Old 09-05-2010, 07:24 AM   #1
vitz rs
Drives: Vitz RS turbo M
Top mount or front mount intercooler
Hi,
i am driving a 08 vitz turbo. It has a top mount intercooler.
The top mount intercooler obstruct the ignition coil and spark plugs.
I am thinking of converting it to a front mount. However, my concern is
will it cause any turbo lag as the distance for the compressed air to reach the throttle body has lengthen.
Or should I keep it as top mount.
Anyone has experience on that?
vitz rs is offline   Reply With Quote
Old 09-05-2010, 10:46 AM   #2
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
I had a Suby WRX and I converted from the stock top mount to a much larger front mount. I'm talking like three times the size. It added considerably more lag. But it worked so well that when the boost did hit it hit very hard. I have mounted a front mount on my Yaris and although I realy havent gone on the gas much yet, I can tell U the lag is not nearly as bad as the Suby. But I have a smaller turbo that spools fast and a much smaller cooler then that Suby. The front mount I bought wich fits perfect in the yaris is 28"wide 5.5"tall 2.5"thick.
pimp my yaris is offline   Reply With Quote
Old 09-05-2010, 11:10 AM   #3
Focus_Sh1ft
Focus_Sh1ft's Avatar
Should just be a matter of choosing a front mount intercooler that isn't stupidly large. If you check out Bluevitz-rs' thread regarding his Greddy install, you'll see that he was losing a substantial amount of power with a top mount at the low end. Plus, let's be real here, front mount intercoolers are sooooo much cooler.
Old 09-05-2010, 01:55 PM   #4
vitz rs
Thanks for the advice.
Guess that would be it. Will change to a front mount.
Cheers.
Old 09-09-2010, 03:01 PM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Correction, the kit had NO intercooler. I was toying with the thought of adding an air to water intercooler because of space savings and efficency but ran out'a $$.
Old 09-09-2010, 06:03 PM   #6
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
An FMIC might lag more, however that would easily be overcome from the gains by getting cooler air. Just do it right, and you should be fine.
Colin Chapman disciple
Old 09-11-2010, 07:09 PM   #7
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
so, you're moving the intercooler because it obstructs your coilpacks?
do you remove your coilpacks every weekend or something?
Originally Posted by xnamerxx
you nailed it sir.
Tamago is online now   Reply With Quote
Old 09-11-2010, 10:05 PM   #8
I had no problems with lag on mine with the GT2554R turbo
Old 09-12-2010, 11:41 AM   #9
vitz rs
Nop. It is not that.
1st of all, with a top mount you can't install strut bar.
2nd, when u want to do anything around the engine bay, you will have to remove lots of things. Even with normal servicing, i will need to pay more for labour.
Cheers.
Old 09-13-2010, 06:50 PM   #10
Tamago
Tamago's Avatar
Drives: ZZW30
Cheers.
1st of all, the strut bar on a yaris is useless
2nd, what normal servicing would require the removal of your top mount? oil change? don't think so.. spark plugs? good for 100,000 miles..
3rd of all, labor will be based on a book, written SPECIFICALLY for your car, and will include the labor/time required to remove the IC if required, to do the work. this means that even if you swap to a front mount, you're still going to get the top mount quote from a service tech, because that's what is in his book.
just give us the real reason you want a front mount and i'll quit harassing you (you want people to see it) lol
you nailed it sir.
Old 09-14-2010, 06:31 AM   #11
vitz rs
Hmm.... Regarding the
1. Strut bar, I doubt it's useless as I used it on my last ride, it did improve handling somehow.
2. changing of spark plugs can be DIY, and of course cleaning the engine bay
will be easier. Besides, the temperature near equator is around 32-34 whole year through and that makes the engine bay real hot. Hence, with the top mount (no scoop or vent on bonnet), there's only hot air going into the engine.
3. Lastly, in Singapore, workshops don't charge according to the amount of work they carry out and not according to the book.
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 09:47 AM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 10:03 AM
"Parmas" Motor Parmas Forced Induction Forum 511 12-01-2011 09:00 PM
WTB: Front License Plate Mount and OEM wheels/tires Snarf77 Willing to Buy by private party 3 07-23-2009 01:43 PM
DIY Camera Mount -- No Cost Version KCALB SIRAY DIY / Maintenance / Service 20 06-08-2009 04:12 PM
