Old 09-25-2009, 05:54 PM   #19
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I just notified MikeNST about this issue. Hopefully he'll chime in soon.
Old 09-25-2009, 05:54 PM   #20
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Maybe we can all agree it is the combination of the pulley or belt too tight and the harsh driving?
Old 09-25-2009, 06:06 PM   #21
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
if you say so.
the ratio of water pump failures stock vs pulley tells the tale..
Could it be due to people over tightenning the BELTS
Old 09-25-2009, 06:06 PM   #22
rhino5
Drives: '08 hatchback, '90 325i 'e30'
Just a lightweight pulley or an underdrive pulley?
Pulley driven water pumps are really that mysterious, mechanically there's not much to fail. I'd blame shitty casting or belt tension before blaming pulley ratios.
rhino5 is offline   Reply With Quote
Old 09-25-2009, 07:35 PM   #23
YarisSedan
Drives: 08 Yaris Sedan
Well to me it just seems very strange within a month the water pump failed. And my original water pump did not fail until after the pulley was installed as well. When i changed the pulley i marked the altenator position with a white out so that it was isntaleld in the exact same position as factory. I am going to go check the tightness of the belt after the water pump was instaleld by the dealer. If it was put on way to tight and compounded with how i drive i would say that would be the cause this time. Or a combination of the pulley and overtightend.
Old 09-25-2009, 07:38 PM   #24
severous01
does the oem pulley have a rubber ring in it? a dampner?
if it is, then the NST doesnt have a dampner. every time the pulley hits TDC or BDC you're slamming the pulleys on all devices and as the pulley rotates towards bdc or tdc the pulleys are slowing down. that's what the dampner does....dampen the force of the engine 'bang' to equalize throughout the rotation.
Old 09-25-2009, 07:42 PM   #25
YarisSedan
Yeah the factory one has a rubber one in the middle.
Old 09-25-2009, 08:50 PM   #26
severous01
there's your problem. the nst pulley is not a dampner. it's just a pulley.
the rubber ring flexes on the bang and flexes back on compression. so................................................ .................................................. .................................................. ......
deal is, the pulleys are actually moving forward and backwards at an extreme rate and that's not designed to do it. the dampner stops it and prevents the bearings from slamming forward and back.
Old 09-25-2009, 11:40 PM   #27
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
I beg to differ. This is a typical mistake people make, just because there is a correlation between A and B it doesn't mean A caused B or vice versa.
Let me explain with an example: studies show that households with more books have smarter kids (correlation between books and kids), so a mayor in Illinois thought he'll simply give away free books and make kids smarter. Needless to say, the plan didn't work. Because it's not the number of books that cause the kids to be smart, it's their parents' education, status, emphasis on school, etc. And those families are likely to have more books to begin with. So, there is another parameter C that causes both A and B to go together.
Back to our situation: people with aftermarket pulleys have more water pump failures than the ones driving stock (that's the correlation). So some people incorrectly infer that the pulleys must cause the failure.
Imagine this: people who install aftermarket parts and tune their cars are more likely to drive their cars more aggressively, therefore putting more stress on their parts than those driving stock (grandma, grandpa, uncle Jimmy).
Just remember the basic principle: correlation does not imply causation. For more details check it out on Wikipedia: Correlation does not imply causation
fmicle is offline   Reply With Quote
Old 09-26-2009, 01:08 AM   #28
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Wisdom
Old 09-26-2009, 02:24 AM   #29
YarisSedan
Yeah but even a car driven agreesively shouldnt have parts like this failing at such a early stage. Maybe at higher milage i could understand but this is just unacceptable.
My 89 acura legend with 200k miles was a tank. I drove it like i stole it for 4 years and never gave me any problems. Only thing major was the altenator that went out once and i attribute that to my high powered stereo system.
And this a toyota which is supose to be better than honda is having problems like this at such a early stage seems unacceptable to me. So even if i put the factory pulley back on and still drive the car aggresively that means i will be having to change my water pump every single year?!?
I know its a econo car but come on.
Old 09-26-2009, 04:10 AM   #30
eddy
love to drive
Drives: 2010 yaris sedan
just wondering what is this other pulley you are all talking about.?
eddy is offline   Reply With Quote
Old 09-26-2009, 05:09 AM   #31
JohnnoEH
Drives: 64 Holden 82 Stanza 07 Yaris
There is another parameter C that causes both A and B to go together.
I was going to write pretty much exactly this, but you beat me to it. So many people jump to quick conclusions without looking at the whole picture.
Having said the above, this could be the source of the problem; especially when combined with the more likely/frequent hard driving that a modded car will receive.
JohnnoEH is offline   Reply With Quote
Old 09-26-2009, 07:35 AM   #32
undampended pullies eat water pumps....ask anyone w/ a 2zzge..
Old 09-26-2009, 10:32 AM   #33
rhino5
I find it hard to swallow that the small change in ability to dampen on the crank pulley with a rubber belt driven system could destroy a waterpump so easily. If I was ambitious I'd look up what the flex per foot of our serpentine belt has and I'd be surprised if it was so ridged that it wouldn't absorb some of this "destructive" torque/vibration.
Not saying that is without a doubt the problem, but I'd be leery that it's the new pulley.
Old 09-26-2009, 11:10 AM   #34
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Could it also be that you got a faulty part?
Old 09-26-2009, 11:16 AM   #35
rhino5
I mentioned this before. Casting metals yields a relatively high chance of poor quality.
Old 09-26-2009, 02:56 PM   #36
fmicle
fmicle's Avatar
I hear you man, I hear you, and I agree it's unacceptable...
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Water pump belt and pulley - replaced at 36,000mi cleong DIY / Maintenance / Service 3 03-06-2009 12:12 AM
bye bye water pump cali yaris Performance Modifications 29 01-03-2009 05:06 PM
