Old 05-21-2009, 07:58 PM   #253
tk-421
tk-421's Avatar
Drives: 5D-07-LB
The cold start sounds normal to me. In my case it's always @ 2.5K
It shouldn't settle @1.1K though... That sounds high to me when idling.
The CEL thing is hit/miss... Some ppl get it, some ppl don't.
Old 05-21-2009, 08:02 PM   #254
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
yea but something is up with the throttle. i gonna try it again once it resets. I think i might have to turn the screw until the idle get down to normal. Little small turns lol.
I hope i didnt get a defective one.
Old 05-22-2009, 03:23 AM   #255
jkuchta
Drives: 2007 Yaris hatch (red)
Turn the idle screw 1.5 turns counter-clockwise. Also, if you used any gasket maker, you need to not run the car for a few hours to let that stuff cure, or else the idle vacuum will suck the stuff into the intake manifold...which will give you really erratic running and a CEL.
jkuchta is offline   Reply With Quote
Old 05-22-2009, 09:35 AM   #256
Yoda
Yoda's Avatar
well its morning gonna try again that idle screw is hard to turn.
Old 05-22-2009, 12:03 PM   #257
Yoda
Yoda's Avatar
ffs its stripped the fing screw!!!
Old 05-22-2009, 12:06 PM   #258
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
get rid of the glue.. then try wd40.
Old 05-22-2009, 02:10 PM   #259
jkuchta
If the set screw is toast get a broken bolt remover and pull it out. I believe an M3x20mm screw will work as a replacement.
Old 05-22-2009, 03:19 PM   #260
Yoda
Yoda's Avatar
ok so i got back throttle response due to chip swap but its idling at 1.6k warm.....
Also when i tried the holding rpm thing it just starts to bounce up and down :(. I think i may need to disconnect the battery longer cause i only did it for 20 min. got to find a way to get that screw out.
O btw i just realized that the TB i got came from an auto trans car. Do you think that makes a diff?
Old 05-22-2009, 04:07 PM   #261
Yoda
Yoda's Avatar
drove it city hard. oscillated whenever i depressed the clutch. got to the Auto part store alive pulled the code it read 2103 Motor circuit high. Unop leaving the store the oscillation went away for the mosr part. It only goes from wateva rpm i am at to 500rpm then settles at 600-700rpm
Old 05-22-2009, 04:14 PM   #262
jkuchta
Make sure there are no leaks between the TB and the intake manifold.
Did you use the stock yaris TB gasket (that O-ring with the small brass screen)?
Once you get the idle screw fixed you'll be in good shape.
The fact that the TB came from an auto car won't make a differance.
Old 05-22-2009, 04:28 PM   #263
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Yup... Happened to me too... Still haven't fixed it, but don't really have to either
Old 05-22-2009, 04:29 PM   #264
Yoda
Yoda's Avatar
Once you get the idle screw fixed you'll be in god shape.
yea i did use the o ring. Gonna try and dyno it on Monday cause i don't really notice a diff really
I an attempt to figure this out i sarted reading
http://www.etimago.com/yaris/repairm...%20Control.pdf
search 2103
Old 05-22-2009, 04:36 PM   #265
jkuchta
Don't bother going to a dyno until the problems you have are ironed out. Until I got the idle set screw set up properly the thing didn't feel any better, but when the TB is dialed in the differance is pretty noticable.
Old 05-22-2009, 04:39 PM   #266
Yoda
Yoda's Avatar
yea i guess i am tiered for today tho tomorrow i go remove the bolt and replace it
Old 05-22-2009, 06:49 PM   #267
Yoda
Yoda's Avatar
cel gone oscillated gone stock idle. hope it last
Old 05-22-2009, 11:09 PM   #268
t0m4s
1NZ-FE
t0m4s's Avatar
Drives: Yaris Seddan 08
cel gone, oscillated gone and stock idle... and u havent touch the idle screw, right?
DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
t0m4s is offline   Reply With Quote
Old 05-22-2009, 11:31 PM   #269
jkuchta
The whole point of adjusting the idle screw is not to stop CEL's in the short term....the point is to stop the CEL from ever coming back down the road.
If you don't adjust the idle screw, the ECU will eventually compensate and not throw a code, but the second you unplug the battery, all of the bad symptoms will come back.
If you do adjust the idle set screw, the ECU will adjust much quicker and the idle will be more stable. Also, later on when you disconnect the battery to do something, when you hook it back up, the car will behave as though the normal TB is installed (i.e. slightly low idle while it relearns all of the relevant trims).
PLUS.....when I adjusted the set screw on my 1zz TB, i noticed that off-idle performance was improved, and most of the jerkyness associated with the DFCO fuction was gone (before the adjustment, when DFCO would kick it it felt like I was putting the brakes on!).
Overall....you can do this swap without messing with the idle set screw and the CEL will more than likely go away (if the TB is properly sealed to the manifold), but adjusting the set screw really unlocks a lot of the benefit of the swap.
Old 05-23-2009, 02:08 AM   #270
MGargano
Drives: 2009 Yaris Hatchback
If you turn the idle set screw out about a turn and a half, all of your problems will go away.
So I should turn it all the way in, then back out 1.5 turns? If not, what's the 'correct' procedure for adjusting the idle screw?
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 07:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
