Old 10-15-2010, 10:04 AM   #1
mudi
Drives: Vitz 2005 model
Exclamation HELP!!! My Vitz/yaris acting weird
I made video of my vitz acting strangely can any one help to fix this problem ...Thanks in advance... my vitz is 2 year old
http://www.youtube.com/watch?v=O6nEgdYWG7o
mudi is offline   Reply With Quote
Old 10-15-2010, 11:45 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
That's a computer issue if I've ever seen one.
if I recall you can unplug the battery to reset the ECU.
Old 10-15-2010, 12:10 PM   #3
mudi
i tried resting ECU but no luck :(
Old 10-15-2010, 12:17 PM   #4
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
One word...possession.
chrisj is offline   Reply With Quote
Old 10-15-2010, 12:45 PM   #5
mudi
@chrisj lol I also thaught of that too
Old 10-15-2010, 01:20 PM   #6
Astroman
Modded Moderator
Astroman's Avatar
Gotta be electrical, but where?
Old 10-15-2010, 01:29 PM   #7
llewellyn
Drives: 04 Echo
CTScott might know what to do..
llewellyn is offline   Reply With Quote
Old 10-15-2010, 01:47 PM   #8
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
idle speed sensor??? thought its a bit weird...
monchito18 is offline   Reply With Quote
Old 10-15-2010, 02:37 PM   #9
Have you installed a remote starter, alarm system, fog lights, or anything else which would have required tapping wires? The automatic transmission shift supplies a signal to the ECM indicating what position it is in. It is a simple switch that in each position directs a +12V signal to a different wire and the ECM has a pin for each shift position.
If I had to guess, I would say that somehow the brake switch or tail light feed got joined to one of the shift selector output wires and is confusing the ECM.
Old 10-15-2010, 02:37 PM   #10
mudi
@monchito18 no when its idle its normal when i hit brake it accelerates ...but when i am driving the brake operate normally...but gear indicator goes off...also when i turn on indicator and hit brake while driving indicator turns off... :(
Old 10-15-2010, 02:40 PM   #11
mudi
@CTScott yes i have installed alarm system and anti theft switch ... but I installed it about six months ago ... if this is a problem can you tell me how to fix it in simple words lol
Old 10-15-2010, 02:44 PM   #12
If the problem just started, and the alarm has been installed for that long, I would look for a damaged or pinched wire. You would need to take the center console out to get at the connectors on the shift lever.
Old 10-15-2010, 03:31 PM   #13
mudi
@CTScott okie i will get it checked by electrician but here mechanics and electricians sucks specially they dont have knowledge about vitz they treat it as other cars. Thanks for your advice :)
Old 10-16-2010, 04:49 AM   #14
mudi
@CTScott can you please tell me what ECM stands for?
Old 10-16-2010, 06:10 AM   #15
tk-421
tk-421's Avatar
Drives: 5D-07-LB
http://en.wikipedia.org/wiki/Engine_Control_Module
Old 10-16-2010, 09:44 AM   #16
mudi
Old 10-18-2010, 02:11 PM   #17
mudi
i got it checked by electrician he disconnected all the accesories but the problem is still there
Old 10-18-2010, 02:20 PM   #18
This is a mighty hard one to diagnose remotely. What does the battery voltage measure before and during the these events?
Also, which automatic transmission does your Yaris have?
Weird Clicking Sounds Itsnhi DIY / Maintenance / Service 6 12-22-2009 07:30 PM
Weird door locking problem, electrical? davembfan General Yaris / Vitz Discussion 19 09-30-2009 03:50 PM
weird knock at full lock YRX DIY / Maintenance / Service 9 06-18-2009 11:18 PM
Weird question, needs some help! hshi DIY / Maintenance / Service 13 01-07-2009 11:54 PM
A/C smelling weird? Yaris_PR General Yaris / Vitz Discussion 11 08-04-2006 09:26 AM
