Old 06-03-2009, 04:06 PM   #109
The hole can be widened A LOT, maybe half an inch on the radius. The catch is the plastic material is like an inch think. It would make a huge mess to remove it.
That's the nice thing about mounting the switches to that removable trim piece - All of the drilling mess happens on the bench instead of in the car.
Old 06-04-2009, 01:39 PM   #110
bronsin
bronsin's Avatar
Here is my switch install showing the radio shack numbers. Note: I havnt tried this out in the dash to see if my hole position is correct!
Old 06-04-2009, 01:44 PM   #111
Looks close. If you look at the scratched cross and circle on the back of mine you can see the center point of the hole and approximate diameter.
Old 06-04-2009, 01:50 PM   #112
bronsin
bronsin's Avatar
Looks like its possible with these switches that they will fit even if they dont make the hole, judging by the standoffs on the panel itself.
Yeah it fits! The switches are on a 3/4 inch circle. The center of the circle is 1 3/16 inches from the top of the panel (as measured on the outside of the panel) and 1 7/16 inches from the right side of the panel. I cut a 1 1/2 inch circle (the diameter of the cutout in the dash)from a piece of paper and laid out the switches on the paper. Then glued the paper to the panel measureing the center point of the circle from the sides.
Old 06-04-2009, 02:49 PM   #113
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
would this work for any other cars..
Old 06-04-2009, 02:57 PM   #114
Such as?
I would think that based on what we found with the Yaris it would probably be doable for any drive by wire Toyota.
Old 06-04-2009, 03:01 PM   #115
marcus
toyota
marcus's Avatar
nice...
Old 06-04-2009, 05:21 PM   #116
bronsin
bronsin's Avatar
IM thinking something similiar will work for all such DBW cars.
Old 06-04-2009, 11:01 PM   #117
Pitt Yaris
Drives: Flint Mica Sedan
Originally Posted by PatrickJohnson View Post
No, the 2008 LB doesn't have the light on the dash. But really, I didn't need it. I may at some point add the other 2 buttons though.
So did you have to do more than ctscott?
Old 06-04-2009, 11:04 PM   #118
Take a look at this thread:
http://www.yarisworld.com/forums/showthread.php?t=16188
It shows what is required to do it with and 07 or 08. Basically, the extra work is running a wire from the switches to an empty pin on the ECM.
Old 06-05-2009, 11:29 AM   #119
bronsin
bronsin's Avatar
Mod is in and working! The lights for CC come on in the dash and the four buttons are working. I really needed this because my feet are going numb and its hard to feel how much to press the gas pedal. Now I can do it with the pushbuttons a lot of the time. Thankyou so much for this idea!
PS The wife and everybody at work were not exactly supportive about this. "Whattaya messin' wit a bran new car fo...yo is gonna RUIN it!" You need to break through this negative energy sometimes!
PPS My car is a 2009 Basic 2 door HB. Made last September. Oh and it is black in color. I think that helped....
Old 06-05-2009, 03:47 PM   #120
bronsin
bronsin's Avatar
I have two sets of resistors and two sets of switches I bought that I didnt use. For $5 Ill send you a set. PM me if intereted.
Old 06-05-2009, 05:11 PM   #121
POORSHA
POORSHA's Avatar
Drives: 2008 LB
pm'd
POORSHA is offline   Reply With Quote
Old 06-05-2009, 10:39 PM   #122
Originally Posted by POORSHA View Post
pm'd
Let me know if you need help with the install, since you're in CT as well.
Old 06-05-2009, 11:20 PM   #123
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Hold on just a couple more days and I'll have that module installed. I just haven't had time to rip the dash again. I also have to rethink my clutch switch, the switch broke. That's what I get for going cheap :) Anyway, I'll prolly just buy the oem one. I'll put picks up when I'm done with all of this...
My Car Rules!
nickhjort is offline   Reply With Quote
Old 06-05-2009, 11:24 PM   #124
POORSHA
POORSHA's Avatar
Drives: 2008 LB
thanks i might just take you up on it
Old 06-06-2009, 08:33 AM   #125
goat1of2
Drives: 2008 Yaris LB Auto 3-door
In order to provide the on-off indicators which some folks want...rather than messing with wiring LEDS and such, why not just buy an illuminated switch button? Would that work? If so, which Digikey part number would you supersmart electronics types recommend?
I'm about to make an offer on an 07 Yaris without cruise and am MOST grateful that I stumbled on this thread! Thank you all!
goat1of2 is offline   Reply With Quote
Old 06-06-2009, 12:20 PM   #126
The illuminated switch won't work without the same type of driving circuitry, due to the switch being a momentary input (rather than a latching switch). Basically, in electronic terms you need a flip-flop, which takes a single input and toggles the output each time the input is pulsed.
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
