Old 03-29-2012, 10:00 AM   #127
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
just hit 80k and sometime in the last 10k miles and that flap that is mentioned in some TSB in the neck to the fuel tank went bad so I am throwing a CEL for it.
Old 04-04-2012, 12:04 PM   #128
jerome
Toyota
Drives: '11 5dr/5spd yaris
Checking in for March and April:
March 1: 3,638
April 1: 3,727
On April first I finally filled my tank after not filling it up since December 26th!
So after 43 weeks of ownership, I've averaged out to: 87 miles/wk
Planning on at least a short road trip this month!
jerome is offline   Reply With Quote
Old 04-07-2012, 10:44 AM   #129
Hershey
Someone we know has a little over 100,000 miles on their 2010 3 door . Used for their business . Very few problems . Has only replaced air filter twice that I'm aware of . I cleaned the original and later gave him a used air filter from our Yaris that was in better condition . Imagine it's still in use . Have to check it again . Gets oil changes every 4 > 5,000 miles at Toyota service center , so likely to be conventional .
Old 04-07-2012, 10:50 AM   #130
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
2009 hatchback
23,000 miles on it.
Replaced waterpump at 21,000 miles.
Twistoffate0817 is offline   Reply With Quote
Old 04-07-2012, 01:53 PM   #131
Kal-El
Kal-El's Avatar
Took this a couple weeks ago.
Old 04-09-2012, 11:13 AM   #132
clubcrasher71
Drives: Toyota Yaris 2010
2010 White
40500 miles
still running with OEM tires. wondering when to change, I guess when tires have no threads left. LOL.
clubcrasher71 is offline   Reply With Quote
Old 04-09-2012, 11:39 AM   #133
33OH
Drives: '08 Yaris
^ Welcome!
And you change tires when the tread is even with the tread depth indicators on the tires.
Old 04-09-2012, 03:49 PM   #134
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
i'd change out the oem tires as soon as you feel comfortable spending the cash. They're terrible.
Colin Chapman disciple
Old 04-09-2012, 10:58 PM   #135
Hershey
Got that right . The Continental Pro Contact w/ Eco Plus made a big improvement in the ride , handling ( especially ran soaked roads ) , and noise level inside . Gas mileage remains about the same as with the Potenza RE 92s . Keep tires at 35 > 37 p.s.i..
Old 04-10-2012, 10:11 AM   #136
746watts
Drives: 2014 yaris hybrid
Year: 2008
Model: 1.4 D4D
Odometer: 201900 kms
Problem: Rear left wheel bearing starting to hum, no play on wheel when jacked up but spinning the wheel by hand reveals the unhappy bearing noise. It's an ABS model, sealed unit (what muppet designed this?). Have to price a replacement today from Toyota dealer, got a price from autoparts (generic) of €140 or so.
746watts is offline   Reply With Quote
Old 04-12-2012, 03:40 AM   #137
carolinablue
Drives: 2012
Yesterday I drove about 40 miles: 30 percent country roads at 55 and 70 percent on 4 lane highway at just under 60. Before I left home I reset my factory fuel gauge. I drove with an extremely light foot. I was pleasantly astounded when I checked my MPG gauge just before I exited the highway to discover that it had recorded 46 MPG.
carolinablue is offline   Reply With Quote
Old 04-12-2012, 08:46 AM   #138
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
Carmine Red, 2010 3 door hatchback
13,600 miles - bought new June 2010
Only money I spent on it: $6 for a cabin air filter
Free oil changes through ToyotaCare which I got free when I bought it
I may have to do a road trip. My ToyotaCare expires early June and I don't know if I can get the odometer up to 15K by then for my final free oil change.
DebbyM46227 is offline   Reply With Quote
Old 04-12-2012, 08:53 AM   #139
vincentg
vincentg's Avatar
Drives: Toyota Yaris 2007
2007 Toyota Yaris 5door Hatchback
Super Black!
33500 kilometers! :)
so far only the tail light is not working properly
change oil in a couple of days
JUST DRIVE
vincentg is offline   Reply With Quote
Old 04-12-2012, 09:32 AM   #140
randeez
Drives: 2008 3dr
Originally Posted by randeez View Post
2008 polar white liftback 3dr 5sp. bought it at 30,xxx miles, up to 32,500 now
only problem so far is a little stumble i get while idling...i dont have a tach so i couldnt tell ya how many rpm it drops, but it's enough to make the car shudder for a sec or two then jumps right back up....any ideas?
5 months and 20,000 miles
just shy of 50,000 miles now, couple of syn oil changes, replacing air filter, changed plugs (no difference), still have a low idle stumble every once and a while. just rotated tires and checked brakes front/rear. finally got a ultragauge- the lack of gauges in the base model leaves mea bit worried. have it set up for instant mpg, average mpg, tach, water temp, voltage, and miles till empty- going to see if i can find oil pressure though
randeez is offline   Reply With Quote
Old 04-12-2012, 12:22 PM   #141
Kal-El
Kal-El's Avatar
Wow, what's your commute like?
Old 04-12-2012, 12:49 PM   #142
randeez
Drives: 2008 3dr
on a good week 600 miles just back and forth to office, on a bad week 1500+
Old 04-24-2012, 08:49 AM   #143
lambornisyoantuan
Drives: 2000 Yaris
2000 Yaris hatchback
Silver
53,000km
lambornisyoantuan is offline   Reply With Quote
Old 04-27-2012, 06:00 PM   #144
12 yaris
Drives: '12 Yaris LE Lagoon Blue Mica
4000mi./0 issues
12 yaris is offline   Reply With Quote
excessive sulfur odor on 2007 model year Yaris tomjasz General Yaris / Vitz Discussion 121 03-13-2010 06:49 PM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
