help where to lube I have put some white li grease on the pushrod but it is still. Please help |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
If the squeak is from that area and you have lubed the end of the pushrod, you are probably looking at the clutch-fork-pivot or possibly the pressure-plate itself. If you are lucky you may be able to move the slave cylinder out of the way, pull the rubber boot off, and pull the clutch fork towards where the slave was. If you gently pull on it that way, it should make a gap between the fork and the pivot to maybe get some grease on. Don't pull too hard because it may pop the retainer off and you may need to r&r the trans at that point.
It may not work. It's not ideal. You don't want to get grease on your clutch, but it may shut it up. |
Thanks I sorted that inside the boot.
But now it is coming from clutch pedal which I put the grease on pushrod side and it disappear for 2 days. Is there any other locations I need to put some other grease or something. Clutch is working fine its just annoying pedal creaking noise. |
| New brakes, squeak sound at front brakes | Vesper | DIY / Maintenance / Service | 3 | 09-09-2016 03:02 PM |
| 2007 hatchback making a weird whirring sound | robkay | DIY / Maintenance / Service | 20 | 03-19-2016 06:53 PM |
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 05:35 PM |
| 2008 Yaris sedan ‘S’ sound deadening project. | Herbicidal | In Car Entertainment + Electronics (audio / video / alarm) | 155 | 09-04-2011 11:56 PM |
| New Sound System - Sound Issues | click.mine | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 03-20-2009 03:11 AM |
