#199 |
Heart Up! Vitz
I have someone on here who is test fitting a 09 w/ ABS cluster on his 07 non-ABS car....I'll let you know whether it works or not..
But: 08 w/ ABS accepted my RS cluster. Scott's 08 w/o ABS didnt accept it His 09 with ABS did... So i highly doubt yours would accept a cluster w/ a tach...speed data won't be sent the same way like it is through the speedometer only cluster~ jus saving you the trouble and money... But go for it, we already have 2 other guinea pigs on here hahaha |
#200 |
Our off road vehicle
Drives: 2009 Yaris 3dr Join Date: Apr 2009
R.I.P. Oz Cluster
#201 | |
#202 | |
pink wheels are cool
but would it have the issues with the read outs? like say an 07 sedan with an 07 liftback? |
#203 |
I was just looking at sedan cluster pictures on ebay and the sedan one is a very different shape than the LB one.
#204 |
ok get back to making the tach fit the clock area
#205 |
#206 |
Heart Up! Vitz
#207 |
I hooked it up to my test bench last night and had the same result with making the speedo change but the odo didn't increment. I just need to get to the bottom of the extra bytes in the speed message.
#208 |
Heart Up! Vitz
Did your 09 send any additional messages from my RS cluster that could help you out with that? I know you said you were going to try that out in my thread...dont know~
#209 |
My 09 sent the same data to both its own cluster and to your RS cluster. It's entirely possible that the odo increment data is sent in an entirely different message. I have 11 more messages from the 09 data capture to decipher.
#210 |
Scott - what about starting a new thread keeping us informed on the progress and release of the Yargauge? It seems like the best answer for so many of us who want a tach but within the confines of the existing OEM cluster setup (i.e. not a separate tachometer on the dash and don't want to have to mess with the odometer flashing.
This thread on the OZ cluster is about as dead as a doornail. |
#211 |
Maybe for you but not for me. I'm hoping Scott can figure out a way to make the Km/L and gear display work.
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
#212 |
sorry Tony- my mistake in wording- I just meant that for all the folks looking for a tach in the cluster it was dead- not dead for everyone.
#213 | |
The YarGauge has its own thread that I update. Lewis, If you don't mind I'll attempt to make the necessary modifications to make the OZ cluster visible to the USDM driver. |
#214 | |
Based on the reverse engineering that I've done so far on the clusters, I believe that we will find that the ECM does the calculations and sends the message up to the cluster. I just need to figure out the message ID and packet structure of that message, as all of the data needed to do the calculation is already available. |
#215 | |
All I can find is you tube videos of it working.... Gear Display works It appears on this one the Km/L works as there is something lit up under the clock I don't think any of these guys are on the forum and from what I understand the Km/L and Gear display works in Europe and I ain't anywhere near Europe.
#216 | |
| DIY - Change your Gauge Cluster Color | vodkalush | DIY / Maintenance / Service | 89 | 04-29-2019 09:41 AM |
| FS: Gauge Cluster from '09 LB- $150 | MGargano | Items for Sale by private party | 14 | 10-05-2009 12:59 PM |
| Shifter knob/gauge cluster color | DevilGirl | Cosmetic Modifications (Exterior/Interior) | 3 | 08-11-2009 10:18 PM |
| Sedan Instrument Cluster to LB Instrument Cluster | Malaya1221 | Cosmetic Modifications (Exterior/Interior) | 2 | 12-02-2008 10:05 PM |
| CLUSTER LIGHTS WENT OUT | Go4th | DIY / Maintenance / Service | 23 | 01-25-2007 11:37 AM |
