Michael
Drives: 07 Silver Yaris Sedan Join Date: May 2007
Custom Exhaust...could use some input
I cant find too much on the flowmaster 60 series of mufflers around here...yes i have searched. after debating for a long time on whether i should go axle back from garm or custom cat back, i've decided to go custom. my initial plan is to go 2.25 pipe stock res and run the flowmaster 60 muffler. has anybody heard these mufflers on a yaris in real life? i'm wanting a good deep aggressive sound without being loud and doesn't drone while cruzin. if you think there is any out there better than the flowmaster let me know :)
![]() ![]() ![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2007
I have the Tanabe Medallion which is advertised as "discrete" and "under 93 db" and is hecka loud
Compared with the stock exhaust anyways. I sound-proofed the floor in the rear which improved the noise level in the cabin a bit, but it's still hecka loud
5% Tint Rear | Micro Image LED Ignition Light Kit |
toyota
2.25 is too big for this car if you dont have other major upgrades.. 1.75-2.0 diameter is better..but thats just me..
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
i think the nitto mid pipe is 2 inches, like marcus said i wouldn't go any bigger than that
Michael
thanks guys :) i can do 2in no problem. now does any know about the flowmaster 60 series and how it will sound?
2" is good, you'll retain some back pressure and maximize your hp gains.
I used that muffler before, nice rich deep tones. I use Vibrant now, but the Flowmaster is very good.
![]() ![]() ![]() Drives: 07 liftback Join Date: Nov 2008
i'll try to post up some video clips foryou, but I ran the 60 for over a year, and loved every part of it. It sounds perfect (as do all flowmasters) at full throttle, but being a 60, it was not just subtle, it sounded almost exactly stock at idle. I'm a big fan of that, cuz i hate sitting at a light listening to my muffler, ya know? I think it's the best sounding thing out there personally, but that's your call.
http://vids.myspace.com/index.cfm?fu...deoid=32350826
stock exhaust http://vids.myspace.com/index.cfm?fu...deoid=32351315 straight pipe (no muffler at all, ran on a 2'' pipe) http://vids.myspace.com/index.cfm?fu...deoid=32352422 60 series on a 2'' pipe I included the stock so you could tell the difference, since my camera sucks nuts, sorry bout that!
Michael
thanks alot for the sound clips Shinlee
alright so i'm def goin with 2in piping and more han likely the 60 series thanks to Shin. next ? is should i keep the stock res or go with a glasspack in its place? what exactly would the glasspack do to the sound? and how long of a glasspack should be used? |
well, if you want the drivability (i.e. less noise when you're cruising at highway speeds) the stock res is fine. Hell, irregardless, the stock res is fine if you're running a 2'' pipe. I personally looked at it myself before my exhaust was put in, and it is a straight flow through 2'' center resonator. (That's why I chose 2'', no point going bigger than the smallest point on the system, ya know?) So a glasspack or stock res should net exactly the same power, just differnt noises :)
Michael
what kind of noise difference would the glasspack make? louder or quieter? deeper maybe?
my personal experience is it makes it louder, but you wouldn't get much deeper just due to the motor i'd imagine.
Michael
thanks for all your help shinlee, i appreciate it. you too garm :) last question is i'm not 100% sure on the order of things on the stock exhaust. is there just one resonator after the cat or two? if there are two then which one would i want to replace with the glasspack?
#14 | ||
![]() Quote:
http://www.flowmastermufflers.com/sh...oducts_id=2299
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#15 |
the stock resonator on the yaris is fed by a 2'' inlet/outlet resonator. The piping ahead of the res is 2'', but behind it it drops to like 1 3/4'' or something, that's why I went 2'' on from my res back to the 60 which was a 2'' inlet/outlet as well :)
#16 |
![]() 60 series ![]() straight pipe make sure when you're having your 60 installed, try to find a better mount point than my muffler guy did, I had to go back and fix it up later. A little more time in planning makes for a better placement, cuz it's a tight fit in there, especially when lowered on df210's
#17 |
exhaust velocity is more important than "backpressure"
#18 |
Michael
thanks for the pics! i was hoping i could use the center inlet offset outlet 2in style and fit it in like this one...http://www.yarisworld.com/forums/sho...hp?t=9520...do you think it would fit?
| Custom 1.75" catback exhaust - worth it?? | fuji | Performance Modifications | 4 | 05-09-2009 07:46 AM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 10:23 PM |
| Custom exhaust or pre-made exhaust - which one makes more power? | fuji | Performance Modifications | 9 | 03-08-2009 01:24 AM |
| Custom Cat-Back exhaust Yaris TS | CASTREX | Yaris TS Talk | 16 | 10-24-2008 01:56 PM |
| How much has your custom exhaust cost you? | whooppee777 | Performance Modifications | 7 | 07-21-2007 12:20 PM |
