Old 05-10-2009, 08:50 PM   #199
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Maybe you have a bad TB or the idle screw was messed with too much? (I didn't bother touching mine.)
I never did the chip swap on mine (too lazy). Coolant bypass (didn't bother to bleed it) and only have high idle when cold and of course my CEL is always on. (For about 700 miles now)
Mine does stick a bit it seems, RPMs hang for a few when slowing quickly to a stop (usually to go over speedbumps).
No oscillation, except when I first installed it. That was fun trying to avoid looking like a douchebag revving at every light. (For the 100 miles I had that issue I would just put the car into gear quickly to bring the car's RPMs down to normal and then release.)
Old 05-10-2009, 11:24 PM   #200
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Yup I get the stuck throttle at times as well. Cold idle too, but no CEL yet.
Old 05-10-2009, 11:37 PM   #201
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
my CEL is now off and looks like its staying off
it hasnt popped back on yet, im feeling lucky
but i havent had any issues with stuck throttle or anything like that
http://www.4055design.com
Old 05-11-2009, 01:03 AM   #202
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I bought the TB off of m911gt who was selling it because of the same issue. I did the chip swap on it so that rules out a bad chip. Fucking with the idle screw is the only thing I have yet to do because I don't see why that would cause anything other than a too high/too low idle. Plus after I installed it I drove to work and back (50 mile round trip) and it ran flawlessly other than hanging to RPMs a little bit but it sure as hell wasnt oscillating. Also this entire time I have yet to actually get a check engine light You would tend to think with the motor ranging from 1-3/4k rpm it would throw a code. I think my ECU is just being a stuck up whore
Old 05-11-2009, 01:05 AM   #203
PHXDEMON
PHXDEMON's Avatar
Also Gideon did yours oscillate right off the start? Did it come and go? Or was it just oscillation constant for first 100 miles and then it went away? How hard did you drive it for thos efirst 100?
Old 05-11-2009, 01:07 AM   #204
PHXDEMON
PHXDEMON's Avatar
Possibly you guys running with CELs are in open loop vs closed loop and that's why you aren't getting oscillation
Old 05-11-2009, 01:29 AM   #205
Gideon
★weeaboo★
Gideon's Avatar
Yeah, it oscillated every time I let the engine go back to idle initially and it was for only 20 miles or so. In that 20 miles I ran it to redline every chance I could. (After the engine was properly warmed up of course)
Old 05-11-2009, 01:36 AM   #206
PHXDEMON
PHXDEMON's Avatar
So I need to start driving like a ricer Also was it really jerky every time you applied/let off the gas? Like on the freeway I hit the gas but it steadily accelerates so I have to let off and every time I take my foot off/put it back on the gass it jerks like a motherfucker.
Old 05-11-2009, 01:56 AM   #207
Gideon
★weeaboo★
Gideon's Avatar
Yeah it was pretty jerky initially.
It still is really jerky if the engine is cold, but once it warms up it ceases.
Old 05-11-2009, 03:29 AM   #208
PHXDEMON
PHXDEMON's Avatar
Mine keeps getting worse and worse. Jerky as fuck even when the sngine is warm and the oscillation is progressively getting worse.
Old 05-11-2009, 05:53 PM   #209
PHXDEMON
PHXDEMON's Avatar
okay so the idle screw was all the way in and I backed it up as far as I could. Let the car idle for about 10 minutes and slowly the idle smoothed out completely While driving I am still getting some jerkyness and moderate oscillation (1-2k) at stop lights but nowhere near as bad as it was. It seems the ECU is actually trying to learn the new throttle body now instead of just being a whore about it. Hopefully it will smoothe itself out some more as I drive it more.
Old 05-11-2009, 06:59 PM   #210
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
hope that fixes ur issue..
Old 05-11-2009, 07:06 PM   #211
PHXDEMON
PHXDEMON's Avatar
Oh believe me so do I Hell I can even live with how it is now it's just that pegging from 1-4k nasty oscillation was horrible. The car was almost undrivable
Old 05-11-2009, 08:49 PM   #212
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Correct others have plugged them I just left them as is. Just go down to a lowes/home depot/etc and get a coupler barb for 3/8 inch ID vinyl tubing and you are food to roll. Stock clamps work and everything just need the barb.
FYI, I'm always food to roll..always.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 05-11-2009, 09:01 PM   #213
PHXDEMON
PHXDEMON's Avatar
Did you do the bypass?
Old 05-12-2009, 01:36 AM   #214
PHXDEMON
PHXDEMON's Avatar
Yay my motor is finally running half decent and I got a CEL
Old 05-12-2009, 08:06 AM   #215
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
that must mean its working!
Old 05-12-2009, 12:17 PM   #216
marcus
toyota
marcus's Avatar
nice.. so ur saying it idles the same as stock and no oscillations.. what about start up how high does it warm up to..
no wwe jsut need to kill the cel ..
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 07:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
