Old 02-06-2009, 02:18 AM   #19
I have the 21 pound model, and it works great. My stock battery was nearly 35 pounds.
The only downside to the Brailles is they don't have a deep reserve. You won't be able to leave the car in key-on bumping your music for very long with the little ones. As far as it holding a charge and cranking the car to start it, I've had no troubles with it.
Old 02-07-2009, 06:52 AM   #20
texkid
The one with cheese on it
Drives: '10 Corolla S
They're not that bad. As far as holding it down. There is a kit for it. You just screw through the bottom plate (after measuring and making sure you don't hit any wires) and it's just as secure as the OEM. When I get a chance, I'll post pics of it. Overall, though, the install is straight forward. MUCH easier than installing the pulleys or the bushings. It just requires ingenuity [*sp?]
I don't know if its just a fresh battery or if its just a better quality, but I noticed that my car cranks up faster. Plus, with all the space you GAIN, you can probably add a BIGGER air intake box.
texkid is offline   Reply With Quote
Old 02-07-2009, 07:08 AM   #21
yarstar
Drives: 2008 Absolute Red HB
Please post pics VERY soon. I'm dying to see one of these installed with the brackets you can get with them. This is definitely going to happen to my car.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 02-07-2009, 07:27 AM   #22
texkid
Don't worry, you'll get the pics my friend. Its just that my wife has the camera and I am cramming for an exam coming up. Probably Sunday.
Old 02-07-2009, 03:38 PM   #23
NonStopTuning
Sunday
MIKE @ NST
www.NonStopTuning.com
Old 02-08-2009, 04:25 AM   #24
ka0sx
ka0sx's Avatar
Drives: bone f*ing stock
GOOD GOD THEY ARE EXPENSIVE!
ka0sx is offline   Reply With Quote
Old 02-08-2009, 07:23 PM   #25
SEVEN
Drives: 07' HB Black
Seems like a good idea for a high price .. 148 ....
When life passes you by ... dowshift
SEVEN is offline   Reply With Quote
Old 02-09-2009, 12:57 AM   #26
NonStopTuning
A 20lb weight reduction for $150 is NOT expensive.
People pay SEVERAL hundred dollars to drop 10 or 15 lbs from their hood or hatch by going to carbon fiber versions.
Sometimes several thousand dollars to drop 10 or 15 lbs from a set of wheels.
MIKE @ NST
Old 02-09-2009, 12:59 AM   #27
NonStopTuning
The 11lb Braille, shown with the optional aluminum kit, in the OEM Yaris location...
MIKE @ NST
Old 02-09-2009, 01:25 AM   #28
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Plus, should you be in the market for a new battery anyway, it's suddenly half price...
How long does a braille batterie typically last?
Old 02-09-2009, 02:53 AM   #29
phenoyz
phenoyz's Avatar
Drives: yaris
braille battery
why the BIG difference in price $$$$$ between the - B14115 (non weight)
and the - B14115C (carbon fiber), since both are 4 cylinder,11.5 lbs.?
phenoyz is offline   Reply With Quote
Old 02-09-2009, 03:40 AM   #30
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by phenoyz View Post
why the BIG difference in price between the - B14115 (non weight)
Hmmm... Might going out on a limb here, but...
One's CF and the other one isn't?
Old 02-09-2009, 04:05 AM   #31
phenoyz
phenoyz's Avatar
Drives: yaris
Old 02-09-2009, 04:31 AM   #32
2006fronty
2006fronty's Avatar
Drives: 2010 Mazda3 iTouring
The aluminum mounting kit looks real nice
Old 02-09-2009, 05:25 AM   #33
ddongbap
Such an adorable battery.
Old 02-09-2009, 05:54 AM   #34
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
pretty cool but in a serious racing car, would it be possible to run without a batter at all? I.E. hook up a battery to start it, then remove it and run only on the alternator?
Old 02-09-2009, 02:39 PM   #35
SAKU
SAKU's Avatar
Drives: White 3-Door Yaris
Send a message via Yahoo to SAKU
We have the 11 lbs battery on our car, for a daily driver it works well, but if i dont drive the car for more than 3-4 days then i have to disconnect it, but other than that it works well on our car.
http://urbanracer.com/articles/anmvi...sp?a=2900&z=40
there are some pictures of the engine bay at the bottom
Saku Ono
leo24@cornell.edu
SAKU is offline   Reply With Quote
Old 02-09-2009, 02:43 PM   #36
CtrlAltDefeat
I ♥ Yaris
hahaha I just started a thread about your car here!
http://www.yarisworld.com/forums/showthread.php?t=13690
Lightweight batteries anyone? jm1681 Performance Modifications 16 08-17-2007 01:50 AM
Toyota plans hybrid that runs on batteries hhcchen Off-topic / Other Cars / Everything else Discussions 2 07-22-2006 02:35 AM
