Old 03-08-2010, 07:24 PM   #1
xxae07xx
hook em
xxae07xx's Avatar
Drives: black 08 lb
NEW SUSPENSION MODS!
upgraded rear springs to Skunk2 Fit springs and raised rear rates up from tanabe 2.2 to a beastly 6.2! then added some PG 13mm spacers and some EZ shims from MI. wheels are 15x6.5 +38
xxae07xx is offline   Reply With Quote
Old 03-08-2010, 07:46 PM   #2
XYaris
Drives: '09 Yaris LB
keeping the angle consistent with the pics would be a more 'honest' way to demonstrate the change, but the spacers look dope. nice
XYaris is offline   Reply With Quote
Old 03-08-2010, 08:49 PM   #3
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
what springs are you running in the front?
aeipee13 is offline   Reply With Quote
Old 03-08-2010, 09:45 PM   #4
enviri
enviri's Avatar
Drives: 2010 Yaris
did you have to modify those fit springs?
Old 03-08-2010, 10:12 PM   #5
xxae07xx
hook em
xxae07xx's Avatar
Drives: black 08 lb
well..i "honestly" tried to get the exact same angle with the before and afters guy excuse me for being a little off....but the fronts are tanabe dfs and no i didnt have to modify the skunks to make them fit. unfortunatley they did create some unsightly wheel gap so i went against all things holy and trimmed them lol
Old 03-10-2010, 05:36 PM   #6
kngrsll
Apexing Egg!!
kngrsll's Avatar
nice to see someone else doing this! I got rear Fit springs from A&J racing and have been running them since september... great setup!
how much did you trim? I took a half a coil off
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 03-10-2010, 05:41 PM   #7
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
CUT SPRINGS??? is that safe???
Old 03-10-2010, 05:51 PM   #8
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
supposedly it is not safe... heating up the coil to cut it makes the metal brittle, and the shorter length, messes it up if it's progressive rate springs. Just what I read somewhere, but it makes sense.
Old 03-10-2010, 11:08 PM   #9
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
I have cut springs before they don't heat up that much depending on what you cut them with. I use an airpowered cut off wheel and it only heats up a tiny bit.
Old 03-10-2010, 11:23 PM   #10
xxae07xx
hook em
xxae07xx's Avatar
Drives: black 08 lb
i used a 4 inch grinder for lack of a better means and i took about a half coil. kngrsll you were my inspiration! i was wondering if you had to trim also. lol glad to see im not the only one doing something so taboo
Old 03-11-2010, 12:18 AM   #11
YAR1S
YAR1S's Avatar
side views maybe to see the drop????? :(
-Jen <3
Old 03-11-2010, 01:14 AM   #12
xxae07xx
hook em
xxae07xx's Avatar
Drives: black 08 lb
yea ill snap a few side shots in the morning w/ tanabe vs. skunks
Old 03-11-2010, 11:43 AM   #13
xxae07xx
hook em
xxae07xx's Avatar
Drives: black 08 lb
okay here are some side pics. the gap isnt as bad as i thought only a half inch, but it still looks like a 4x4 compared to what im used to looking at lol. keep in mind im running 195/50s and the springs havent settled yet, though i doubt the settle much being so stiff. the side by side of the springs doesn't really show how short they are either. they are easily an inch or more shorter.
Old 03-11-2010, 04:16 PM   #14
CtrlAltDefeat
I ♥ Yaris
funny how the skunks look shorter, but the tanabes are a lower drop. I guess the Tanabes must be a lot softer...
Old 03-11-2010, 04:45 PM   #15
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Well, the skunk2's still need to settle... I'm guessing they'll drop a bit more in the coming weeks.
I like how these new ones look.
Old 03-11-2010, 05:43 PM   #16
kngrsll
Apexing Egg!!
kngrsll's Avatar
its all math dudes... http://www.engineersedge.com/calcula...spring_pop.htm
the tanabe spring is 125 lbs, the fit spring is 300 lbs. thats 2.5 times as much! that is a huge difference.
and cutting it is not going to harm a thing, that is a crazy myth perpetuated by spring companies to make money. now, applying heat to compress coils, that may be dangerous.
great job! any plans on what to do next? i ended up using generic coilover perches on the front with 375 lb springs and putting the rear sway bar back on. although i have not tracked it yet with this set up, i can tell you, it will be good!
Old 03-11-2010, 05:54 PM   #17
xxae07xx
hook em
xxae07xx's Avatar
Drives: black 08 lb
well correct me if im wrong but i thought for fwd cars in order to reduce understeer one would use stiffer springs in the rear and softer in the front...thats why i didnt go ahead and beast up the fronts...but if i am incorrect then perhaps something similar to your setup will be in my future
Old 03-11-2010, 07:41 PM   #18
kngrsll
Apexing Egg!!
kngrsll's Avatar
i have battled with that thought...
some schools of thought think stiff rear on FWD is better, some think not. when i tracked the yaris the first time, it was on tanabes and had the 23 mm rear bar. the car was great, balance perfect, and a blast to drive. i put the stiff springs on the rear, i never got to track it, only autox. and i wasnt real sure i liked it. so i did the suspension like i have it now, and i think its better. next time i go, i plan on swapping parts on different days and trying it out.
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 10:26 PM
Suggestions for $300-$400 worth of mods please! CtrlAltDefeat Performance Modifications 51 01-05-2011 10:15 AM
Sedan owners with full suspension mods? specifically all TRD AdeJong 03 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 05-15-2010 01:13 PM
mods! mods! mods! canadian_princess Cosmetic Modifications (Exterior/Interior) 32 08-23-2009 05:52 PM
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 01:32 AM
