Old 10-29-2008, 11:56 PM   #19
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
My interpretation of your 'rough ride' statement.
well my ROUGH RIDE consists of the everyday potholes and uneven road surfaces.. in certain areas where i cannot avoid them i didn't hear some of the familar sounds im use to associated with my current suspension and wheel/tire combo.
Old 10-29-2008, 11:57 PM   #20
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Originally Posted by largeorangefont View Post
That upper bar works a bit, in hatchbacks, but you can't have anyone in the back seat so that kinda sucks.
The lower bar on top of the shocks is worth the money you can get for it at the recycling center. It does even less than the front strut bar, and just adds weight and cuts down on cargo space.
To Rockland,
You are implying that the bar made the car is "stiffer" and "ride better" all at the same time? Not that I think you are in any position to quantify handling gains.. but thanks for your opinion. I think if I gave you a battery tie down brace you would say the car handled better.
You mean those billet battery tie down braces don't improve handling
Old 10-30-2008, 12:00 AM   #21
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Originally Posted by Gideon View Post
So just get this an a sway bar and you'll be set? (Thinking about getting one myself along with a sway bar. :P)
I would get a rear sway bar, and the front lower subframe brace. Braces in that area are actually effective. If you don't have a sway bar, definately get one before spending ANY money on braces.
Old 10-30-2008, 12:02 AM   #22
largeorangefont
Break'em off some.
Originally Posted by ROCKLAND TOYOTA View Post
this man i guess has no clue to my suspension setup oh well another brillant answer from the other side.......
Then enlighten us all as to how the bar made your car stiffer (which you have no way of quantifing) and ride better all at the same time.
I don't need to know your suspension setup to ask you a question about you own comments in post #1.
Old 10-30-2008, 12:03 AM   #23
largeorangefont
Break'em off some.
They do. Ask Rockland
Old 10-30-2008, 01:29 AM   #24
Too bad us sedan owners don't have anything like that, at least I'm not aware of anything for the rear other than a bottom sway bar.
Old 10-30-2008, 02:23 AM   #25
reggaetonfreak
El Yoe
reggaetonfreak's Avatar
Drives: Yaris Hatchback
mmmm, let me think, so unless I a dont plan on doing anything in the back of my car for the rest of its life, (if you know what i mean), mmm, yeah, thats a negative, it would have a purpose if you do auto x, m just saying!
Cuban to the bone, sitting in a Yaris, ahi si hay!!...
reggaetonfreak is offline   Reply With Quote
Old 10-30-2008, 11:06 AM   #26
He simply made an observation, that's all. Even if his words were not the correct ones to describe the feeling, which I'm not saying they are wrong, he still noticed a difference in the way the car reacts. Do you need Loren to back you up on this to justify and say I'm wrong?
Old 10-30-2008, 11:19 AM   #27
ROCKLAND TOYOTA
TRIM HUNTER
^^ its whatever, we'll let this ass paper think how he wants. it makes for good reading.....
Old 10-30-2008, 11:53 AM   #28
Astroman
Modded Moderator
Astroman's Avatar
Yay, I knew they'd chime in! Where's Loren?
I know the "effect" that Rockland is trying to explain. After installing the TRD rear sway bar the ride was was more comfortable while the handling was better as well. Since I have not tried this brace I don't feel that I am qualified to judge it's effectiveness. Same goes to everyone else. It's like saying you know everything about a movie when you've only seen the trailer.
Old 10-30-2008, 12:45 PM   #29
largeorangefont
Break'em off some.
The reason the car felt better was because his wallet was lighter.
Old 10-30-2008, 01:55 PM   #30
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Rockland noticed a difference and he claimed that the car was smoother. If you have basic knowledge of suspension you'll find that it is counterintuitive that stiffening the chassis brings a smoother ride, because road vibration and shock are more clearly transmitted through a rigid chassis.
Unless, of course, that the chassis is so flexy that it flexes more than the suspension does. Bracing this flexy chassis would force the suspension to work.
Given our experience with the Yaris LB this would hardly be the case - to me, the monocoque is stiff enough as it is (but this is subjective). So it is unlikely that you actually gain a smoother ride with the body bracing.
I would love to hear any theory on how a stiffer chassis creates a smoother ride.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 10-30-2008, 02:33 PM   #31
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
I like the bar.
Seems easy to install and remove and cheap enough to have it as an accesory for autox or track days only. When you are not carrying the rear seats anyways.
Old 10-30-2008, 02:39 PM   #32
largeorangefont
Break'em off some.
Agreed. This car has to be very stiff to begin with to make safety standards.
Old 10-30-2008, 04:14 PM   #33
ROCKLAND TOYOTA
TRIM HUNTER
so for my lack of describing better the change i experienced we have this. keep it going it makes for interesting read......
Old 10-30-2008, 04:48 PM   #34
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Hey, if you like it that's all that matters.
It's a shame there's no way to really verify whether or not they do stiffen the chassis other than the ol' butt dyno ... er ... "butt skidpad." (Ewww?)
Old 10-30-2008, 04:49 PM   #35
Mythbusters! Do it, do it now! lol
Old 10-30-2008, 10:33 PM   #36
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Bolt on braces, always guaranteed to start an argument.
(I prefer welded in ones myself.)
rob323 is offline   Reply With Quote
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 10:26 PM
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 07:04 PM
My Newest Exterior Mod fallensoldier1986 Cosmetic Modifications (Exterior/Interior) 22 05-08-2007 12:15 PM
newest mod!! turboyaris Performance Modifications 21 04-14-2007 05:51 PM
Torque Settings, front suspension Nimble Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-21-2007 02:00 PM
