View Poll Results: Would you be interested in a Supercharger from Jackson Racing?
Yes, I'm interested! 67 94.37%
No, not interested. 4 5.63%
Voters: 71. You may not vote on this poll
Old 02-09-2007, 08:09 PM   #19
spkrman
Drives: 1
Originally Posted by CASTREX View Post
150 hp @ $2500 sounds about right.
Less power or more money than that wouldn't be attractive for must of the Yari owners. Of course there's always people throwing big bucks on anything they drive. I'm just saying what I think it makes the most sense.
yep, 150 wheel hp, though, with the capability to get more with a pulley swap, etc etc I'm really not sure exactly what you could do with this setup.
Old 02-09-2007, 10:41 PM   #20
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
Dude, there's no way to get 150whp out of this motor without internal work done. They said it above a few times, 150 CRANK hp is even a stretch.
The Honda Fit kit, takes it from the stock 95whp to 150whp, but with a hefty 10psi, which IMO is high for a s-chrgr, and will be a hot running car in the summer months. I'm not familiar with the Fit motor, but 10lbs of boost is a lot if the motor is built with weak components like our Yaris' are. Put 10lbs of boost on a stock Yaris motor, and you can kiss it goodbye in a matter of months probably.
Safely, I'd say 6-7lbs of boost, and 140-150 crank hp, or about 120-135whp. A good 50% gain.
Nimble is offline   Reply With Quote
Old 02-09-2007, 10:48 PM   #21
spkrman
Drives: 1
check out the turbo kits from: http://www.zpiracing.net/
its without a shadow of a doubt possible...
the motor has been known to *reliably* handle a 50 shot, and those with the bawls to run 75 havent had problems, this on stock ecu/injectors/no tune etc.
Old 02-09-2007, 11:02 PM   #22
Nimble
Yeah, turbos are nice, but in no way, shape, or form would I try and push the enveloupe on a stock internal Yaris motor. What's the point, to make a high 17 second car a 16 flat car? Waste of time. I would, however, spend $2500 total for 60 reliable hp to make the car more fun to drive.
Old 02-09-2007, 11:26 PM   #23
magoo_lc1
Drives: honda civic hatch
Same here. In the new siphon mag out they got around 155 hp and 148 tq if i remember correctly. If i know blitz though the kit is probaly 5g. I bet me and my buddies can make a turbo kit for these cars for barely a grand if they make injectors and a good fuel rail for it. Hell we have a geo metro convertible that runs 12s. If you want ill post up pics of it.
91 SE-R. R.I.P old freind
The influence of peers on individual behavior illustrates the seductive power of conformity
And, I don't mind at all being looked down upon by purists. Indeed I don't mind at all being looked down upon by those whom I do not look up to at
magoo_lc1 is offline   Reply With Quote
Old 02-09-2007, 11:41 PM   #24
spkrman
Drives: 1
post it in off topic and link to it here :)
Old 02-09-2007, 11:49 PM   #25
LVAquaman
LVAquaman's Avatar
Drives: 2007 Yaris Hatchback
Spkrman,
I for one would like to see the pics of a 12 sec metro.
LVAquaman is offline   Reply With Quote
Old 02-20-2007, 01:12 PM   #26
dansides
dansides's Avatar
Drives: 07 3 dr
blitz now has a turbo for yaris seen in auto mag other day 3800.00 may be old news .
dansides is offline   Reply With Quote
Old 02-20-2007, 01:29 PM   #27
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Correct me if I'm wrong but 1PSI of boost = 10HP
So with a 5PSI waist gate we are looking at 50HP
Our engines, from what I have read and asked around can handle 7PSI without internal Modification.
At 6.5PSI it will need a new Lightweight Flywheel
But with 4-5PSI we don’t even need an Intercooler, As long as we position the Turbo correctly!
Nutzoids is offline   Reply With Quote
Old 07-15-2007, 07:10 PM   #28
Jackson Racing didn't reply to multiple emails -- I guess they are not interested? :sad:
Old 07-16-2007, 12:31 AM   #29
sdmf
Down With the Sickness
sdmf's Avatar
Drives: 2007 yaris liftback
Send a message via AIM to sdmf
underdog racing maybe?
Strength - Determination - Merciless - Forever
sdmf is offline   Reply With Quote
Old 07-16-2007, 05:48 AM   #30
Nigal
Nigal's Avatar
I found the prices on a Honda forum...
"$3500 for 5lbs and $4995 for 10lbs."
So basically I'd have the same interest in this as would Pamela Anderson. Desired from afar and knowing I'll never get a crack at hittin' it.
Old 09-17-2009, 08:04 AM   #31
rpalai
Drives: 2008 NEW Yaris 2-door Liftback
Hi Doc Z! How are you doing? I just saw this passge from you on the forum and wanted o say hello! I love th deflector and the car itself!
I ALSO LOVE the Blitz system I had installed in my Yaris (2008 No. Ameican 2-Dr liftback 5-speed) like 9 months ago. It performs great and still allOws me to get good fuel econOmy at the same time. But the other day, I had an incidence of bad audible detonation at high throttle position I had to use to pass another slower vehicle. I never had that bEfore, But I also never mashed the throttle like I had to like that before either. I realize that a bad tank of Premium fuel could cause that, but not likely as I always use Chevron High Test and have never had a problem in any of my other vehicles. Have you ever heard of this happening, or had it yourself? DO you know of any fixes, etc to prevent this from happeneing again? I am very concerned as I do not want to have to replace my motor at any time. Still, I want to be able to use higher throttle whenever it is necessary without having this Detonation occur. Please let me know, as I'd really appreciate anything at all you can tell me about this issue. Thanks!
Rich
rpalai
Originally Posted by Doc Zaius View Post
Very interesting...!! Hmmmm... I've been leaning towards a turbo application recently, but now... I'll have to go do some research!
BTW, pretty cool how our website has a pretty big influence on the development of Yaris aftermarket support! And good for being proactive, redglare!
rpalai is offline   Reply With Quote
Gauge Pod for Liftback? eight_heads General Yaris / Vitz Discussion 2 06-07-2007 10:41 AM
temp gauge? gaf99 General Yaris / Vitz Discussion 10 01-15-2007 10:43 PM
Supercharger? iampachino Performance Modifications 15 08-24-2006 04:51 AM
Temperature gauge fearturtle44 General Yaris / Vitz Discussion 1 05-18-2006 08:54 AM
