Old 03-04-2011, 06:03 PM   #1
bB2NER
My Box and Her Egg
bB2NER's Avatar
Drives: 05' Scion xB / 08' Yaris 3dr
Easy mod for 5 spd. LBs starting/shifting.
I always hated how you had to push the clutch ALL the way to the floor to start it. I came up with a cheap easy fix for this issue.
I took a small 1" square piece of high dense foam (the kind that has smooth finish on the outside) and using some red 3M molding tape attatched it to the tab on the clutch lever where it contacts the switch. It gives enough so if you do push it to the floor it won't restrict pedal movement but contacts the switch earlier making it easier to start.
I also adjusted the push rod so the clutch doesn't grab so close to the floor.
It takes a 14mm and 13mm wrench and some small vise grips.
Use the 14mm wrench to hold the switch and the 13mm to loosen the locknut. With the locknut loose you can unscrew the pushrod 1 1/2 turns (making it slightly longer). I used visegrip to turn the rod cause it was kinda hard to do it by hand. Then retighten the locknut and you are done.
The clutch now grabs later and shifts much easier and more normal.
bB2NER is offline   Reply With Quote
Old 03-04-2011, 06:31 PM   #2
^ I disable that clutch switch with every manual car I buy. Just jumper it.
You should post pictures.
Old 03-04-2011, 07:08 PM   #3
bB2NER
My Box and Her Egg
bB2NER's Avatar
I'll try and post a pic later on. It's so tight up in there.
I didn't want to disable it for safety. Just make it so you only push the clutch slightly past halfway to start. Enough so the car doesn't lurch forward when in gear.
Old 03-05-2011, 01:41 AM   #4
yaris2010RS
yaris2010RS's Avatar
i personally never leave my car in gear and that was the first mod i did, i used ducktape to hold down the switch.
Garm, really just a jumper will work? for some reason i was under the impression it was a "smart" sensor and told the car if it was bipassed or not
Old 03-05-2011, 07:38 AM   #5
AppleJacks716
Drives: 2010 5 Door
Really? I mean really? Foam between the pedal and switch? That doesn't make you the least bit uncomfortable driving knowing you shoved something between the pedal and the switch? Why would you get a manual car if you don't want to fully use the clutch? Electronically disabling the clutch is much safer.
AppleJacks716 is offline   Reply With Quote
Old 03-05-2011, 08:44 AM   #6
bB2NER
My Box and Her Egg
bB2NER's Avatar
It's FOAM and fully compresses when you push the pedal to the floor. The clutch IS fully functional still.
Electronically disableing the switch completely is a law suit waiting to happen. If someone were to drive the car not knowing the switch isn't there and they hit the key with it in gear and the car lurches and hits another car. Then what?
Old 03-05-2011, 09:02 AM   #7
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Just make sure you still have enough freeplay when the clutch is up. There should be another stopper at the top for that. Or you could risk cooking the through out bearing.
Old 03-05-2011, 09:20 AM   #8
bB2NER
My Box and Her Egg
bB2NER's Avatar
How is the freeplay measured exactly? Thanks
The slave cylinder seems to re adjust the freeplay for the throwout bearing by itself.
Old 03-05-2011, 10:03 AM   #9
Bluevitz-rs
there should be a few MM of freeplay when the clutch is at the top before it gets harder to push by hand. Like a loose spot at the very top.
Old 03-05-2011, 10:24 AM   #10
bB2NER
My Box and Her Egg
bB2NER's Avatar
Thanks, I'll check it out before I drive it again.
Old 03-05-2011, 10:39 AM   #11
AppleJacks716
Drives: 2010 5 Door
You are probably parked too close to the car in front of you.
Both void any warranty, if you have it, and is just catering to lazy people who should have bought an automatic.
Old 03-05-2011, 11:21 AM   #12
1. Try starting the car with the clutch switch disabled and the e-brake on. The car doesn't move, guys.
Only if you let other people drive your car. I don't. Besides, everyone is already trained to depress the clutch when they start a manual.
I'm confused now. Didn't you say this:
Then this?
Old 03-05-2011, 12:11 PM   #13
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I find that the clutch pedal is one of the weaker aspects of the Yaris, so anything that can help with that has my attention.
@bB2NER: I like your idea of lengthening the pushrod... I would really appreciate some pics of the process to see if I can do this myself or not... TIA
Yaris Towing 1000 lbs? Aquahiker General Yaris / Vitz Discussion 188 04-02-2019 05:42 AM
Quick, Easy and Cheap mod bB2NER Cosmetic Modifications (Exterior/Interior) 11 03-06-2011 11:55 PM
Engine Pull Anthony_kp61dotnet Performance Modifications 12 03-11-2009 07:13 PM
manual transmission: to mod or not to mod? tomato General Yaris / Vitz Discussion 34 03-08-2009 10:40 AM
