Old 11-08-2006, 06:16 PM   #73
funkstrong
I was wondering about that. I don't want to sound like an idiot but I don't see how it can increase your hp. Would you just get a better spark?
funkstrong is offline   Reply With Quote
Old 11-08-2006, 07:25 PM   #74
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
On a new car it won't do much if anything.
However better grounding can allow engine sensors to work more efficeintly becaise of equalized resistance.
Overtime ground points and connections can become corroded and rusted and poor ground can result in higher and lower resistance, poor ignition or false/poor sensor readings.
I have seen cars like my own Laser that did have several rusted and corroded connections after 10~15 years of driving. Components like the throttle body bolts and studs were really corroded badly and add to that a gasket between that and the head there is a possibility for a very poor ground. And adding a ground kit as well as cleaning up the original equipment grounds will help restore proper grounding and lost power. In my case I went through 3 alternators in a couple months and finally talked to a Mitsu mechanic for a rally team and he told me to clean up the OE grounds and add a few more to or close to the most important components to equilize the resistance. I did that and never had any more chrarging problems and a better steady idle. But that's it on a 12+ year old car, driven daily with 300,000k.
With gold terminals you don't have as much or any corrosion so over time you maintain the same performance.
I've heard almost every possible "felt difference" from other members from other boards about adding a grounding kit.
things like
faster 1/4 mile
Lower rpms at cruise speeds
Faster warm ups
Better throttle responce
Quieter engine
Fact is 99% of so called felt gains are bullshit. People get it in their heads it's going to help increase power and will swear it did. a basic Placebo...
Companies will tell you what you want to hear to sell you a product but for the most part these kits don't do any of these.
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 11-08-2006, 07:26 PM   #75
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Originally Posted by bigsky2
Ground wires are not meant to increase HP imho.
It's another marketing point for ground wire/voltage stabilizer manufacturers when they sell these types of products.
My goal is to strengthen the ground connections of the vehicle to reduce fluctuations in voltage, and hopefully reduce this sort of fluctuation on electronic components.
Old 11-11-2006, 02:37 AM   #76
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Hey itsmydaily,everything fits fine with the Tanabe strut bar installed,just make sure they dont toch,i got some sparks,but thats because I installed the kit after the bar,alot harder.I only have the alternator and the intake hooled up at the moment,I also have my voltage stabalizer installed,I deffinitly notice the car is smoother,and when I start the car,it starts quicker,and the starter sounds stronger.
eco is offline   Reply With Quote
Old 11-11-2006, 09:02 AM   #77
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Guys do I need to buy a complete kit, like the one the guys above bought from ebay?
I have a custom one, but there are only 6 grounding points.
Old 11-11-2006, 09:04 AM   #78
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
You ground what u wanna ground.
Old 11-11-2006, 09:06 AM   #79
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
I made mine. Easy as crap.
will work for parts
vodkalush is offline   Reply With Quote
Old 11-11-2006, 10:30 AM   #80
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
thankx, thats good to know. looks like I'll be getting the strut bar then
Got any pics? I'm curious to see where you mounted the voltage stabilizer.
Yaris Mods:
20% Tints
Ground wires
2007 Toyota Yaris Liftback - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla SR5 - Sold
DIY: Groundwire Kit
ItsMyDaily is offline   Reply With Quote
Old 11-11-2006, 11:44 AM   #81
eco
eco's Avatar
Ok,Ill take some pics today.But if your curious and cant wait,I mouted it between my battery and fuse box.
Old 11-11-2006, 10:28 PM   #82
hasher22
Look mum no stars!!
hasher22's Avatar
My curiosity on this grounding kit
http://cgi.ebay.com.au/New-JDM-Groun...QQcmdZViewItem
hmmmmm should i? its just looooooksss soooo pretttyyyy......
Old 11-11-2006, 11:18 PM   #83
the_saint
50% borikén
the_saint's Avatar
Drives: 06 Mazda5, 90 240sx
For $85....I'd pass.
the_saint is offline   Reply With Quote
Old 11-11-2006, 11:51 PM   #84
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
wow never seen one like that before, good find, but not worth the price.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 11-12-2006, 12:01 AM   #85
eco
eco's Avatar
It looks like that stabilizes voltage aswell,but I think youll have a very hard time mounting that,you may,but you will not be able to see that voltage meter.Ill post the pictures of my partial install tomorrow morning.
Old 11-12-2006, 11:02 AM   #86
Katana
Katana's Avatar
Yes but do I need more grounding points?
Old 11-12-2006, 11:57 AM   #87
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
You don't need to have more. six is enough and even five would be enough. Only put more if you want to add more grounding points. Otherwise six is plenty.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 11-12-2006, 03:54 PM   #88
hasher22
Look mum no stars!!
hasher22's Avatar
I believe there are 6 main points to ground. Though from what i heard/seen u can have 13 grounding points......correct me if im wrong...
Old 11-12-2006, 06:35 PM   #89
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
Well here are the results from my grounding kit:
W/O GROUNDING KIT
---------------------OHMS----VOLTS
Alternator----------- 0.6-------0.02
ECU-------------------1.7-------0.005
Throttle Body------- 1.2-------0.011
Transmission-------- 0.6-------0.016
Head------------------0.7-------0.016
WITH GROUNDING KIT
---------------------OHMS-----VOLTS
Alternator------------0.6--------0.011
ECU-------------------0.6--------0.008
Throttle Body-------0.3--------0.001
Transmission--------0.1--------0.009
Head------------------0.5--------0.009
The Ohms were read while the engine was off, volts while engine was on. The readings were taken using a Fluke 87 Ohmmeter. The leads were placed, red on the bolt being tested, black on the negative terminal on the battery. The volts were a good indicator of how the resistance was reduced, since the more voltage flowing through the grounding wire, the less voltage drop across the voltmeter. If you wish, I can tell you exactly which bolts I used for my hookups/readings.
I will tell you this, I can detect a small difference in the pull of my engine at higher speeds. It feels a little more willing at higher RPMs. Nothing major though. Idle doesn't really feel any smoother. I'll let you know about any MPG changes, if there are any.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 11-12-2006, 11:32 PM   #90
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
i think we need a new thread
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
Is aftermarket HID kit legal (in NJ)? Jfoofoo Cosmetic Modifications (Exterior/Interior) 25 03-19-2009 02:05 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
Any front bumper/ hood stone chip issues? Where could I get Clear Bra kit? tifosi360 General Yaris / Vitz Discussion 9 08-07-2006 02:43 PM
