Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 12-14-2008, 10:54 PM   #1
richardholdener
Drives: 2008 Yaris hatch
TS/Xd Long Tube Header & Intake dyno results
Here are the dyno results of the new long-tube header for the 1.8L Taris TS and Scion Xd (possibly other apps as well). Equipped with just a home-made air intake, the otherwise stock Xd produced 123 wheel hp and 121 ft-lb of torque. Equipped with the long-tube headers and 2.5-inch mid pipe (2.25 would work equally well) and no axle back, the motor produced 134 wheel hp and 134 ft-lb of torque. At just 3000 rpm, the header and mid pipe offered an additional 15 ft-lb of torque. Next we installed the prototype of the Xd intake manifold. The peak power numbers jumped to 148 hp and 137 ft-lb of torque. At 6000 rpm, the intake offered gains of 16 hp. It appears from this testing that if we add an NST u-pulley and receive the same results as we did on the 1.5L Yaris motor, the 1.8L can produce a real 150 wheel hp (possibly more if it reponds favorably to the FIC). Can someone (Castrex) post this over on the Scion site as well-I can't seem to get the images attached. BTW-We already made 151 wheel hp with a version of the intake that won't be offered for sale-it adds a bit more peak power but sacrafices too much elsewhere)
richardholdener is offline   Reply With Quote
Old 12-14-2008, 10:57 PM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
wow impressive!
Old 12-14-2008, 11:19 PM   #3
yeah, that's right!!
Old 12-15-2008, 01:13 AM   #4
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Well...
Might I say this is simply amazing!!!
I'll post the graph at SL.com
Old 12-15-2008, 05:01 AM   #5
richard, I now dub thee the airflow magician
Old 12-15-2008, 12:48 PM   #6
NonStopTuning
Very well done sir!
Great job
MIKE @ NST
www.NonStopTuning.com
Old 12-15-2008, 12:52 PM   #7
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
very nice numbers.. this proves that the new dual VVTi is severely under-rated from the factory (stock numbers) or your dyno is not properly calibrated.. i hope it's the first and not the second..
Old 12-15-2008, 01:43 PM   #8
CASTREX
CASTREX's Avatar
Well he is comparing against base line runs done on the same dyno. So you can look at it as a % gain.
Stock car 119whp
+ custom CAI 123 whp
+ LT header + Int Mani + Mid pipe 148 whp
We are talking about a 24% increase.
I hope that in a few years we will be able to swap heads with the new 2ZR-FAE (Same engine but with valvematic)
This engine puts 15 additional hp over our version with no Lift.
I see this as the future swap engine of choice for the US Yaris as the work to be done should be minimal.
Not to forget the new 6speed MT (C67 tranny) that it's been offered for the 2009 1.8L and 1.33L Yaris
I can see the light at the end of the tunnel....
Old 12-15-2008, 03:04 PM   #9
andries
aka Jack Wolfskin
Drives: Yaris
Send a message via MSN to andries
This is a great HP gain.
I drive with the stock 1.8 engine and I have already problems, on bad and wet roads, to get the power on the street. Often I have a intervention of the tractioncontrol.
How will that be with all that power?
andries is offline   Reply With Quote
Old 12-15-2008, 03:26 PM   #10
CASTREX
CASTREX's Avatar
Well as you can see from the graphs... most of the power is coming after 4,000rpm.
I don't see why would you be driving at more that 4,000rpm on a slippery / wet road.
That is of course if you are not me...
We have 8-9 months of rain a year over here... and I just loved to push the car under the rain...
If you do it safely driving on such conditions can teach you a lot about the dynamics of your car.
Old 12-15-2008, 04:03 PM   #11
andries
aka Jack Wolfskin
Drives: Yaris
Oke. I had not looked by witch revs the power was released.
(I now the dynamics of the Yaris very well)
Old 12-15-2008, 04:10 PM   #12
CASTREX
CASTREX's Avatar
Sometimes I even disengage the Trac Control / VSC and the ABS from my car.
that is some funny stuff! Is hard to learn how to control the car with all the electronic gadgets.
But for every day driving conditions, Trac Control / VSC / ABS are the best of the best!!! Safety wise Toyota did a great job on this little car.
Old 12-16-2008, 12:15 PM   #13
andries
aka Jack Wolfskin
Drives: Yaris
You can switch off the TRC and VCS without remove the fuse. The ABS is then still working.
It's a trick I've learnt from Yaris Palme, a gadget stock built in by Toyota.
Old 12-16-2008, 12:37 PM   #14
CASTREX
CASTREX's Avatar
.... and why the heck you guys haven't share the trick with me?
Sent me a PM and I'll keep it a secret!
Old 12-16-2008, 01:41 PM   #15
andries
aka Jack Wolfskin
Drives: Yaris
you have PM.
Try it immediately and let me now if it works well on your car
Old 12-16-2008, 04:42 PM   #16
CASTREX
CASTREX's Avatar
Old 12-17-2008, 02:49 AM   #17
andries
aka Jack Wolfskin
Drives: Yaris
And, already drove with the TRC and VSC switched off in the way of trick?
How like that? ( I think )
Old 12-17-2008, 11:37 AM   #18
CASTREX
CASTREX's Avatar
Great!!!
I used to just pull out the VSC/TRAC fuse out. But the downside of this was that by doing that I lost the ABS too which I didn't like.
Now I can disable it with out loosing the ABS...
Have to be careful tough... I was kind of getting used to the vsc keeping things under control on fast corners...
Intake and Long Tube Header Update richardholdener Performance Modifications 48 03-02-2009 02:44 AM
Official Richard Holdener who wants to buy an Long Tube Header list bdc87 Performance Modifications 65 01-13-2009 05:01 AM
Long Tube Header Dyno results & Photo richardholdener Performance Modifications 59 11-26-2008 06:27 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 11:14 AM
