View Poll Results: Would you buy one?
No 5 5.10%
Yes (for $75) 46 46.94%
Yes (but it would have to be less than $75) 7 7.14%
Yes (but I still want it to also display the time) 40 40.82%
Voters: 98. You may not vote on this poll
Old 01-22-2010, 12:56 PM   #235
Originally Posted by dean_park View Post
Hi Scott,
For the mi/km to empty feature, I think the cars that have this built in average this. Most times when the mpg feature is installed in the car, it has two screens instantaneous and average. I think the mi/empty is based on the rolling average so the value doesn't increase based on acceleration/cruise/coast/idle, etc. I'm not sure if it's possible in the controller you are using, but if so, can it be based on an average?
Doesn't matter... I'm still gunna buy it and I can ignore the value while accelerating.
I was working on the interface to the fuel level wire last night. and was thinking about that. I agree that the data needs to be averaged, otherwise the miles until empty would bounce all over (from 80 miles with a full tank while goosing it, to infinity when in DFCO).
Old 01-22-2010, 03:48 PM   #236
127.0.0.1
great video of the first steps needed on removing the front plastics
to get to the gauge cluster.
http://www.youtube.com/watch?v=nBTIJLk-EZo
Old 02-01-2010, 05:22 AM   #237
goku87
goku87's Avatar
Drives: Black HB
Just lookin for an update.
goku87 is offline   Reply With Quote
Old 02-01-2010, 06:54 AM   #238
Just waiting for the final revision of the circuit boards to come in. The latest rev adds the fuel level in gallons/liters and range until empty.
Old 02-01-2010, 09:48 AM   #239
POORSHA
POORSHA's Avatar
Drives: 2008 LB
with all the revisions will this unit be able to do my daughters math homework ?
POORSHA is offline   Reply With Quote
Old 02-01-2010, 09:53 AM   #240
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
cool im excited to pick one up!
http://www.4055design.com
Old 02-01-2010, 09:58 AM   #241
I think so. Accuratizing of the fuel gauge data has even required the use of some calculus.
Old 02-01-2010, 12:46 PM   #242
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Sorry if this is either too late or stupid, but is it possible to get the air-to-fuel ration and the ignition timing?
And what's the refresh rate or response time for this thing?
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Old 02-01-2010, 01:41 PM   #243
cowboy
Drives: yaris CE 2007
Question YarGauge
hi CTScott
can the YarGauge be converted to Metric Canadian units like km's & such ....if so i really like to buy one ...thanks
looking also to adapt my laptop & tower PC to become a temp. OBD11 scanner , what can u do here CTScott
cowboy is offline   Reply With Quote
Old 02-01-2010, 01:49 PM   #244
Originally Posted by cowboy View Post
hi CTScott
Yes, it will be configurable for US/Metric units.
A USB laptop interface will also be an option for the YarGauge. The laptop interface will provide data logging capability of all of the parameters that the YarGauge displays, plus as I figure out more Toyota specific things (like perhaps being able to enable or disable the seatbelt chime), those features will be added to the software for the laptop interface.
Old 02-01-2010, 01:55 PM   #245
Any software only additions are still possible at this point. The hardware is frozen, but the SW is not.
Air to fuel ratio is not a standard PID for OBD, but the ECM does monitor it. If I can figure out how to make the ECM tell it to me, then I can add it.
Ignition timing advance is a standard PID, so that one is an easy add.
Right now I am running with the refresh rate at 4x per second (2x that of the scangauge). I can go wayyyy faster, but then the values become a blur.
Old 02-01-2010, 02:27 PM   #246
fmicle
fmicle's Avatar
Oh man, if I were living close by, I'd be begging you to let me assist you... even if that meant only bringing you coffee and donuts
Old 02-01-2010, 02:29 PM   #247
Mateo
Drives: Blazing blue 08 LB
This has became one of my favorite threads to check. One question I did have, is this going to be a one time production run or will they be available past the fist run?
Mateo is offline   Reply With Quote
Old 02-01-2010, 02:36 PM   #248
wow, 14 pages to read oh brother lol. Wanna make it easy for me Scott? Any chance of one with A/F and Boost in the mix of ideas for this in the future. Or have I stepped in a pile of words already spoken? Thanks.
Old 02-01-2010, 02:45 PM   #249
It will continue to be available after the first run.
Old 02-01-2010, 02:49 PM   #250
A/F was just asked a couple of posts above. It is a maybe depending on if I can figure out the CAN command to get the ECM to give it to me (as it isn't a standard OBD PID). Boost would be a no, as it requires adding a pressure sensor.
Old 02-01-2010, 02:57 PM   #251
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
image this all started with needing a tachometer!
from tiny acorns grow mighty oaktrees.
Lewis is offline   Reply With Quote
Old 02-01-2010, 03:25 PM   #252
tk-421
tk-421's Avatar
Drives: 5D-07-LB
@CTScott: You are the MAN! Please let me know when I can snatch one of those OBD modules of yours, since my carpc needs a fast one (the ELM unit I bought does not refresh quickly enough for me).
in dash clock as tach? Cosmonaut In Car Entertainment + Electronics (audio / video / alarm) 10 07-12-2010 11:27 AM
digital tach, 52mm, preferably blue leds severous01 Cosmetic Modifications (Exterior/Interior) 5 05-15-2009 10:58 AM
Digital Tach nqd Performance Modifications 4 05-17-2007 12:04 PM
