Old 12-17-2008, 07:17 PM   #19
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Originally Posted by at3GG View Post
their racing stuff was like $13 something a quart. How much would i need for a full flush?
A quart is fine for a full flush.
Old 12-17-2008, 07:25 PM   #20
at3GG
at3GG's Avatar
Drives: 07 metmet LB
ohhh ok thanks
will it really help that much?
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 12-17-2008, 07:30 PM   #21
largeorangefont
Break'em off some.
ohhh ok thanks
Yes. Brake fluid attracts moisture and the fluid gets dirty. This takes away pedal feel and consistency over time.
Old 12-17-2008, 07:34 PM   #22
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
ohhh ok thanks
You need to understand what is the function of "racing" brake liquid.
Racing brake liquid has a higher boiling resistance. In other words a higher boiling point.
When the brake fluid gets to hot, you will feel that your brakes are fading. If it get to the point were it boils you can press the brakes all the way down and nothing will happen!
A racing fluid will retard that effect.
But same as racing brake pads. It won't make you stop faster!
Old 12-17-2008, 07:39 PM   #23
at3GG
at3GG's Avatar
haha i wasnt saying i necessarily wanted the racing flui, i was just saying what they had. But if all I need is one quart, the difference betwen the racing and normal stuff is like ..4 buck or soemthing. Might as well get the top notch. How often is a good interval to change it anyway?
Tanabe Df210's
Old 12-17-2008, 07:42 PM   #24
oops, sorry. I'll be darned, they aren't on there. CarboTech pads will be posted tonight!
But there is also vendor thread you can check right now
http://www.yarisworld.com/forums/showthread.php?t=10029
Old 12-17-2008, 07:45 PM   #25
at3GG
at3GG's Avatar
haha gotcha cali! i didnt think they were on there lol The prices on the thread..those for a set of pads AND shoes or just pads?
Tanabe Df210's
Old 12-17-2008, 07:47 PM   #26
CASTREX
CASTREX's Avatar
I change it once a year.
But is really humid down here... plus I drive my car quite hard...
Don't know what's the recommended interval under normal a driving situation.
Old 12-17-2008, 07:49 PM   #27
at3GG
at3GG's Avatar
ok good to know thanks a lot castrex!
Tanabe Df210's
Old 12-17-2008, 08:45 PM   #28
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Nice writeup! I can't wait to get my updated front pads/rear shoes installed.
Judging from what I've read on this thread, it looks like I should go for some SS brake lines and upgrade the brake fluid if I want the full effect.
Does anyone know which SS lines fit the USDM Yaris on the front/rear?
Old 12-17-2008, 09:44 PM   #29
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
C-One SS Brake Lines
StopTech SS Brake Lines
i've seen stoptech on ebay!
Old 12-17-2008, 09:48 PM   #30
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Thanks for the links. I've heard that JDM SS brake lines don't fit the USDM Yaris for some reason, however. Plus, what is up with the price?!
As for the StopTech ones, they don't list the Yaris on their site. Are you sure those lines will work on our cars?
Old 12-17-2008, 09:55 PM   #31
jdmekcivic
jdmekcivic's Avatar
Drives: 2007 Yaris LB
I have Goodridge front and rear lines and they fit fine. No issues at all.
I am also running the Carbotech XP8 pads and shoes. They are great! I have had them on for the last 5 months or so and so far no fade at all. I haven't been to the track to test them to their limits but from what they said I should be very happy with the result.
Thanks Jkuchta for the review!
jdmekcivic is offline   Reply With Quote
Old 12-17-2008, 09:56 PM   #32
Malaya1221
Malaya1221's Avatar
c-one price is ridiculous!
here are stoptech and goodridge for the yaris!
Brake Lines
Old 12-18-2008, 12:50 AM   #33
jkuchta
Drives: 2007 Yaris hatch (red)
Update:
These pads rocked pretty hard at both the Autoclub Roval and the Streets of Willow. I experianced NO brake fade, and pedel feel was quite nice. Modulation was a snap, with really nice bite both cold and hot, though hot bite was phenominal!
One word of caution, though:
With the stock suspension and 500 treadwear tires (Yokohama Avid V4s), and running the XP8 compound up front and the 917 shoes in back, brake bias shifted to the rear to such an extent that moderate to hard braking while going anywhere but straight on the track resulted in a really light rear end (nearly got in trouble once going into the fast esses after the back straight at the Streets (clockwise). While the slight oversteer was very controllable, I still took notice (i.e. pucker factor). I have a feeling that a lot of this can be attributed to the overheated tires and pretty crazy forward weight transfer due to the soft OEM suspension. I'll soon be on coilovers and appropriate tires, so that should bring the braking behavior back more in line. Note though that trail-braking is still quite possible with the current setup, and I found it quite possible to "turn" the rear in very controlably in tighter turns (at the Streets). I'd caution against any trail-braking "exploring" on on/off ramps!
Thanks to all for the positive comments, and I'll keep everyone posted as to improvements and/or changes over the life of these pads.
jkuchta is offline   Reply With Quote
Old 12-18-2008, 08:14 PM   #34
justjesus
justjesus's Avatar
Drives: 2008 Liftback
Holy smokes those C-Ones are expensive! 400+ ?!?!? What did I have for lunch? I'm feeling faint.
Old 12-18-2008, 11:55 PM   #35
auxmike
auxmike's Avatar
Originally Posted by mikenacarato View Post
no, brake shoes go with drum brakes, brake pads go with disc brakes. there is no rotor with a drum assembly.
Not true.
Volvo's 240 series used the inside of the rear rotor as a emergency brake drum. There were "mini" brake shoes within.
I know because I had to replace the mini brake shoes when one lost the braking media off the steel shoe. It was a really weird setup, I'll say!
Old 12-19-2008, 02:25 AM   #36
ddongbap
Remember, your brakes will only be as good as your tires. As far as single runs. If you're already locking tires, or hitting ABS, then you need better tires.
But yes, the only real benefit beyond tires, is heat function.
