Old 07-13-2009, 09:42 PM   #145
PatrickJohnson
Drives: 2008 Yaris LB
if you are standing in front of the car looking at the engine bay, it is attached to the firewall in the upper left corner
PatrickJohnson is offline   Reply With Quote
Old 07-13-2009, 09:43 PM   #146
And to answer the next question, here's the location of pin 40:
Old 07-13-2009, 09:56 PM   #147
Blue_dragon_192
Drives: 2009 Yaris 4dr Sedan
OK.
looking at the engine bay and now understand the diagrams....
Since it's too dark out and my wife's scion is in the garage, I will attempt this at a different date.
Thank you all for your input...i hope this works.
Blue_dragon_192 is offline   Reply With Quote
Old 07-14-2009, 01:06 AM   #148
Revsson
Where's the engine bay??
just kidding
I have the factory cruise, but if I didn't, I'd probably try this mod.
CT Scott is one of the best with electronics in this forum!!!
Old 07-14-2009, 07:52 AM   #149
Blue_dragon_192
just kidding
Wait................These things have engines?
And here I thought they ran by magic.
Revsson, I am very fluent in sarcasm.......
From all the posts I read, CT Scott knows his stuff. I now have to get the courage to mess with the ECM and get the cruise working.
I am far more comfortable in a room full of servers, the car stuff is a little daunting, when dealing with an ECM!
Old 07-20-2009, 10:57 AM   #150
bronsin
bronsin's Avatar
I had the Yaris out this weekend for a trip to upstate NY and back. (about 250 miles each way) So the CC mod got a good workout. It worked very well indeed! The car got just about 40 mpg when I set the speed on 70 mph. I did the four switch version which gives you plus one and minus one mph at the touch of a button. It came in very handy and I recommend going the four switch route if you install this mod. Getting the Radio Shack really mini switches made doing the four switch really easy...
Old 07-20-2009, 06:43 PM   #151
TylerJ
Drives: Blazing Blue 2007 3dr HB 5MT
Unhappy Help with cruise control switches
I have been looking for a cruise control solution for a while, I am glad I found this thread
I have a 2007 Yaris 3dr Liftback with 5 spd MT, if I can't see the lit icons that you showed in the first few pictures does that mean I can't perform this DIY?
TylerJ is offline   Reply With Quote
Old 07-20-2009, 07:28 PM   #152
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
It just means no indicator lights - the actual cruise will work fine, if properly connected.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 07-21-2009, 08:15 AM   #153
You can do it on a USDM 07 for sure. You will need to run a wire from the switches directly to the ECM's pin 40 on an 07 or 08. Also, with a MT you will need to add the clutch switch and wire it to the connector in the under hood fuse panel. Check out the tail end of this thread for more details:
http://www.yarisworld.com/forums/showthread.php?t=16188
Old 07-21-2009, 03:50 PM   #154
tforkner
Drives: 08 liftback 5 speed
Here's how I did my clutch switch. I used a SPDT submini roller lever switch, Radio Shack # 275-0017. I superglued it in place on the metal bracket.
tforkner is offline   Reply With Quote
Old 07-22-2009, 11:00 AM   #155
TylerJ
Thanks for those of you who responded to my question. I am thinking about doing this mod this weekend. I will update on how it turns out.
Old 07-22-2009, 11:40 AM   #156
bronsin
bronsin's Avatar
Does anyone know the Toyota Part Number for the dash panel next to the ignition switch? (the one I put the switches in for the CC) Im thinking it would be handy to have in case the car needs warranty work!
Old 07-22-2009, 05:00 PM   #157
55446-52060-B0
Old 07-22-2009, 07:48 PM   #158
bronsin
bronsin's Avatar
Thanks much appreciated!
Old 07-23-2009, 02:19 PM   #159
bronsin
bronsin's Avatar
55446-52060-BO is $22 BTW.
Old 07-25-2009, 02:16 PM   #160
TylerJ
I have two SPST N.O. momentary switches from radio shack and a pack of resistors I was just wondering what combination to use ... I have seen some people use 630 and others 660, I can do either with the supplies I have but was not sure about which is better CTScott mentioned I will have to hardwire the clutch switch into my under hood fuse box ... is this because we dont have the connector near the clutch pedal to just plug it in?
Old 07-25-2009, 03:07 PM   #161
216 to 264 ohms for one between resume and on/off
351 to 426 ohms for the one between set and resume
819 to 1001 ohms for the one between set and cancel
For the two switch method, the range for the resistor for the Set switch is from 567 Ohms to 690 Ohms. Any value in that range is fine. I would just stay at least 10 Ohms from either end point.
For the clutch switch, that is correct that the 07 and 08's don't have the clutch cruise switch connector, so you do have to hardwire to connector in the under hood fuse panel.
Old 07-25-2009, 04:02 PM   #162
TylerJ
is there one spot in the firewall where i can thread through the ECM wire from the switches and the two wires from the cluth cruise switch ? being that they are on opposite sides
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
