Old 02-06-2007, 01:19 AM   #19
Yaris TTE JWRC
Drives: 07 5spd red Yaris HB 1.5L 16V
Originally Posted by PetersRedYaris View Post
These engines don't have timing belts.
Do you even know what a timing belt is?? how can an engine run without a timing belt, how are you going to run the water pump and powersteering?
Yaris TTE JWRC is offline   Reply With Quote
Old 02-06-2007, 01:34 AM   #20
You're both rigtht and wrong, the Yaris uses a timing CHAIN (which connects the crankshaft to the camshafts), and a single accessory BELT which connects the crankshaft to the alternator, air conditioning compressor, etc. You don't see the timing chain from the outside of the engine as it has a cover on top of it.
Yes, it's a lot of semantics, different words for more or less the same thing, easy to get confused.
The echo and xA/xB use two accessory belts as they have a traditional pump based power steering system, while the Yaris' is electric, meaning the extra belt is not needed. Which is why aftermarket Scion pulleys CAN fit on the Yaris, but they'll have an extra groove for that second accessory belt, which is more or less useless.
Anyway this thread is starting to turn a little too nasty, I think we now all need a timeout to re-read what everyone wrote and try to understand each other a little better, OK? Yaris TTE WRC is trying to help and share his experiences, but his choice of words is not always quite so helpful!
Old 02-06-2007, 02:11 AM   #21
ChinoCharles
Drives: LB
Yarii have electric power steering... unusual.
Old 02-06-2007, 03:48 AM   #22
spkrman
Drives: 1
hopefully you already knew that :)
its one of my fav things about the car.
Old 02-06-2007, 06:52 AM   #23
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
ditto
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Old 02-06-2007, 12:20 PM   #24
ChinoCharles
Drives: LB
I only found it out during the NST GB. For a second I thought the car had no power steering, like a Festiva.
Old 02-06-2007, 02:03 PM   #25
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
I do! Apparently you don't as eTimago had to explain it to you. Use the correct terms. It's a chain, NOT a belt, and is internal, as opposed to external with a plastic cover over it. People may interchange the terms accessory and timing when talking about belts but they are not even the same thing nor do they serve the same purpose. One reason I like this 1.5 liter motor is because it does NOT have a timing belt. That means no expensive timing belt replacement/service. You probably feel dumb now, I'll let it go.
P.S. We have nearly the exact same car, even the color is the same. We should be friends!
PetersRedYaris is offline   Reply With Quote
Tanabe Strut Tower Bar Install & Review [pics!] Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 04-07-2022 07:46 AM
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 01-10-2007 06:53 PM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM Performance Modifications 2 10-07-2006 02:26 AM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM General Yaris / Vitz Discussion 3 08-30-2006 09:43 PM
