Old 11-26-2006, 02:11 PM   #55
grimez
grimez's Avatar
Drives: 2007 Yaris
If nothing else, i might just get a cap for that spot, and disconnect the switch.
grimez is offline   Reply With Quote
Old 03-12-2007, 10:33 PM   #56
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Can someone break down the install on the led to go in the auto shifter for the liftback? I have searched the threads and the repair manual but haven't found any good instructions or a tutorial. I'm stumped.
SPONSORED BY
Old 05-22-2007, 11:11 AM   #57
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
Send a message via MSN to Sway84
hey do the 1157 eagle eye tower LED blinkers found on autoillumination work on the hatch?
Sway84 is offline   Reply With Quote
Old 05-23-2007, 12:05 AM   #58
uncleyaris
Vodka, you are the light guru!!!!!!!!!!!!!
Old 06-27-2007, 02:20 AM   #59
Jerkratt
Jerkratt's Avatar
grimez which type did u buy a? b? or c? for the a/c controls???
"It hurts more when its wet"
Old 07-01-2007, 04:18 PM   #60
Farenheit
Drives: Yaris T3
Hi Guys,
After a long hard read.. can someone tell me how many led's i need per knob?
Also will these be ok:
http://cgi.ebay.co.uk/10x-T5-286-Col...QQcmdZViewItem
or
http://cgi.ebay.co.uk/2pc-dashboard-...QQcmdZViewItem
or
http://cgi.ebay.co.uk/2X-RED-T5-LED-...QQcmdZViewItem
Thanks
FH
Farenheit is offline   Reply With Quote
Old 07-02-2007, 09:02 AM   #61
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Originally Posted by vodkalush View Post
....... so I got mine from*http://autolumination.com/74.htm (from a link in either this thread or a diff one... cant remember and dont care to look ) they where "Neo - Wedge Instrument Panel Bulbs" leds.
(from earlier in thread)
will work for parts
vodkalush is offline   Reply With Quote
Old 07-02-2007, 01:46 PM   #62
Farenheit
Drives: Yaris T3
It will be cheaper and quicker for me to purchase from somewhere in the UK hence the UK (ebay) links.
I know i can get them from autolumination.
I still dont know how many bulbs there are per knob.
Can someone check those links for me and tell me if any of those are any good?
Regards
FH
Old 07-02-2007, 02:02 PM   #63
vodkalush
I drive a yarrrris
vodkalush's Avatar
sorry, didnt even look at your local.
Each knob only has 1 light in it. And you can search ebay for "Neo - Wedge Instrument Panel Bulbs." just be-sure that they are the correct ones if you get from ebay
will work for parts
Old 07-02-2007, 05:31 PM   #65
Jerkratt
Jerkratt's Avatar
i just got mine from autolumination.com and there is 1 led per knob
Old 07-03-2007, 06:50 AM   #66
vodkalush
I drive a yarrrris
vodkalush's Avatar
bulb:
led:
is how the LED/Bulb needs to look for the temp controls
the you listed look like the one needed for the shifter light (gear selection light-up on automatics)
will work for parts
Old 07-03-2007, 06:54 AM   #67
vodkalush
I drive a yarrrris
vodkalush's Avatar
Once again if you go with a bulb it needs to be:
and if its a led:
Neo - Wedge Instrument Panel LED Type A/B (C should work aswell)
will work for parts
Old 07-22-2007, 08:43 PM   #68
manborn
are u still 34/39?
manborn's Avatar
Drives: flint mica yaris s sedan
does this also apply to the sedan? i mean, if it's similar changing the
LED Center Control Colour,Panel Removal
manborn is offline   Reply With Quote
Old 10-29-2008, 02:46 AM   #69
DerKaiZeRs
-YaRiS OwNeR-
DerKaiZeRs's Avatar
Drives: YRS Sedan
well... this thread already 2 years old.. and no one reply on this thread ever since...
but.. I hope someone read mine and reply this
Is there any change I can change the LED behind the speedometer??
mine is yellow and I want to change it into blue...
DerKaiZeRs is offline   Reply With Quote
Old 11-11-2008, 03:34 AM   #70
DerKaiZeRs
-YaRiS OwNeR-
DerKaiZeRs's Avatar
Drives: YRS Sedan
up up up.... :o
Old 01-31-2009, 09:59 AM   #71
ZING
ZING's Avatar
Drives: Yaris '09,GTi '09, BMW 3.30ci
bump
ZING is offline   Reply With Quote
Old 02-14-2009, 04:38 PM   #72
pariahdecss
Yarisomniac
pariahdecss's Avatar
Drives: 2009 5spd LB
Yes it can be done in the 09 - I just changed my speedo gauge backlighting from orange to blue using these from eLed :
http://www.eled.com/product.asp?cata...d=epl3015pbc-a
They are slightly bigger than what Vodkalush recommended in his DIY but they worked fine and were easier to work with (slightly). The problem I ran into was the clock on the base 09 LB gets its color from the plastic housing it is in, so changing the LED's would not fix that. What I did was buy some blue 1/8 inch transparent plexiglass and use that to change the clock color. I cut out a window in the orange plastic part around the clock and replaced it with a small piece of blue plexi that I got here:
http://www.estreetplastics.com/Trans...Sheet_s/58.htm
Cost me like $3 plus the LED's and overall was pretty easy - Use search to find the DIY from others that changed their gauge color lighting
pariahdecss is offline   Reply With Quote
Accessory Bulb Types, anyone know? Ayka Cosmetic Modifications (Exterior/Interior) 135 04-29-2007 08:33 AM
