#19 |
![]() ![]() ![]() Drives: Yaris Join Date: Apr 2009
Another good point noted above.
BTW...why does putting a supercharger on a 4cyl car automatically mean that you actually know something or use common sense for that matter? |
#20 | |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
I'll try the finger press thing and see.
#21 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris manual dark silver Join Date: May 2006
Where can I find the Serpentine Belt Routing Diagram?
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) |
#22 |
#23 |
Drives: Blazin' Blue Yaris Liftback Join Date: Nov 2006
help?
Any guidance on this issue would be appreciated. I have spent two hours trying to loosen the bolt at the bottom of the alternator to no avail. I have tried some pb blaster as well. I have nothing to show for my effort except sore hands. Does anyone know the trick to getting this bolt loose? The space is really awkward to get good torque so I tried a universal extension, but am still having no luck. The replacement belt only cost me $11 but paying someone else to replace it is starting to look pretty good.
#24 |
^^ Do you have a breaker bar?
#25 |
It will come loose. Initially I had to use a 1/2 " drive and move the ac line bracket. Now a 3/8 inch drive gets it.
#26 |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
What size socket is the bottom bolt? 14 seems like it is slightly loose. I cant find my 5/8 socket to try. Also have a problem getting a 1/2 inch drive ratchet in there and being so tight I dont think 3/8 ratchet will break it loose.
Any advice on breaking it loose? I wish I had air ratchet to use. |
#27 | |
#28 |
Thanks gonna go give it a try. Got 114K miles on my 2007 and belt looking tired.
#29 |
Done. Very simple job. Not as easy as my Dodge Ram. Kinda a PITA with a sideways engine. Think I got the tension good. Just a FIY found the same belt on Amazon for 11 dollars after I already bought one from Autozone for 20 w/tax with 3 year warranty
#30 |
![]() ![]() Drives: 07SedanS06Taco Join Date: Oct 2008
Whats the recommended belt brand and best place to buy it.
Thanks |
#31 |
In the South I buy from AutoZone. They always honor the lifetime warranty with no reciepts. Napa or PepBoys is a good place to buy also.
Use Part Number: 5040465 Dayco Brand |
#32 |
![]() ![]() ![]() Drives: US 2007 Yaris Liftback 5MT Join Date: Aug 2006
I think this is done and gone, but I just wanted to say that I recently did this to my Egg. She has about 90K on her and needed a new belt. The bottom bolt is on there REEEEALLY good. I had to use a socket wrench and put a tube on the end to extend the fulcrum and had to make sure the socket I was using was the exact right size.
2007 Toyota Yaris Liftback Base 5 Speed. Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust. |
#33 |
#34 |
I replaced the belt going on 6 months.
Had to tighten the belt at least 5 times due to screeching. Seems like the belt stretches a little every time. (I marked the original location of the bolt) Belt looks good, maybe this Dayco is just cheap or defective. Probably will see if I can return it under warranty. Are the gates any better or just go get the OEM from the dealer (on-line)? Can someone tell me what the actual torque for the two bolts are? Thanks |
#35 |
Got a replacement serpentine belt.
Still a Dayco but a better quality one. Store would only give me credit for the same brand. Originally went with the part number above. Didn't know they came in different grades. So far so good. Sure was easier the second time replacing. |
#36 |
![]() Drives: 2007 Yaris Hatchback Join Date: Feb 2012
Just used this guide - thanks all. Easy Peasy.
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 01:25 PM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 06:52 PM |
| revamping the DIY section | supmet | Suggestions - Feedback - Questions | 7 | 03-23-2009 02:01 AM |
| The Accessory belt? | N9QGS | DIY / Maintenance / Service | 4 | 02-12-2009 11:05 PM |
