#181 |
Update: I received the OZ cluster from Lewis today!
I immediately had to open the box and hook it up on Crashy. With the swapped connectors (since it is for a RHD Yaris) I just hooked up connector D1, which has power, CAN bus, fuel gauge, tach, speed, etc (the other just has the feeds for a bunch of the indicator lights). It powered up fine and the fuel gauge showed proper level. So, I started the car and the tach worked correctly, but the speedometer stayed at zero. This cluster is off an ABS car, so that makes sense, as Crashy is non-ABS. The issue though is that the cluster is indeed angled to... the passenger (at least on this side of the world). The VFD (vacuum fluorescent display) is reversed and is mounted in that chunk at the bottom and is pointed to the left. A concave mirror magnifies and inverts the VFD and angles the display to the USDM passenger. Being an Engineer, I just had to take it apart to see how it was setup and to snap some pics. Here they are: Powered up: OZ On.jpg Close up of the VFD: OZ VFD.jpg Close up of the clock/mileage VFD: OZ VFD clock.jpg Concave mirror: OZ Mirror.jpg |
#182 |
So could you transplant the guts of the aussie cluster , into the USDM
unit , or is it not that easy
#183 |
The USDM one is just a flat plane. The Aussie one has the lens in the same place, but the guts and case are completely different to make the VFD work correctly. I was initially thinking that you could modify the bottom chunk and the back to point towards the left, but the upper portion has a molded tunnel that is angled from left to right. It would take some creative plastic work to make the display point left.
#184 |
Scott and Lewis,
Glad it works. Looks like some more work is required to make it useable for you though. Scott, I know you just got the unit, but is there any chance of a fix so the Km/L would work for us Aussies?
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
#185 |
I think this picture sums up this thread.
#186 |
#187 |
Heart Up! Vitz
sedan cluster should be the same size as the liftback cluster, but the plugs to connect are different from the liftback......
Also.....is your car ABS enabled kustom? If not, you will run into problems like Lewis and I.... :P |
#188 |
Heart Up! Vitz
I have someone on here who is test fitting a 09 w/ ABS cluster on his 07 non-ABS car....I'll let you know whether it works or not..
But: 08 w/ ABS accepted my RS cluster. Scott's 08 w/o ABS didnt accept it His 09 with ABS did... So i highly doubt yours would accept a cluster w/ a tach...speed data won't be sent the same way like it is through the speedometer only cluster~ jus saving you the trouble and money... But go for it, we already have 2 other guinea pigs on here hahaha |
#189 |
Our off road vehicle
Drives: 2009 Yaris 3dr Join Date: Apr 2009
R.I.P. Oz Cluster
#190 | |
#191 |
I was just looking at sedan cluster pictures on ebay and the sedan one is a very different shape than the LB one.
#192 |
#193 |
Heart Up! Vitz
#194 |
I hooked it up to my test bench last night and had the same result with making the speedo change but the odo didn't increment. I just need to get to the bottom of the extra bytes in the speed message.
#195 |
Heart Up! Vitz
Did your 09 send any additional messages from my RS cluster that could help you out with that? I know you said you were going to try that out in my thread...dont know~
#196 |
My 09 sent the same data to both its own cluster and to your RS cluster. It's entirely possible that the odo increment data is sent in an entirely different message. I have 11 more messages from the 09 data capture to decipher.
#197 |
Scott - what about starting a new thread keeping us informed on the progress and release of the Yargauge? It seems like the best answer for so many of us who want a tach but within the confines of the existing OEM cluster setup (i.e. not a separate tachometer on the dash and don't want to have to mess with the odometer flashing.
This thread on the OZ cluster is about as dead as a doornail. |
#198 |
Maybe for you but not for me. I'm hoping Scott can figure out a way to make the Km/L and gear display work.
| DIY - Change your Gauge Cluster Color | vodkalush | DIY / Maintenance / Service | 89 | 04-29-2019 09:41 AM |
| FS: Gauge Cluster from '09 LB- $150 | MGargano | Items for Sale by private party | 14 | 10-05-2009 12:59 PM |
| Shifter knob/gauge cluster color | DevilGirl | Cosmetic Modifications (Exterior/Interior) | 3 | 08-11-2009 10:18 PM |
| Sedan Instrument Cluster to LB Instrument Cluster | Malaya1221 | Cosmetic Modifications (Exterior/Interior) | 2 | 12-02-2008 10:05 PM |
| CLUSTER LIGHTS WENT OUT | Go4th | DIY / Maintenance / Service | 23 | 01-25-2007 11:37 AM |
