Old 01-26-2009, 06:39 AM   #37
ZING
ZING's Avatar
Drives: Yaris '09,GTi '09, BMW 3.30ci
Originally Posted by CtrlAltDefeat View Post
Still unsure about which springs to order...
Also, is an alignment really needed when you swap springs?
Here check out the bottom of this thread, I posted up my car before/after NF210's.
http://www.yarisworld.com/forums/showthread.php?t=13054
As for an alignment I have no idea. I was told by members here to do it, and from my friends dad who was assisting with installation. I am going to go right after my finals.
ZING is offline   Reply With Quote
Old 01-26-2009, 07:17 AM   #38
tk-421
tk-421's Avatar
Drives: 5D-07-LB
well the SSK and the Underdrive pulley are ordered... Still unsure about which springs to order...
Also, is an alignment really needed when you swap springs? The DIY seemed pretty straight forward; I didn't see any thing you could adjust...
I have NF210 springs and they are the perfect balance between stance and daily driving comfort IMO. No rubbing at all with my wheel/tire combo (see my garage for details).
As far as alignment goes, you should really do it until the new springs have settled. Drive it around for a couple of weeks and then get it aligned.
Old 01-26-2009, 07:28 AM   #39
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
Makes sense... I appreciate everyone's help... It kinda got off topic after the parts were decided, so I'm really thankful for everyone's patience with the noob
Old 01-26-2009, 03:26 PM   #40
NST underdrive pulley $118
$112 shipped from me - who did you order from?
Old 01-26-2009, 04:30 PM   #41
CtrlAltDefeat
I ♥ Yaris
whoops... damn I didn't see that I ordered directly from NST for $118 and $10 for shipping
Old 01-26-2009, 04:53 PM   #42
Old 01-26-2009, 07:56 PM   #43
CtrlAltDefeat
I ♥ Yaris
Well I bought all my parts the final list is
Tanabe DF210 lowering springs $158 shipped
from Micro Image
NST Short shift kit $90 shipped
from wesellcarparts.com
NST 10% Underdrive Crank Pulley
$118 + $10 shipping
from nonstoptuning.com
Total: $376
Sadly, I didn't realize that I could have gotten the NST Pulley from Micro Image for $112 shipped
I don't know how I missed that... ahh well, Thank you everyone for your help... when I get the parts in take pics and post the new thread here
Old 01-26-2009, 08:41 PM   #44
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Sweet, your Yaris is about to drive a thousand times better...
And yes, get an alignment post spring install.
Old 01-28-2009, 02:12 AM   #45
botchilah
Drives: white and red shiny things
From my experience, any car with a macpherson front suspension will necessitate an alignment every time you dismantle / disassemble the shocks since it is an integral, moving part (not just up and down but rotates on its body clockwise / counter-clockwise when you steer). And if the car's ride height becomes lower, your camber will be off for sure. By how much varies on a lot of things, but for the most part, it will be excessively off for sure. Toe also tends to change so you gotta look into that. Camber bolts would be great to remedy this. A pillow-ball top-mount would be beter but might be too harsh for most DD cars.
Having said that, since I don't have my Yaris yet, I'm not sure if the Yaris has a macpherson front suspension but if it does, you definitely will need an alignment job to maximize your suspension upgrades.
As for the rear, I haven't really looked at the Yaris' rear suspension but doesn't it look like ti has a simple twist-beam rear-end? Anyone please correct me if I'm wrong. I'm basing my experience on mostly Evos and Subarus I've dealt with in the past plus my old Honda Fit / Jazz DD.
botchilah is offline   Reply With Quote
Old 01-28-2009, 04:46 AM   #46
dexter_5000
dexter_5000's Avatar
Drives: 2006 Scion xA
Send a message via AIM to dexter_5000
machperson front suspenion and a torsion beam rear.
dexter_5000 is offline   Reply With Quote
Old 01-28-2009, 05:40 AM   #47
botchilah
Thanks Dexter5000!
I realize an alignment job there is quite expensive which is probably why everyone is hesitant to do it. Back here a decent alignment from a computerized aligner will set you back 10-20 U$ in your money. I tend to have my cars aligned every 3-4 months partly because the roads here are pretty bad, partly because I like experimenting with alignment specs and lastly because it's cheap!
I believe it's closer to 100U$ for a proper alignment job there?
Old 01-28-2009, 08:10 AM   #48
CtrlAltDefeat
I ♥ Yaris
well costhelper.com says $50-$100 for an alignment which is an unexpected expense... Well I've heard it will take a couple of weeks for the springs to settle, so I'll just have to save up... If I had realized that I might have dropped off one of the other parts to make up for it...(tho I don't think I'd be as happy about my upgrades)...
Last edited by CtrlAltDefeat; 01-28-2009 at 09:41 AM. Reason: whoops left out what i was talking about...
Old 03-30-2009, 05:09 AM   #49
CtrlAltDefeat
I ♥ Yaris
Oh hey I forgot to post the link here with my mods on it... Here it is...
Old 01-02-2011, 11:38 PM   #50
crolandiz
Drives: Yaris Sedan '08
Hi, my engine is a 1.3L 2NZ-FE, do you think I can install the NST 10% Underdrive Pulley Set wich is for the 1.5L?
Thank you.
crolandiz is offline   Reply With Quote
Old 01-05-2011, 07:56 AM   #51
yaris rs
Drives: 2009
your list is good, i would suggest though...
shocks (tokico blues)
lowering springs
shortshifter kit
AND if money is left over, a rear sway bar.
(rear since there isnt anything there besides control to regulate corning load)
"Anti-sway bars (also known as anti-roll bars) are used along with shock absorbers or struts to give a moving automobile additional stability. An anti-sway bar is a metal rod that spans the entire axle and effectively joins each side of the suspension together.
When the suspension at one wheel moves up and down, the anti-sway bar transfers movement to the other wheel. This creates a more level ride and reduces vehicle sway. In particular, it combats the roll of a car on its suspension as it corners. For this reason, almost all cars today are fitted with anti-sway bars as standard equipment, although if they're not, kits make it easy to install the bars at any time"
yaris rs is offline   Reply With Quote
Old 01-05-2011, 10:15 AM   #52
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Thank you.
the 1nz and 2nz are the same engines, just different displacement.
