Old 12-03-2012, 01:14 AM   #163
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
The inside diameter of stock 2012 header runners is 28mm and the Weapon R's are 36mm...
Old 12-03-2012, 04:18 PM   #164
NJ Drive
Drives: 2012 Yaris SE
So perhaps the Weapon R is the closest port-matched of the two considering the amount of soot on the OEM. Anyone have an I.D. of an exhaust port?
NJ Drive is offline   Reply With Quote
Old 12-03-2012, 04:49 PM   #165
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I measured 35mm for the port and 40mm for the gasket.
Old 12-03-2012, 05:39 PM   #166
NJ Drive
Thanks. I have to be honest- the more I gather reading about 'bolt-on' solutions, I'd rather buy one of yours, assuming you find appreciable gains. I don't doubt that you will.
I intend to run a single hi-flow with a Burns muffler anyway, so might as well do it right.
Old 12-03-2012, 07:58 PM   #167
xnamerxx
0-60 in slow
xnamerxx's Avatar
I was once told by a GM engineer that the absolute best solution and absolute worse solution for exhaust is generally only a few % different. I've taken this advice to heart knowing the expected gains and losses can only be so much.
I do expect gains but the dyno and racing will be the true test if it actually works, I have simulation numbers, but those aren't always accurate to the real world.
If you want an easy/cheap solution ots parts work, but have the same design constraints production parts have, so you won't get the "best" solution. I can tell you this I noticed a significant loss of low-mid-range torque with the DC header while getting a size-able gain in topend torque. If you look at my dynosheet you can see that the DC produces a sizeable dip between 2700-3800 rpm, it feels really gutless out of slower corners but nice up top.
Old 12-03-2012, 08:39 PM   #168
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
I have to defend the DC header, as I think it's been the single best bolt-on since I started messing with this car.
First mod was a K&N typhoon intake, other than more engine noise, I didn't feel much change.
Second mod was the DC header. I noticed no mid-range torque loss and a noticeable change to the way the top end acted. The engine breathed better in the top end, instead of running out of steam before redline like before. The power across the board seems more linear. Despite the cost I would recommend the header.
Last engine mod I've done is a resonator-back obx exhaust. I didn't really notice any seat of the pants change from this.
Now with these mods the car is easier to drive. It's surprising torquey in 5th gear, I don't have to downshift to 4th gear any more when going up hills on the highway, even with passengers. It still doesn't have the top end that my Honda cars had, which it probably never will. It pulls really well in the 3000-5500 range though for a 1.5L. Overall I'm happy with the mods, I/H/E are worth it in my opinion.
4/20 NEVER FORGET is offline   Reply With Quote
Old 12-04-2012, 12:58 PM   #169
^ Good luck, and congrats on vacation time!
Old 12-04-2012, 03:16 PM   #170
tooter
play every day
tooter's Avatar
Do show us pics of your project, and jack up the front of the car. It makes getting to the headpipe bolts sooo much easier from the bottom.
Old 12-04-2012, 05:02 PM   #171
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Originally Posted by TOLMACH View Post
^Tooter: I am pretty sure you can do the whole thing without jacking a car - you just need to be a giant octopus
^best answer ever.
Old 12-04-2012, 05:16 PM   #172
tooter
play every day
tooter's Avatar
I already did. Having the front of the car up helped make it easier... and I need all the help I can get.
Old 12-05-2012, 11:24 AM   #173
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
some pics
all crap moved to the trunk while working on the header
Off Topic, But liked your JL sub setup. Pretty cool. Can you PM me a link or do you have more pictures of your install?
JustDidIt is offline   Reply With Quote
Old 12-09-2012, 10:53 PM   #174
DJYojimbo
Drives: 2012 Grey Toyota Yaris SE
I know this header is ceramic so there's no need to wrap it right?
DJYojimbo is offline   Reply With Quote
Old 12-09-2012, 10:56 PM   #175
xnamerxx
0-60 in slow
xnamerxx's Avatar
DO NOT WRAP A HEADER!!! wrap is bad avoid it, it holds moisture and increases corrosion. Its coated leave it as is.
Old 12-09-2012, 11:01 PM   #176
DJYojimbo
Thank You for the advice
Old 09-27-2013, 04:11 PM   #177
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Possible? Sure.
PITA? Definitely.
Old 09-27-2013, 05:23 PM   #178
The flange bolts from header to downpipe are only accessible from below. I don't know about you, but personally I cannot fit under the car if not raised.
Old 09-29-2013, 08:51 AM   #179
tooter
play every day
tooter's Avatar
Originally Posted by blkfwlr View Post
I'm thinking to drive the front of the car on a curb just enough, so it would be sitting over the concrete, on the grass. Then I can slide underneath and hopefully reach the bolts still. Or is there a reason why this is flawed ?
Won't be on grass, just concrete. Going to do tomorrow morning.
That's a very clever idea!
If you can, post some pics of your installation.
Greg
Old 10-07-2013, 09:27 PM   #180
Neurotic Hapi Snak
Drives: 2011 Yaris 3dr
Is there a reason you don't put the heat shield back on? You'd think you'd want to, to keep your engine bay cool and exhaust header hot.
Neurotic Hapi Snak is offline   Reply With Quote
