Old 05-21-2009, 03:20 PM   #235
jkuchta
Drives: 2007 Yaris hatch (red)
Originally Posted by Yoda View Post
thx it wasnt too hard so i didnt need the diy. Didnt do the chip swap gonna see what other means there are to eliminate the cel if i get any.
If you adjust the idle set screw you might be ok.
jkuchta is offline   Reply With Quote
Old 05-21-2009, 03:32 PM   #236
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Did you get the oscillation? thats what the chip swap was originally indended to fix
Old 05-21-2009, 03:35 PM   #237
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
adjust it to were? sry total noob at this. dont even kno where the darn thing is
Old 05-21-2009, 03:52 PM   #238
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
ok sorry its this one like he said.
Old 05-21-2009, 04:03 PM   #239
Yoda
Yoda's Avatar
there
clockwise? anticlockwise? how much of a turn?
o and is it an actual screw cause there is none...
Old 05-21-2009, 04:59 PM   #240
tk-421
tk-421's Avatar
Drives: 5D-07-LB
there
That's not the idle screw. It's this one (covered in epoxy here):
You'll need a small allen wrench to turn it BTW. As far as CW/CCW, I can't remember... I believe I ended up turning it CW almost all the way.
Old 05-21-2009, 06:05 PM   #241
Yoda
Yoda's Avatar
ok kwel i will try it as is now then adjust later the rain lifted up sp let me finish installing it. It was hard as heck to get the afe coupler over the TB had to shave some off.
Old 05-21-2009, 06:41 PM   #242
Yoda
Yoda's Avatar
so yea i installed it right. i was doing the whole coolant overflow thing and well it didnt. I waited for like 5 min and no overflow so i was like ok. No oscillation just high cold and when its warm it setlles at a high of 1100rpm and a CEL Againg i said ok. Before i went to disconnect the battery i tried stepping on the throttle. This event was followed bu very very very slow climb in rpm. Again ok... So i floored it Not a good idea didnt make a diff at all the car started shaking and i quickly turned it off. So yea the battery is disconnected and i will wait a ahwile before i see wat is up. Any ideas lol?
Old 05-21-2009, 06:58 PM   #243
tk-421
tk-421's Avatar
Drives: 5D-07-LB
The cold start sounds normal to me. In my case it's always @ 2.5K
It shouldn't settle @1.1K though... That sounds high to me when idling.
The CEL thing is hit/miss... Some ppl get it, some ppl don't.
Old 05-21-2009, 07:02 PM   #244
Yoda
Yoda's Avatar
yea but something is up with the throttle. i gonna try it again once it resets. I think i might have to turn the screw until the idle get down to normal. Little small turns lol.
I hope i didnt get a defective one.
Old 05-22-2009, 02:23 AM   #245
jkuchta
Turn the idle screw 1.5 turns counter-clockwise. Also, if you used any gasket maker, you need to not run the car for a few hours to let that stuff cure, or else the idle vacuum will suck the stuff into the intake manifold...which will give you really erratic running and a CEL.
Old 05-22-2009, 08:35 AM   #246
Yoda
Yoda's Avatar
well its morning gonna try again that idle screw is hard to turn.
Old 05-22-2009, 11:03 AM   #247
Yoda
Yoda's Avatar
ffs its stripped the fing screw!!!
Old 05-22-2009, 11:06 AM   #248
marcus
toyota
marcus's Avatar
get rid of the glue.. then try wd40.
Old 05-22-2009, 01:10 PM   #249
jkuchta
If the set screw is toast get a broken bolt remover and pull it out. I believe an M3x20mm screw will work as a replacement.
Old 05-22-2009, 02:19 PM   #250
Yoda
Yoda's Avatar
ok so i got back throttle response due to chip swap but its idling at 1.6k warm.....
Also when i tried the holding rpm thing it just starts to bounce up and down :(. I think i may need to disconnect the battery longer cause i only did it for 20 min. got to find a way to get that screw out.
O btw i just realized that the TB i got came from an auto trans car. Do you think that makes a diff?
Old 05-22-2009, 03:07 PM   #251
Yoda
Yoda's Avatar
drove it city hard. oscillated whenever i depressed the clutch. got to the Auto part store alive pulled the code it read 2103 Motor circuit high. Unop leaving the store the oscillation went away for the mosr part. It only goes from wateva rpm i am at to 500rpm then settles at 600-700rpm
Old 05-22-2009, 03:14 PM   #252
jkuchta
Make sure there are no leaks between the TB and the intake manifold.
Did you use the stock yaris TB gasket (that O-ring with the small brass screen)?
Once you get the idle screw fixed you'll be in good shape.
The fact that the TB came from an auto car won't make a differance.
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
