Old 06-01-2022, 06:10 PM   #1
nesagwa
Drives: 2007 Yaris Hatchback (US, MT)
Question Question about cluster swap in progress
Hey all,
I'm in the process of swapping out the stock cluster on my 2007 manual Hatchback (US) with a 06-07 Hatch Canadian version. (link to ebay for reference: https://www.ebay.com/itm/175232190217)
I swapped the core board as suggested by this video: https://www.youtube.com/watch?v=lC-V3hV0-2w
When turning the car on, the tach and speedo don't move and the lcd is blank, but my brakes, seatbelt, blinkers etc. all seem to work fine.
Am I missing a step or make a mistake in the process?
nesagwa is offline   Reply With Quote
Old 06-01-2022, 07:33 PM   #2
nesagwa
Well, switched the core back and made sure the pins on the pcb were connected to the gauges. Now the tach works, but nothing from the speedometer.
File Type: jpg 284199235_550154859901278_186653003341181678_n.jpg (127.7 KB, 81 views)
Old 06-01-2022, 08:09 PM   #3
nesagwa
I think I may have made a mistake and bought an ABS cluster, and I'm pretty sure my car doesn't have ABS.
EDIT: Swapped the original cluster back in and the speedo doesn't work on it now. I've either messed up one of the wires on the harness or my speed sensor has failed.
EDIT 2: Spoke too soon, went for a drive with the Canadian unit installed and the speedo started working fine. Guess it just needed a warm up.
Old 06-03-2022, 03:04 PM   #4
sh0rtlife
the brain needed to re-learn what it was attached to, its kinda common for ALOT of parts on new cars to need to do that
Old 06-07-2022, 09:50 PM   #5
nesagwa
That's what I figured, it's working now so its all good.
Sat and swapped out the bulbs on the climate control knobs today and now everything matches a bit better.
File Type: jpg 285589520_506305021274808_1189629000809211214_n.jpg (90.2 KB, 66 views)
Old 06-13-2022, 08:39 PM   #6
remcafee
it looks like one of the cluster lovating tabs on the dash is broken, the cluster isnt sitting up in the correct position, happened to me too, i used a paper clip and drilled 2 small holes and shaped a new little tab
Old 06-14-2022, 07:46 PM   #7
sh0rtlife
FWIW its abs plastic so you can just get some pipe glue and ABS sheet from a plastic shop or hobby shop and re-work the tab with ease
Old 06-22-2022, 08:00 PM   #8
nesagwa
It's been bugging me so I will either drill and put a support or do the ABS glue route soon.
Tags
cluster, swap
After Engine Swap Downstream O2 Sensor Question 06YarisRS Performance Modifications 10 12-23-2018 12:16 AM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 09:12 PM
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 09:02 AM
Do you really need the 1nzfe cluster when doing a swap? longlivekel DIY / Maintenance / Service 5 01-01-2014 07:22 PM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 11:22 AM
