Old 03-02-2009, 03:59 PM   #1
Brian
Brian's Avatar
Rear disc brake conversion installed
Installed my rear disc brake conversion yesterday. Just need to adjust
the e-brake a little bit more.
Old 03-02-2009, 04:00 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
shiney!!!!
Originally Posted by xnamerxx
you nailed it sir.
Old 03-02-2009, 04:00 PM   #3
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
looks good, any install problems?
Old 03-02-2009, 04:06 PM   #4
Brian
Brian's Avatar
Didn't really have any problems. Just took a little bit of time for me to bend the brake lines
in a good position. But they will be going away soon to make way for some Vios stainless steel
braided lines.
Old 03-02-2009, 04:08 PM   #5
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Nice!
Is that MicroImage's kit?
Are you installing a proportioning valve?
Old 03-02-2009, 04:15 PM   #6
Brian
Brian's Avatar
Originally Posted by CASTREX View Post
Nice!
Yes, it's the kit from Micro Image. No plans for proportioning valve.
Old 03-02-2009, 04:15 PM   #7
There's no need for a proportioning valve with this kit. It's designed for the car, and while I haven't scientifically tested it, I will say I think the rear brakes are doing more of the work with the conversion installed.
Old 03-02-2009, 04:16 PM   #8
Tamago
Tamago's Avatar
Drives: ZZW30
what's the rotor diameter compared to stock?
you nailed it sir.
Old 03-02-2009, 04:18 PM   #9
Klink10
Klink10's Avatar
Nice job.
Old 03-02-2009, 04:25 PM   #10
Brian
Brian's Avatar
I think the new rotors are 285mm. Garm or Thomas should be able to verify.
Old 03-02-2009, 04:27 PM   #11
Tamago
Tamago's Avatar
Drives: ZZW30
11.2" rotors in the rear??? wow!
you nailed it sir.
Old 03-02-2009, 04:31 PM   #12
The rotor is just a little bigger than stock -- if I recall correctly, 285mm?
Old 03-02-2009, 04:57 PM   #13
Brian
Brian's Avatar
Just checked. There's a 285 stamped on the rotor.
Old 03-02-2009, 05:07 PM   #14
tk-421
tk-421's Avatar
Drives: 5D-07-LB
That looks hot. Well done, sir!
Old 03-02-2009, 05:26 PM   #15
falkor_99
falkor_99's Avatar
Drives: 07 Yaris Blue HB
Send a message via AIM to falkor_99
that looks amazing! it makes the car looks sooo much better imo. Great job.
falkor_99 is offline   Reply With Quote
Old 03-02-2009, 05:56 PM   #16
SurfinYaris
Drives: White Yaris
awesome!
SurfinYaris is offline   Reply With Quote
Old 03-02-2009, 07:24 PM   #17
bxrich
bx in the house
Drives: toyota yaris sedan
nice job sweeeeeeet i like i like gram that's next for me.
bxrich is offline   Reply With Quote
Old 03-02-2009, 07:57 PM   #18
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Will this conversion fit stock 15" alloys?
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 09:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 07:05 PM
ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS kargoboy YarisUniverse 11 01-20-2009 05:43 PM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 07:13 PM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-26-2007 12:10 AM
