#307 |
![]() ![]() Drives: 2007 Yaris Sedan Join Date: Oct 2008
How would hardwiring around the sensor solve the problem?
Maybe I'm not understanding your idea properly. It seems to me that if you were to do that, you'd still be driving a car without a functioning speed sensor that no longer has ABS. You might as well just pull the fuse and not cut any wires. I'd hate to have to explain to my insurance company that I got in an accident because I cut a bunch of wires off my brakes. |
#308 |
speed sensor -> connector -> wires
proposed solution: speed sensor -> wires Since the issue is corrosion in the connector, the idea put forth by yaris2010RS is to directly bypass the connector and hard wire direct to the sensor.
#309 |
Riiiiight. Sorry, it's been a long day. My bad.
#310 |
![]() ![]() ![]() ![]() Drives: 06 yaris 5-dr le man Join Date: Mar 2006
i'm writing a letter to the wheels section of the toronto star regarding this, perhaps if more of us did that we would get some attention and therefore action from toyota canada.
here's the email for the editorial staff of the wheels section if anyone else feels so inclined: wheels@thestar.ca |
#311 |
after a couple of calls to the service manager of my dealership and toyota canada, they ended up covering 80% of the price to replace the faulty sensor and wiring harness on my yaris,
so it cost $75 plus the initial $50 diagnostic (this is for the one side only). while i was happy that it did not cost $416 like i was quoted i'm still not entirely satisfied as i think this is a defective part. i think there's a good chance the other side will eventually go as well so i'm wondering if they will hand me the same token for that one? |
#312 |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jun 2006
I went to my tire place, they checked all connections; they saw nothing worth alarming, and it only came on one more time after this and now the weather is warmer, it has not returned. I do expect to see it next winter, and I will get it taken care of at that time.
#313 | |
#314 |
![]() ![]() ![]() Drives: 2007 Yaris Hatch Join Date: Feb 2007
Has this been recalled by toyota yet????????
#315 |
Lot's of good info in this thread. My abs/ brake light recently came on so I checked my rear sensors and this is what I found. One pin basically corroded off completely. Their has to be a replacement sensor available with out having to buy a whole new hub. Or an updated part. I think i'm going to try and remove the sensor and see what happens. Are their any updates on whether or not you can buy just the sensor???? From looking at the base, it looks like a twist and pull removal. Similar to a parking light bulb. If the whole hub needs to be replaced then it looks like a bad design on Aisin's part.
![]() ![]() ![]() Here is a link to Aisin's website >> http://www.aisin.com/product/automot...ake/index.html If you scroll down you will se they are mighty proud of their offerings The speed sensor with integrated hub is the exact toyota model! The bottom speed sensor which they refer to as "stick style" is used on the front of the yaris. I think we should all email aisin and say wtf!
#316 |
![]() Drives: Blueberry Join Date: May 2011
Both of my lights are on as well - somewhat of a comfort to know that I'm not the only one.
I drive an '07 RS HB. I have to go in tomorrow for service so I will talk to them about it then. This really should be a recall... |
#317 |
![]() Drives: 08 Blazing Blue LB Join Date: Jul 2009
I'm having the problem as well, it started happening this past winter. I cleaned the rear sensors and applied Dielectric Tune-up Grease and still have the lights on. I really don't want to have to pay anything to have this problem fixed, since it should be recalled. I'm very disappointed Toyota has done nothing for their clients. Worst part is that unless the design for the sensors themselves are not changed, it will just keep us all going back to the shop.
I contacted the National Highway Traffic Safety Administration http://www-odi.nhtsa.dot.gov/complaints/index.cfm I urge those in the US to do the same. Last edited by sternz; 05-21-2011 at 11:11 AM. Reason: Added direct url for vehicle complaint |
#318 |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
I've tried almost everything to get Toyota to do SOMETHING about this, but unless I pay them to do the repair they won't budge. Toyota Canada is crap when trying to get anything.
They should have really had a recall for this issue since it's happening to more and more people. I just leave the lights on the dash on, I don't care any more since they keep coming back on. |
#319 |
They turn on and off all the time, specially when wet.
D.
. CLA 250, 4MATIC |
#320 |
91octane $2.24nzd / litre
Drives: 05 5d 1.3 CVT Join Date: Jul 2009
Okay now I'm really confused...
ABS light comes on, I don't own any diag stuff to plug into it so I jumpered 4 & 13. ABS light flashes 4 times then goes out, then flashes 9 times. None of this even comes close to what is listed above.. does anyone know what it's complaining about? Last edited by Mikeey01nzl; 05-28-2011 at 12:51 AM. |
#321 | |
I'm sorry if I'm been naive here, but what does it means to " I jumper 4 & 13"D.
. CLA 250, 4MATIC |
#322 | |
http://www.yarisworld.com/forums/sho...&postcount=262 So back to my orginal question chaps.... what the heck is 49 or 94 flashes on the ABS light really mean?
#323 |
Drives: 2007 Yaris Join Date: Jul 2011
ABS AGAIN
I have two 07 Yaris', a sedan and a HB. The ABS problem, I believe, is due to road salt probably causing corrosion. The dealer will fix, I believe, for about $600 - $1000 by replacing all the wiring (not needed only the rear wheels cause the problem). I found that the front wheels were fine. However on the rear wheels the elctrical connection going into the wheel hub does not have an outer plastic insulation covering (as it does on the front hub) only the individual wires going to the sensor. I sprayed the cables with WD40 and then regular engine oil and filled the little pocket/pit/depression with oil at the hub. After a couple of weeks the ABS came on less frequently. Now after about a month it no longer comes on at all and that has been like that for about 4 months now. Got the idea because the one vehicle I had rust proofed never developed a problem. Hope this helps someone and save a pocket full of cash.
It's heaven, before the ABS light was always on. Cheers Iain |
#324 |
![]() ![]() Drives: 07 Yaris Sedan Join Date: Jan 2009
If you're handy and Toyota seems a bit much, you can always order 2 new after market rear ABS sensors for $288 CAD (taxes, brokerage and shipping included) from Rockauto. http://goo.gl/L6z5o
