Old 08-17-2011, 03:31 AM   #19
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Rooted and OCed mine. OC is absolutely necessary to play Hulu..well root too. But in the end, i need more of a laptop than what even the docked form can provide. Afterall its still weaker than a netbook. Plus theres an update to the eepad coming very very soon with the new processor.
Check out my Build thread:
Old 08-25-2011, 03:44 PM   #20
Emerge
On a trek to upgrade...
Drives: 2003 Echo Coupe
Originally Posted by toy_toronto View Post
Emerge, any update on this?
OT: I'm loving this Eeepad, have you rooted or OC'd your TF tablet yet? I'm thinking about doing mine.
Saving money for it, I still also need to find a way to keep it charging while it is in use.
Emerge is offline   Reply With Quote
Old 08-25-2011, 04:00 PM   #21
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
In-car charging is actually pretty simple. The TF expects to see 12v before it starts to charge over USB (unlike other devices that works fine with 5v), so I would just modify the internals of this to supply the 12v directly to the USB pin 1 & 4 (pref fused at 1.5A):
-toy
Old 08-25-2011, 04:27 PM   #22
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
-toy
I wouldn't recommend that. USB spec is 5v period. If his pad charges through the USB port then it charges using 5v not 12v.
Old 08-25-2011, 05:01 PM   #23
toy_toronto
always toyin'
Drives: 2010 5-Dr
^ It's already been researched and proven to work. I have already built my own DIY home adapter for my Eee Pad and works flawless.
http://forum.xda-developers.com/show....php?t=1087321
-toy
Old 08-28-2011, 04:50 PM   #24
Emerge
I'm going to best buy today to look at some stuff. Wish me luck!
Old 09-02-2011, 04:43 PM   #25
ezhacker1
ezhacker1's Avatar
update?
Old 09-04-2011, 02:01 PM   #26
Altitude
Altitude's Avatar
Just picked up an Acer A100 Iconia 7" tablet (Honeycomb 3.2!). Over the next several months I'll be working on getting it installed and writing some custom SW to work with my bluetooth OBDII unit (which means I'll be selling my ScanGaugeII, Ultragauge and possibly my HU.)
The size of this tablet is almost a perfect fit for the OEM radio bezel. Hopefully I can work out an installation that looks super clean. It doesn't have cellular capability (I think the A101 does) but I think I can use my android phone and tether it when needed. Does have GPS, BT and WiFi so all that's good. Not sure if the USB port supports hosting, but I think the dock connector will so I might have to buy a dock and cannibalize it for the port connector.
Should be an interesting project and I think this is a better solution (less hassle and less cost) than a carputer which is something I always wanted to install but never had the time.
Old 09-04-2011, 02:34 PM   #27
yep, the advent of (relatively) cheap, powerful tablets is going to make some big changes to in-car entertainment, that's for sure!
Old 09-04-2011, 10:08 PM   #28
ezhacker1
ezhacker1's Avatar
I just got a used Nook Color, its perfect with it's IPS screen, sure I could have gotten a real tablet but at $185, how could I say no. Doesn't have gps on board but externals are usually faster at refreshing.
Definitely interested in what oBd stuff you'll do, better than Torque?
Old 09-05-2011, 07:53 PM   #29
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I pretty much scrubbed my earlier attempt at a carpc, and am looking forward to getting a Nook very soon as well. At $180ish it's too good a price to pass up. Heck, at that price it could almost be worth it to get a couple more for the rear seats (if I still had any )
Old 09-07-2011, 02:36 AM   #30
Emerge
Originally Posted by ezhacker1 View Post
update?
Found a decent solution for in car charging. Next step is deciding where the eff I am going to put this damn thing.
Old 09-07-2011, 06:32 AM   #31
if I had the fabrication skills, I would get the blank 2-DIN plastic plate that the base models came with instead of a radio, and make some brackets that directly attach to that.
Which tablet did you buy? You should check if there is a desktop dock available for it, that would make for a good base, and keep the tablet easily removable, all you would need is a spring loaded clamp to hold it in place at the top.
Old 09-10-2011, 03:12 PM   #32
Altitude
Altitude's Avatar
Looks like finding the right amp is going to be the challenge. Been looking for a *small* 5 channel and they are hard to find. Something along the lines of the pic that Emerge has in one post only with the addition of a sub/5th channel.
Everything I see is huge wattage and for show. I don't care what it looks like. I don't need huge wattage either. I want to hide it, preferably behind the dash.
Emerge - Where did you get that pic of the tiny amp? I tried to search for it using the brand and model number on the unit and can't find it.
Test Fit:
Old 09-10-2011, 11:56 PM   #33
ezhacker1
ezhacker1's Avatar
nice work, get nook in soon
Old 09-11-2011, 10:38 AM   #34
Lil Abner
Drives: 2009 3dr LB Manual
That fits quite nicely!
Altitude, look on eBay. There are a TON of small 2-channel, low power amps out there. They are usually $20-30. I personally have 2 tiny old-school Blaupunkt amps (2x25W) that I always used for my tweeters. I can't remember the site I found that had a ton of them. But here is an example of one I use to own:
http://www.crutchfield.com/S-FFyk0Ps...kt-PA2100.html
Also remember, there is room under the passenger seat for an amp!
Old 09-11-2011, 05:12 PM   #35
Altitude
Altitude's Avatar
Thanks Lil Abner. Thing is, I already have an amp under the passenger seat for the SW. I think what I'll probably do is get a single DIN HU that has the outputs I need and also has an AUX input so I can hook the tablet up to it. There's room to stash the HU behind the tablet, just need to tie it down.
Old 09-15-2011, 01:58 AM   #36
ezhacker1
ezhacker1's Avatar
Got my Nook Color installed. The bezel thickness is causing me some mind pain {installed as close to the radio trim as possible, needs some side trim pieces}. The tablet is too tall when laid horizontally. pictures to follow to explain. Tho it looks awesome to have Torque app running there.
I'd like to be able to remove the tablet from the car but right now ibhave to remove the HU trim to do so. It's too wide to just come out of the Double Din bezel
Dash lights won't work after installing new head unit? blh4645 General Yaris / Vitz Discussion 10 04-06-2010 06:17 AM
Need help with installing head unit Pioneer AVH-P6850DVD JCMoon In Car Entertainment + Electronics (audio / video / alarm) 1 08-31-2007 10:27 AM
Req: Head unit suggestions. xed In Car Entertainment + Electronics (audio / video / alarm) 21 08-09-2007 07:38 PM
