Old 06-13-2022, 07:39 PM   #6
remcafee
it looks like one of the cluster lovating tabs on the dash is broken, the cluster isnt sitting up in the correct position, happened to me too, i used a paper clip and drilled 2 small holes and shaped a new little tab
Tags
cluster, swap
After Engine Swap Downstream O2 Sensor Question 06YarisRS Performance Modifications 10 12-22-2018 11:16 PM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 08:12 PM
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 08:02 AM
Do you really need the 1nzfe cluster when doing a swap? longlivekel DIY / Maintenance / Service 5 01-01-2014 06:22 PM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 10:22 AM
