Old 02-27-2007, 10:29 PM   #1
JDM_EK3
JDM_EK3's Avatar
Drives: 2006 Toyota Yaris RS
Shiftknob....?
Just curious if a Manual Transmission Shiftknob will work universally on a Toyota Yaris with an Automatic Transmission? As I wouldn't mind purchasing the Blitz Duracon Shiftknob.
JDM_EK3 is offline   Reply With Quote
Old 02-27-2007, 10:36 PM   #2
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
Yea they fit since the Yaris doesn't have that gear selector knob usually found on older model automatic cars. I myself am planning on getting the Sparco Lithium shift knob for my automatic.
Old 02-27-2007, 11:06 PM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
I am pretty sure there are different part # 's for the Auto and the Manual
Old 02-27-2007, 11:38 PM   #4
JDM_EK3
JDM_EK3's Avatar
Well of course there would be different part numbers, as one would have a shift pattern, and one would not. However that's not to say they aren't interchangeable.
Old 02-27-2007, 11:44 PM   #5
Black Yaris
der Zeck
even after market ones have different part #'s for Man and Auto
Old 02-27-2007, 11:48 PM   #6
DJ_Trizzak
DJ_Trizzak's Avatar
Drives: Yaris 07 Auto CE -Blazin Blue
depends if theres an adapter
myspace.com/djtrizzak | epik.ca | track1.ca |
DJ_Trizzak is offline   Reply With Quote
Old 02-28-2007, 12:34 AM   #7
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
I'm pretty sure whether there is an adapter or not a manual shift knob would fit onto the Yaris automatic gear shifter. I've taken my shift knob off my automatic yaris and it looks the same as my TC shift knob (manual). Easy to swap out but only difference is that the automatic knobs look a bit smaller than the manual knobs but that shouldn't matter since you'd be getting an aftermarket one.
Old 02-28-2007, 07:57 AM   #8
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
The automatic has an 8mm shaft and the manual has a 12mm.
Old 02-28-2007, 07:22 PM   #9
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
Thanks Mr. Shift Knob expert
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 02-28-2007, 07:39 PM   #10
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
Do aftermarket shift knobs come with adapters?
Old 02-28-2007, 07:43 PM   #11
bigsky2
Cousin Vitz
bigsky2's Avatar
Not always.
If you purchase an OEM manufactured shift knob, it will come with adapters.
E.g. OBX shift knobs for Toyota/Scion will come with adapters
Other aftermarket shift knobs do not come with adapters, but are fastened by using three screws on the bottom of the shift knob, which "grip" the stick shift. This is how MOMO shift knobs are secured to the stick shift.
Old 02-28-2007, 09:49 PM   #12
JDM_EK3
JDM_EK3's Avatar
Anyone have a clue about Blitz's Shift Knob? As I'd actually really love to pick it up for both the Yaris, and my Civic.
Old 03-01-2007, 02:42 AM   #13
bigsky2
Cousin Vitz
bigsky2's Avatar
JDM_EK3:
Blitz Shift Knobs come in particular threaded applications for Toyota/Subaru/Honda/etc.
The Toyota thread pattern is 12mm (manual transmission).
Old 03-01-2007, 04:59 AM   #14
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
Originally Posted by bigsky2 View Post
Not always.
I believe that is how Sparco works also. Is it worse than using adapters or is it about the same in durability standards (three screws compared to adapters)?
Old 03-01-2007, 07:19 AM   #15
bigsky2
Cousin Vitz
bigsky2's Avatar
I feel that adapters, or better yet, shift knobs with the correct thread pattern (ie. directly screwed on without the need of an adapter), are a better fit than the universal fasteners which use the three screws.
Adapters compensate for the incorrect thread patterns as they will thread directly onto the shift knob on the inside, while securing the shift knob to the stick shift. Overall this makes for a good fit too.
In the past I found that my MOMO shift knob became loose after a few months usage and would require some tightening/retorquing of the screws.
Old 03-01-2007, 03:36 PM   #16
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
Then I guess I'll take my chances with the Sparco shift knob. Thanks for all the info though
Old 03-01-2007, 03:47 PM   #17
bigsky2
Cousin Vitz
bigsky2's Avatar
Either way you should be okay.
Try not to tighten the screws too much of it's a universal fitting knob, as it might strip the threads!
Old 03-01-2007, 06:44 PM   #18
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
I'll have to remember that once i get my shift knob in
