Old 08-20-2006, 04:50 PM   #1
SamDaYarisMan
SamDaYarisMan's Avatar
Drives: meteorite liftback
MAINTENANCE REQUIRED!!!
Hey guys i got in my car today and the maintenance required light flashed about 10 times when i started up my car. I'm just wondering if something is wrong or if it's time for the first oil change. The odometer is a lil over 4500. I changed the oil at 3000 but i know toyota recommends every 5000. Is this just a reminder for the 5000 mile oil change? Thanks.
YARIS LIFTBACK: meteorite metallic, 5speed, debadged, 15" black rota gt-3's w/ 205/50/15's, tanabe df210's, colibri universal power window kit, glow shift 2" tach and twm shortshifter.
FUTURE MOD's: power door lock kit w/ keyless entry and new audio.
SamDaYarisMan is offline   Reply With Quote
Old 08-20-2006, 05:11 PM   #2
MacMaster761
Five-Star General
Drives: 07 Silver Streak Mica
Send a message via AIM to MacMaster761
look in your manual, there is a way to disable the light manually if you know that you dont need the oil change.
JWU '09 Baking and Pastry
MacMaster761 is offline   Reply With Quote
Old 08-20-2006, 06:19 PM   #3
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
Did the Yaris have a light especially to recall engine regular maintenance? Cause in my 2002 Echo, there's only one light and it's a "Service Engine Soon" light (Check Engine). And flashing "check engine" light is indicating a cylinder misfire problem.
I have this problem on my Echo because I have a cracked ignition coil on cylinder #2. I had to replace it cause the Echo is out of warranty (105,000 KM now). But part cost only 50$ and I replace it myself in 5 minutes.
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 08-21-2006, 09:51 AM   #4
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
It starts flashing on startup at 4,500 miles to let you know an oil change is coming up. It stays on after 5,000 miles. I think it's a great feature.
To reset - with the odometer in "Trip A" mode turn the ignition off - hold down the trip odometer reset button and turn the key to the "on" position (not start) - keep the reset button depressed for at least 5 seconds - you'll see several little dashes counting down and disapearing then all zeros display indicating it is reset. You're done.
(The manual says it's not in Canadian versions.)
Old 08-21-2006, 10:07 PM   #5
SamDaYarisMan
Thanks a bunch violin!! thought something was wrong with my car.
Old 08-21-2006, 10:17 PM   #6
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Look on the back of your thick manuals guys... its the first "quick note" listed.
Old 08-21-2006, 11:30 PM   #7
johnnyfive
johnnyfive's Avatar
was flashing check engine light at me for a couple days now, and just tonite i was driving, and BAM, hit 5k miles, and maintnance req. light comes on :)
was afraid i was going to have to get out the manual, but no need now, thanks :)
johnnyfive is offline   Reply With Quote
Old 09-19-2006, 04:07 PM   #8
Racer X-8
Races Little Red Wagons
Racer X-8's Avatar
Drives: red '07 Yaris liftback auto.
Thanks Violin.
Racer X-8 is offline   Reply With Quote
Old 10-09-2006, 10:50 PM   #9
Buckethead
Sweet, mon frer!!!
I'm at 4630 right now. My car will not get its first oil change before 6000 miles.
Buckethead is offline   Reply With Quote
Old 10-10-2006, 08:38 AM   #10
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
at 12000 it start blinking again
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Old 10-10-2006, 12:00 PM   #11
xfatefailsx07
Lean Wit It. Rock Wit It.
xfatefailsx07's Avatar
Drives: 2007 Yaris Sedan - 5 Speed
hehe chris always gets frustrated when people dont read their owners manuals..
YARIS... enough said!
xfatefailsx07 is offline   Reply With Quote
Old 10-10-2006, 01:13 PM   #12
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Yeap, also in European versions...Dammit!
Old 10-10-2006, 06:42 PM   #13
Chris07LB
Chris07LB's Avatar
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
