#19 |
I have the 21 pound model, and it works great. My stock battery was nearly 35 pounds.
The only downside to the Brailles is they don't have a deep reserve. You won't be able to leave the car in key-on bumping your music for very long with the little ones. As far as it holding a charge and cranking the car to start it, I've had no troubles with it.
#20 |
The one with cheese on it
Drives: '10 Corolla S Join Date: Oct 2008
They're not that bad. As far as holding it down. There is a kit for it. You just screw through the bottom plate (after measuring and making sure you don't hit any wires) and it's just as secure as the OEM. When I get a chance, I'll post pics of it. Overall, though, the install is straight forward. MUCH easier than installing the pulleys or the bushings. It just requires ingenuity [*sp?]
I don't know if its just a fresh battery or if its just a better quality, but I noticed that my car cranks up faster. Plus, with all the space you GAIN, you can probably add a BIGGER air intake box. |
#21 | |
Please post pics VERY soon. I'm dying to see one of these installed with the brackets you can get with them. This is definitely going to happen to my car.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
#22 |
Don't worry, you'll get the pics my friend. Its just that my wife has the camera and I am cramming for an exam coming up. Probably Sunday.
#23 |
![]() ![]() ![]() ![]() ![]() Drives: NST CARS: S13 AE86 ANT10 AW11 Join Date: Dec 2006
Sunday
#24 |
![]() ![]() ![]() Drives: bone f*ing stock Join Date: Dec 2008
GOOD GOD THEY ARE EXPENSIVE!
#25 |
![]() ![]() Drives: 07' HB Black Join Date: Nov 2008
Seems like a good idea for a high price .. 148 ....
When life passes you by ... dowshift
#26 |
A 20lb weight reduction for $150 is NOT expensive.
People pay SEVERAL hundred dollars to drop 10 or 15 lbs from their hood or hatch by going to carbon fiber versions. Sometimes several thousand dollars to drop 10 or 15 lbs from a set of wheels.
#27 |
The 11lb Braille, shown with the optional aluminum kit, in the OEM Yaris location...
#28 | |
![]() How long does a braille batterie typically last? |
#29 |
![]() ![]() Drives: yaris Join Date: Oct 2008
braille battery
why the BIG difference in price $$$$$ between the - B14115 (non weight)
and the - B14115C (carbon fiber), since both are 4 cylinder,11.5 lbs.?
#30 | |
One's CF and the other one isn't?
#31 | |
#32 |
![]() ![]() ![]() Drives: 2010 Mazda3 iTouring Join Date: Jun 2007
The aluminum mounting kit looks real nice
#33 |
Such an adorable battery.
#34 |
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
pretty cool but in a serious racing car, would it be possible to run without a batter at all? I.E. hook up a battery to start it, then remove it and run only on the alternator?
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
#35 |
We have the 11 lbs battery on our car, for a daily driver it works well, but if i dont drive the car for more than 3-4 days then i have to disconnect it, but other than that it works well on our car.
http://urbanracer.com/articles/anmvi...sp?a=2900&z=40 there are some pictures of the engine bay at the bottom
Saku Ono leo24@cornell.edu |
#36 | |
I ♥ Yaris
http://www.yarisworld.com/forums/showthread.php?t=13690
| Lightweight batteries anyone? | jm1681 | Performance Modifications | 16 | 08-17-2007 01:50 AM |
| Toyota plans hybrid that runs on batteries | hhcchen | Off-topic / Other Cars / Everything else Discussions | 2 | 07-22-2006 02:35 AM |
