Old 04-04-2009, 02:47 PM   #91
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
Originally Posted by AlexNet0 View Post
awesome, now I'm not mad anymore, lol, I get so pissed whenever I try something and it doesnt work, makes me feel so incompetent when I know I'm fully capable, lol
oh i know what you mean, but it'll oscillate back and forth until it finds a happy medium
Wanted: Forced Induction
Old 04-04-2009, 08:47 PM   #92
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
i think i just got a bad 1zz tb, it still just oscillates wildly and doesnt settle at all, even fully warmed up, even with the 1nz chip swapped in. i just put the 1nz tb back on, maybe ill try to get ahold of another1zz tb
Old 04-05-2009, 12:46 AM   #93
i have an extra 1zz tb
Old 04-05-2009, 01:33 AM   #94
dallas
Drives: Yaris Hatch /Landrover D2
First dibs, why did you buy two? are they different serial numbers ? What do you want for it, if it's o.k ? I'm in Canada like you, so shipping should be easy.
dallas is offline   Reply With Quote
Old 04-05-2009, 02:02 PM   #95
jkuchta
Drives: 2007 Yaris hatch (red)
Make sure you use a god gasket maker (RTV silicone), and let it sit for 3-5 hours before starting the car.
If you don't let the silicone set up before starting the car, the engine vacuume will suck the stuff into the intake, and you'll get an ocillation and CEL!
jkuchta is offline   Reply With Quote
Old 04-05-2009, 07:10 PM   #96
AlexNet0
AlexNet0's Avatar
Exactly what I used, I let it set for over an hour, when I pulled it back off after getting the same bad result it was set pretty well. It barely responded to the throttle, meaning that I could not manually hold it in one spot, it would start to, then it just took over, maybe a bad spring in it or something, I dunno.
Old 04-06-2009, 12:38 AM   #97
jkuchta
What codes are you getting...and have you adjusted the idle set screw yet?
Old 04-06-2009, 02:53 PM   #98
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I just finished my own TB swap install. I made the chip swap from the start, took the epoxy off the idle screw, and bypassed the TB coolant lines, just as other members have done.
I was unable to find a silicone coupler quickly enough, so I just used a dremel with a filing bit on the inside of the hose until it fit perfectly.
I just took it back from a test drive, and have a BIG smile on my face. No CELs, no weird idle fluctuations, nothing. The only small detail was that it idled at 3K for the first minute or so. After that it steadily went down until it got to 0.5 K.
So now I guess that I shouldn't even need to adjust the idle screw at all. I'll try it out for a couple of days. If nothing happens, I'll just seal the screw again and be done with it.
The difference can be felt right away. And not only did I not notice a power loss at lower revs, but actually a gain! The car pulls a lot better now, even from a complete stop. And the sound is amazing too.
Many thanks to Yaris T-Sport for his excellent idea to swap the chips, and jkuchta for his writeup!
Now on to the 4-2-1 header...
Old 04-06-2009, 08:48 PM   #99
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Hmm now I wanna do this again
Blah, Blah, Blah, Blah
Saggio is offline   Reply With Quote
Old 04-06-2009, 09:09 PM   #100
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
where are you guys getting the connector for the coolant bypass?
i used a Volvo VED12 Semi-truck engine piston squirter nozzle to make my bypass.
mikenacarato is offline   Reply With Quote
Old 04-06-2009, 09:20 PM   #101
jkuchta
I used a 3/4 " brass double barb union from the plumbing section of Home Depot....I think I paid $5 for it.
Old 04-07-2009, 12:21 AM   #102
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I tried a 3/4" but it was way too big. I went for a 1/4" instead and it worked great. Weird, I know.
Old 04-07-2009, 01:56 AM   #103
jkuchta
I also tried a quarter inch fitting, but there was no resistance on the barb, so I went 3/4.
Old 04-07-2009, 01:43 PM   #104
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Looks like I will need to adjust the idle screw after all... Every time I cold start, it goes up to 3K and gradually goes down until the engine temp light turns off. No CELs as of yet, and I've been driving it pretty hard.
Old 04-07-2009, 03:57 PM   #105
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I just found something out by chance: I can lower the revs when cold starting by pumping the clutch pedal. Every time I press/depress the pedal, the revs go down a notch. Don't ask me why.
Old 04-07-2009, 05:44 PM   #106
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
and stay down?
Old 04-07-2009, 06:52 PM   #107
mikenacarato
SIPNDEW
Drives: 15 STI
ya i noticed that too a few days ago and i noticed it does that.
on a side note....still no cel after hard driving and a few weeks of time. the chip swap mod is a success.
Old 04-07-2009, 07:29 PM   #108
AlexNet0
AlexNet0's Avatar
maybe I just didnt use enough gasket maker, err, practice makes perfect I guess, lol, since someone mentioned that a leak can cause it to go nuts too.
makes sense now, because it did go nuts on me, lol
1zzfe throttle body lilman717 Performance Modifications 22 02-12-2009 07:08 PM
intake and throttle body Q thebarber Performance Modifications 3 08-20-2007 07:02 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
