Old 12-09-2006, 03:47 PM   #19
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
I have a battery mount grounding kit available
Made from 8 awg high quality power/ground cable, with gold ring terminals. Wires are transparent black and are complete/made to fit. The gold ring terminals are made by Monster.
Kit comes with everything needed to install the kit including the ground plate and mounting hardware, bolts to attach wires to ground points etc.
$21 each to US or Canada, shipping is included.
Battery mount kit
07WYarisRS is offline
Old 12-12-2006, 09:47 PM   #20
skc
skc's Avatar
Drives: White5drRS
finally got my ground kit today.
i'm going to install it tomorrow.
Thx 07WYarisRS
skc is offline
Old 03-15-2007, 03:01 PM   #21
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
Does it matter if u get both? or just 1?
-- Blen
Blenjar is offline
Old 03-18-2007, 09:48 PM   #22
Blenjar
Blenjar's Avatar
-- Blen
Blenjar is offline
Old 03-18-2007, 09:54 PM   #23
Black Yaris
der Zeck
Black Yaris's Avatar
What are you talkin about Blen?
Black Yaris is offline
Old 03-18-2007, 09:56 PM   #24
Blenjar
Blenjar's Avatar
Installing both:
battery mount ground plate kit
firewall mount ground plate kit
-- Blen
Blenjar is offline
Old 05-02-2007, 12:04 AM   #25
d4w1
Drives: Yaris Hatchback
What I recommend, is that anyplace where a grounding point is attached. Is to make sure the bonding point has no type of insulation between the surface area where the ground is to be connected. To do this correctly, 1st, remove any paint and corrosion at the hole of attachment. Burnish the area with a small high speed round wire brush. The brush center guide pin should be the same diameter of the hole. The brush itself should only remove paint around the area where the bolt head or nut and terminal lead makes contact with the metal surface. For the best results these small wire brushes can be attached to any drill, air or electric. 2nd, Clean and treat the point where the bond is to be made. 3rd, Attach the ground lead with the proper size hardware. 4th, Test your bond with a mulitmeter, you should have very little ohm resistance reading on your meter. 5th, Touch up any bare metal surface with paint.
d4w1 is offline
Old 05-05-2007, 01:20 AM   #26
joey1320
joey1320's Avatar
Drives: Yaris LB
-- Blen
theres no reason to need both. one is more than enough. nice kits by the way
joey1320 is offline
Old 05-15-2007, 10:36 PM   #27
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Heya, I dont wanna start a new topic on this.........
Im thinking of gettin a voltage stabilizer aswell as some grouding wire........
is a voltage stabilizer worth gettin to help with the grounding wires?...bleh
hasher22 is offline
Old 05-29-2007, 10:25 PM   #28
Jerkratt
Jerkratt's Avatar
iw as wondering that to
Jerkratt is offline
Old 05-30-2007, 03:27 AM   #29
sort_o_sane
Yaris GSR LOL
sort_o_sane's Avatar
Drives: 07 Yaris Hatch
Since I don't know, What is the purpose of these grounding kits?
07 Yaris hatchback purchased in Dec '06. April 2015 and 103k miles, brakes finally needed changing, original battery finally died. I love this car.
sort_o_sane is offline
Old 05-30-2007, 06:55 AM   #30
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
They prevent premature hair loss.
Violin is offline
Old 05-30-2007, 03:11 PM   #31
sort_o_sane
Yaris GSR LOL
I could have used that a couple years ago.
Old 05-30-2007, 04:52 PM   #32
Jerkratt
Jerkratt's Avatar
lol
Jerkratt is offline
Old 06-02-2007, 01:12 PM   #33
Jerkratt
Jerkratt's Avatar
hey let me know when u gat a firewall mounting one up ill get it
"It hurts more when its wet"
Jerkratt is offline
Old 06-05-2007, 04:07 PM   #34
R0ME0
Drives: '00 Toyota Celica GTS Turbo
Do you offer different colors?
R0ME0 is offline
Old 06-05-2007, 05:26 PM   #35
tk-421
tk-421's Avatar
Drives: 5D-07-LB
+1 with shipping to Mexico City pls
tk-421 is offline
Old 07-01-2007, 05:19 PM   #36
Jerkratt
Jerkratt's Avatar
he has not been on since the begining of april... maybe he forgot about us?? lol i really want the firewall mounted one
Jerkratt is offline
u.s. model body kits? delirium Cosmetic Modifications (Exterior/Interior) 27 09-07-2007 02:15 PM
Yaris Body Kits???? SamSam Cosmetic Modifications (Exterior/Interior) 23 01-15-2007 03:38 PM
GROUNDING KIT DIY? SEaton DIY / Maintenance / Service 73 10-22-2006 04:03 PM
Any lip kits out yet? Spades Cosmetic Modifications (Exterior/Interior) 2 10-10-2006 03:28 AM
using regular power lock kits with cable style twixt DIY / Maintenance / Service 4 08-12-2006 01:18 PM
